The amp on my gigaware 2.1 multimedia speakers is not working. I just barely purchased the speakers, they worked for two songs and now there is absolutely no bass. HELP!! FYI: I am using them with my imac
SOURCE: RX-V2090 Bass Output Problem
A couple things to check on the no bass problem:
1) Make sure your center speaker is set for normal, not large.
2) Make sure your speakers wires are in phase (+ conn. to + and - conn. to -).
Posted on Dec 04, 2007
djnick989
  • 1067 Answers
SOURCE: BA745
yes bad bord so cheap on these u can kick bass out like u wanna best bet referb kilspsh on ebay 70 bucks bass on them rocks ok
Posted on Jan 16, 2008
zzedly
  • 300 Answers
SOURCE: Amp went into protect, but front speakers sound distorted too
If the amp still goes into protect mode, the easiest thing to do is disconnect the RCA cables from the amp and see if still goes into protect mode (after turning off/on). If it does, the issue lies in the amp or the wiring to/from the amp (most likely case). Check to make sure no speaker wires came loose and touched +12V or ground (car body). From the sound of it, my guess is something internal to the amp died and will need repair.
Posted on Mar 27, 2008
SOURCE: The bass speaker doesnt work
OK, Bose owners out there listen up and listen good. Here's the real scoop on 1.(getting access to the inside of most bose subwoofers, 2.( repairing said subwoofer.
Follow these steps in removing the cover of your subwoofer. Unscrew the two screws from the cover. (They are on the input/output side of the cover) Remove the two knobs (Bass and treble volume).
On the opposite side of the cover, (put those damn shoes back in the closet) there is a lockout tab that needs to be swung out, it moves 90 degrees in a counter-clockwise direction and is located under the center of the cover.
A small flat blade screwdriver works great for swinging this tab out and will be necessary for the next step (the screwdriver that is).
On the same side (opposite the input/output side) there are two small tabs near the edges of the cover, one on the right and it's counterpart on the left. If you look closely in the gap between the cover and the sub itself, you will see these 3/8" wide tabs near the edges and towards the top of the cover.
With the flat blade screwdriver, put the blade between the cover and on the tab and pull down. Then with your hand balled into a fist, gently hit that side of the cover towards the input/output side. the cover will move only slightly but the tab should remain depressed.
Do the same procedure on the opposite side of the cover and it will slide about a 1/2 to 3/4" towards the input/output side and can then be removed by pulling it straight up and off of the cabinet.
Yay! If you get this far without incident then you are ready to implement repairs. In the case of the AM15's, normally what happens is a resistor will open up and prevent the triac (turn-on device) from firing.
The fuse is on the underside of the PC board and this above mentioned resistor is a 100 ohm, surface mount "chip" resistor on the top side of the PC board. It will not appear to be bad but trust me, if the fuse is good and the sub will not turn on... replace it!
You don't have to use a chip resistor since as a consumer you may have a rough time finding one but a 1/8 watt or 1/4 watt resistor you can find at any Radio Shack will work just dandy in this application.
Cut the leads short and solder the two cut leads to the pads on the circuit board where the chip resistor is currently sitting. The chip resistor will be black, about 1/4" long, 1/8" wide and have "101" printed on it's surface. On some models they used two 200 ohm resistors in parallel but the result is the same. One 1/4w axial lead resistor will do just fine. Plug it up and give it a try. (Before you replace the cover).
Secondly, if the fuse is blown on a "Lifestyle" Bose subwoofer, contrary to popular belief, it blew for a reason. The speaker outputs and the subwoofer output devices are TDA7294 IC's with TIP142 and TIP147 Motorola transistors used as current supplements to these said output devices. If the fuse is blown and replacing it only results in another blown fuse then chances are good that one or more of these are blown. In some cases it's very easy to tell, the front of these IC's will be blown off and/or you will see burn marks on the board where they are mounted. These devices are located inside the amp portion of the subwoofer. (The black metal heatsink underneath the input/preamp PCB. As a consumer, if the fuse is blown, unless you are familiar with soldering techniques and troubleshooting electronics, leave this to the pro's. It isn't as easy as you might think and you can destroy the PCB in your attempts to repair it.
 This was from a Guru of Bose systems at ecoustics.com: Mark Burgess
Posted on May 11, 2008
  • 153 Answers
SOURCE: connecting 4 bass speakers to one amp?
If you have a 4 channel amp and 4 speakers and each speaker is connected to each of the 4 channels you are just fine.
A stereo amplifier has 2 channels, typically labeled left and right and each channel has an amplifier. A 4 channel amplifier has 4 amplifiers. With one speaker on each channel, there is one speaker on each amplifier. Audio amps are referred to as amps or amplifiers, although if they have more than one channel it would be more correct to call them something like 'multi-channel amplifier' or 'multi amplifier speaker driver'. Semantics.
Posted on Apr 29, 2009
My gigaware 2.1 multimedia speakers (16W) sub rumbles/rattles at low frequencies
You seem to have opened up your speakers already. So, I think you should use your creativity to displace the parts a little so that no contact takes place even at max volume.
Dec 02, 2013 | Gigaware 2.1-Channel Multimedia Speakers
Can you connect the speaker system to a TV?
if ur tv has the supported jack can do so
or else find a converter pin which is sufficient
Jan 21, 2013 | Gigaware 2.1-Channel Multimedia Speakers
98 Durango Rear Speakers not working
look under back seat for preamp
Jun 01, 2012 | Cars & Trucks
I just purchased songs and they wont play on my pc. oher music still plays.
You may need to move them from the Purchased area in iTunes into your iTunes Library. Try the following:
1. Open iTunes.
2. Select the Purchased icon located under Store.
3. Press either Ctrl A (on a PC) or Command A (on a Mac) to select all the songs within this window. Alternatively you can
  • Depress you Shift key whilst you click each song. OR
  • Depress your Ctrl key (PC) or Command key (Mac) whilst you click each song.
4. When the songs are selected, use your mouse to Click & Drag the selected items into your iTunes library or a folder within your library.
I hope this solves your problem. Regards,
Feb 10, 2010 | Apple iTunes
Amp Turns off after 30 seconds of song play
Since the unit recovers once it has powered down. I suspect that the internal protection circuit is kicking in. Check the wiring and be sure that there are no crossed wires anywhere. These amps are designed to work with 2 ohm loads and can take a direct short for a short period of time. If the wires appear ok, measure the speakers with an ohm meter. If the speakers are 4 ohm rated, they should measure just under 3 ohms with the meter, If they measure less than 2 ohms, there is a problem with the speakers.
Also, does the amp shutdown regardless of the volume level or just when played loud?
Thanks,
Dan
Apr 15, 2009 | Kenwood 1000W Class D Bridgeable Mono...
Docked itouch emits song, but nothing through logitech speakers
Talked to both Apple and Logitech, and uploaded newest firmware ( had assumed since this was a recent purchase it had same), presto, it works.
Jan 29, 2009 | Apple iPod touch
Onkyo just shuts off...
check whether any loose connection in the board of the unit.
Aug 15, 2008 | Onkyo TX-SR605 Receiver
55 people viewed this question
 Grubhead
Grubhead
