Question about Hotpoint 24 in. DWF32P Free-standing Dishwasher
Aqurius fdw 60
When dishwasher is on it seems to finish its cycle then the 55 45 lights flash on preventing you from doing anything else with it . also some times it does not empty completly can u help
  • iggylfc Jun 17, 2008
    will make sure the filters are all clean and clrea thank you iggylfc
  • 108 Answers
Ensure that your filters are not blocked - these are inside the unit. remove the grey plastic filter and see if there any food or other items jammed in it.
Make sure there is nothing underneath the filter - if there is items of food (e.g seeds) may already be restricting the exit pump path.
Posted on Jun 17, 2008
Dishwasher wont finish any cycles
That blinking light is trying to tell you that there is something wrong with the dishwasher. You need to fix the problem or else that blinking light will come back. And the number of times it blinks (before it pauses and repeats) will tell you (or a technician) what is wrong. How many times does it blink?
Jul 04, 2014 | Kenmore Dishwashers
HOtpoint Fdw 60 goes straight to DEMO mode and refuses to do anything? Any idea?
Try resetting cycle-Push cycle select and cycle start together till you hear a long beep followed by three short beeps.this will cancel previous selection and allow a new program to be selected
Nov 10, 2011 | Hotpoint 24 in. FDW60 Free-standing...
I have a Hotpoint Aquarius FDW 60 dishwasher. Crockery was with greasy smear on it. Since then the drying does not appear to be working. Seems the drying element has malfunctioned, can we replace this...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
Check your heating element..
A bad heating element causes many problems in dishwashers…
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Sep 08, 2010 | Hotpoint Dishwashers
Eco and rapid cycle light flashing rapidly.wash cycle not finished. still has water in bottom of machine
had something jamming pump impeller which prevented machine pumping water out. The motor is connected by a bayonet fitting to the pumpand is easy to get at and clear obstruction.
Dec 17, 2009 | Ariston Technologies LL64WNA Built-in...
Hotpoint aquarius fdw60 tripping problem
I would agree with you. Everything you say here certainly points to a faulty heating element. The original is fitted with two factory fitted clips so you may need to go to your local garage and get two jubilee clips as they don't usually come with the new element.
Jun 01, 2009 | Hotpoint 24 in. FDW60 Free-standing...
FDW 60 lights 4 and 5 flashin.Select programme,m/c then bleeps 4 times and then lights 4 and 5 flas together and nothing else happens!Any ideas please?
Control panel which is a bit sensitive might need re-booting. Mine did the same and had a mind of its own, doing what it wanted, lights flashing all over the place, not completing the wash etc etc.
Switch off the machine and unplug from the mains. Leave for 10 minutes.
Plug back in, switch the machine on to your required programme and if ,like me, you are lucky, your machine should work again. If it happens again in the future you know what to do. Failing that go to the Hotpoint website, find the customer service number and ask if there is anything else you can do yourself to solve the problem, before paying for a service call. They are really helpful
May 27, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Our ls12 ev03 dishwasher won't turn on, every time it is switched on it says'I'm still drying' with it's flashing light evn when it has not been programmed to do anything
It could be that it was opened before it had finished its last cycle. When you switch it on again, it wants to finish. You could either leave it on until the drying light goes off, or force it to finish the cycle. I'm not familiar with that model, but on mine I have a Stop option on the dial. On the machine I had before, I had to press two buttons together to force the end of cycle. Worth a try. Good luck.
Jan 06, 2009 | Dishwashers
Dishwasher problem
My dishwasher Indesit DI67S will not run on the number 1 cycle. It will fill and then when that programme finishes it jumps straight to the drying cycle missing all the rinses out etc. If on the number 2 programme it goes all the way through but then doesn't dry. I've also noticed that the water doesn't seem to be heating up much and certainly isn't drying. Is this the element or something else? Once its reached the drying cycle the light for this just flashes then I have a job to try and reset the machine. It can take endless attempts. Will switching the machine off at the mains solve anything or is it the element?
Thankyou
Oct 09, 2007 | Indesit 24 in. DI67 Free-standing...
FDW 60 Float and Filter Clean problem
Blockage in internal pipework causing water not to circulate fast enough to stop switch activating. Regards Advisor
Aug 17, 2007 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint 24 in. DWF32P Free-standing Dishwasher Logo
146 people viewed this question
Top Hotpoint Dishwashers Experts
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
