Question about Samsung Microwave Ovens
How do you defrost something on the samsung timesavers 1000w microwave?
4 Suggested Answers
  • 686 Answers
SOURCE: user manual
CHECKTHE FUSE :)))
Posted on Apr 18, 2009
MicrowaveSvc
  • 9047 Answers
SOURCE: microwave will no longer heat. Model #MA-1000W
So we can help you, please post a NEW question, and please include your model number MA-1000Was well as the answers to these questions:
When you try to microwave are the inside light, internal cooling fan and turntable all working?
Is there any unusual noise or is it louder or quieter than normal?
A loud buzz, hum, or groan is usually a shorted high voltage rectifier diode, but a sound like gurgling into an empty coffee mug is one symptom of a failed magnetron, and yet the mag can be bad without that sound.
We have a sound clip of what a microwave should sound like when the cooling fan and high voltage section are working.
Posted on Oct 11, 2009
caroldon
  • 17129 Answers
SOURCE: samsung timesaver 1000w microwave turntable has stopped turning
Possible that the belt has failed, the motor has failed or the fault is the drive in the board. You need to start by checking the belt and motor.
click this link: Motor replacement
Posted on Apr 10, 2013
I can't get started with my new 32l microwave
Have you read the owner's manual that came with your new 32l microwave oven. It tells you how to program it.
Jun 16, 2017 | Microwave Ovens
Message on samsung timesaver microwave 1000w 5E what does this mean?
The code indicates a possible shorted membrane switch. Unplug the unit for at least 30 minutes to see if the code clears. If not, you might actually have a shorted switch.
Jan 28, 2017 | Samsung Microwave Ovens
I have a Timesaver 1000w Samsung microwave. Just started to get error messages of p2 and p1 as I have lost the manual a long time ago could you explain what these codes mean.
There are no user serviceable part on a microwave and the screws holding the case are security screws. You are better off taking it for service.
There are fault codes here, but no P codes.
Microwave Fault Codes
Jan 20, 2016 | Samsung Microwave Ovens
Samsung timesaver microwave
follow this steps and fix it. God bless you
  1. Check the power diodeThis electronic component is responsible for transmitting current in one direction. If the diode becomes defective it will cause your microwave to not heat. Test the diode and replace it if necessary.
  2. High voltage capacitorResponsible for storing electricity, this part is a key component in any microwave. Remove, discharge, and test the capacitor to determine if it requires replacement.
  3. Damaged magnetronResponsible for generating waves and producing heat. When your microwave is no longer heating properly, replacement will be required.
  4. Thermal CutoffsExamine the thermal cutoffs on both the magnetron and the oven itself. Take off one of the leads and using a volt-ohm meter on RX1, check the terminals. If you get a result other than zero, replace the thermal cutoffs.
Read more: http://www.appliancepartspros.com/repair-help/microwave-repair-help.html#2#ixzz2YxACIG9d
Jul 12, 2013 | Samsung MC5694 Microwave Oven
Samsung timesaver 1000w microwave turntable has stopped turning
Apr 10, 2013 | Microwave Ovens
Will not power on
there is a fuse inside your microwave that may have blown out. most people throw out there microwaves and normally just the fuse inside.
Jul 07, 2012 | Oster 1.4 Cu. Ft. 1000w Stainless Steel...
My Model is Samsung timesaver 1000 W, M1934NCE. Made in malaysia, September 2002. No power at all. Completly dead. Please help me to fix this.
possible solution
checkpower unit like fuse
check transformer which gives different supply to various part of oven
May 15, 2012 | Samsung Microwave Ovens
Have a samsung timesaver 850w it has just come up with an error message either 5 E or S E have tried turning it off and on but still cmes up. cant find my booklet
The letters S E indicates "systems error" usually caused by a short in the keypad membrane, the only solution is to have the keypad replaced to bring it back to normal.
Apr 07, 2011 | Microwave Ovens
User manual
CHECKTHE FUSE :)))
Apr 18, 2009 | Microwave Ovens
Microwave Ovens Logo
41 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Henry  Thomas
Henry Thomas
Devabhakthuni...
Devabhakthuni...
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
