Question about DeLonghi CTO4003 4Slice Toaster
Left hand side not working will not lock or heat up
This is a double toaster.Model number 18140. Right hand side of product fails to stop/lock down (its electrically operated)
You need to open it up. These toasters have small mechanical locking devices under the cover. you need to see what isn't working.
Mar 17, 2016 | Russell Hobbs Kitchen Appliances - Others
How do I replace the inner tie rods?
undo the ball joints at the steering arms , loosen off the lock nuts just enough to unscrew the rods
Right hand side right hand thread , left side left hand thread
If you do not move the lock nut back more than 1 thread then you set the lock nut in the same place on the new rod , you will not need a wheel alignment
If you have to take the lock nuts off to fit to the new rods , measure the distance from the end of the rod to the face of the lock nut and position the lock nut at that distance on the new rods
Jan 13, 2016 | Cars & Trucks
Toaster won't turn off
its broken, retun it to the place you brought it and demand a refund
Nov 22, 2013 | Russell Hobbs 18117 4-Slice Deluxe Toaster...
No indicators working found fuse box which fuse?
When you are talking about "indicators" we could assuming that your are refer about signal lights. This work with "flashers" devices.
For 1996 Audi A4 2.8L SFI 6cyl the Flasher is located in front seating area, driver side, under dash, behind dash lower panel, mounted above driver side of steering column.
About generic fuses, open the driver side door. Remove panel on left side of dash. Fuse box is behind panel:
Fuse # / Description / Amps
1 / Heated washer jets / 5
2 / Turn signals flasher unit / 10
3 / Headlight washer, illumination of glove compartment, engine compartment, climate control, automatic transmission, instrument cluster / 5
4 / License plate light / 5
5 / Instrument cluster, seat heating, test connection for cruise control, bulb monitor for auto-check control, Automatic transmission display, switch lighting, mirror switches and actuators, airbag warning light, outside temperature indicator, Climate control / 10
6 / Central locking system / 5
7 / Anti-lock brake system / 10
8 / Vacant
9 / Mirror heating / 10
10 / Vacant
11 / Cruise control (automatic transmission) / 5
12 / On board diagnostic system / 10
13 / Brake lights / 10
14 / Interior lights, reading lights, anti-theft alarm system, vanity mirror / 10
15 / Instrument cluster, power windows, climate control, automatic transmission / 10
16 / Anti-lock brake system, Anti-Slip-Regulation / 5
17 / Heated door locks / 10
18 / High beam right / 10
19 / High beam left / 10
20 / Low beam right / 15
21 / Low beam left / 15
22 / Tail and side marker right / 5
23 / Tail and side marker left / 5
24 / Wiper and washer system / 25
25 / Blower for heating, climate control / 30
26 / Rear window defogger, mirror heating / 30
27 / Rear window wiper / 15
28 / Fuel pump / 15
29 / Engine timing / 20
30 / Sun roof / 20
31 / Tail lights, cruise control, automatic transmission / 15
32 / Engine timing / 20
33 / Cigarette lighter / 15
34 / Engine timing / 15
35 / Trailer receptacle / 30
36 / Fog lights / 15
37 / Radio / 20
38 / Luggage compartment light, central locking system / 15
39 / Emergency flasher / 15
40 / Horn / 25
41 / Anti-lock brake system / 25
42 / Vacant
43 / Vacant
44 / Seat heating / 30
Hope this helps (remember to rate and comme this free answeer).
Jun 16, 2011 | 1996 Audi A4
I have a 2002 Freelander 2.5 SE automatic V6. All the interior lights are working apart from the centre console lights. The fuel, temperature, rev counter and speedo are all working. The heated rear screen...
The internal panel lights work off the left hand side of the side lights and are protected by the 10 amp fuse for this side. I had replaced both stop and tail lights with a heavy duty bulbs and because the left hand side powers the panel lights as well, obviously it was too much for the circuit. The right hand side was okay.
Oct 30, 2009 | 2002 Land Rover Freelander
The outside middle front & left hand side of the fridge were hot
The reason you feel heat by the middle of the door is because of the "mullion heater' or anti-sweat.
Check the temperature of the freezer, must be below 12*F for the ice maker to work.
Apr 23, 2009 | Kenmore Refrigerators
Touch screen - left hand side does not work
this sometimes happends if you have knocked the screen a few times.
it also does this when there is water inside it i would recommedn you place it on your heater for 2 hours.
if there is a chip in the screen or the left hand side of the screen is smashed it will not work because the sensors will be damaged
Apr 08, 2009 | Samsung Tocco F480 - Pay Monthly Cellular...
Dryer runs but does not heat
I have just had a similar problem and fixed it today.
The "Empty Water" light was staying on and no heat was given out to dry the load.
I found it to be the float switch in the condenser unit at the back left. It had stuck with fluff and debris. I cleaned out the condenser reservoir and the polystrene float and now all is well.
To get to this unit you must first,
Take of the top and the left hand side panel.
Locate the 2 locking tabs that hold the top half of the condenser onto the back panel and release this part.
Remove this by releasing 2 further tabs that hold it to it's bottom half,
and you will see the float switch assembly on the left hand side.
Clean out the condenser reservoir of any water and aslo clean the polystyrene float, it needs to be free to slide up and down between the plastic guides.
Hope this helps.
JohnM
Aug 20, 2008 | Whirlpool Dryers
Does not heat
Hope this helps.
JohnM
Aug 20, 2008 | Dryers
Blue screen red lock
I dont have a clue what happened...
The screen is blue and has a little red lock on the upper left hand side...
remote only works to turn it on...no other buttons work.
Help please!!!
Apr 01, 2008 | Insignia IS 20" TV040919 TV
DeLonghi CTO4003 4Slice Toaster Logo
100 people viewed this question
Top DeLonghi Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Oloyede Monsuru
Gerry Harvey
Gerry Harvey
Are you a DeLonghi Kitchen Appliances - Other Expert? Answer questions, earn points and help others
