Question about Kenmore Elite 45986 Front Load Washer
Control lock is on and i cannot get it to disarm. even unplugged washer. no luck.
  • Kenmore Master
  • 1,902 Answers
Hello
You can unlock the control by resetting it, to reset try pressing the DRAIN/SPIN button and hold it for 15 seconds. This will resolve the problem...please get back to me if you have any other questions.
Kevin
Posted on Nov 10, 2010
Testimonial: "i have never tried this before! unbelievable! what a remarkable service. thank you so very much! it worked! all resolved in less than one minute!!"
It displays 'control lock' with red light
Here are a few Different models as i do not know yours.
How to Unlock the Control on Whirlpool Duet eHow
Maytag - To unlock the controls, press and hold the CYCLE END SIGNAL for 3 deliberate seconds or until the control lock light goes out. If the control locked light will not turn off, I recommend unplugging the washer for 5 minutes. Plug the unit back in and see if the controls will respond. If not, I recommend calling a service technician to diagnose and repair the washer. You could have a failed control console or a bad electronic control board in the washer.
Kemmore- Unplug for 10 minutes.
GE washer - Make sure that the control for the washer is not locked. If it is, press and hold the LOCK button for 3 deliberate seconds (or until the control unlocks).
There is not another way to reset the control board other than completely unplugging the washer as you have been doing. Since the display light up and works, the washer apparently has electrical power supplied to the control board and control console. You could have a failure in the console that is preventing the start button from working. A failed control board or a problem with the door switch could also prevent the washer from starting. Make sure that the washer door is firmly closed.
If the washer will not start after checking the control lock and the door, I recommend calling a service technician to diagnose and repair the washer.
Good luck More info would be helpful. Make and model. Is always a plus.
Oct 02, 2014 | Washing Machines
How to correct control locked will not go off on whirlpool ghw9150 washer
While the machine is 'on' press & hold the "end of cycle" button for 3 seconds, or till the lock light goes off. This is on the far left or right of the machine's panel. Good luck! Pl rate me.
Sep 01, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Control lock light is on and nothing else will respond, and this continues even after unplugging/replugging. help!
Hello & Welcome to FixYa
This is a common issue with Whirlpool Duet washer however; your whirlpool duet washer needs a reset to resolve the control lock problem. Press and hold the END OF CYCLE /CYCLE SIGNAL button for 15 seconds to reset the control. Please get back to me if you have any other questions.
Kevin
Jul 31, 2011 | Maytag EPIC MFW9700S Front Load Washer
Dorr won't recognize that is is locked even after
lock assembly could be bad..or main control might be bad...rechek all connections...good luck...
Apr 03, 2010 | Frigidaire Affinity ATF7000ES Front Load...
It said contorls locked and will not work. I tried to unplug and reset no luck.. any suggestions please!!!!!
The Control Lock is a designed safety feature that enables the us to lock the control panel to prevent small children from manipulating the controls and accidentally starting the appliance.
The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Mar 11, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Control locked. How do I unlock it?
Press and hold the End of Cycle button for 3 seconds or until the Control Locked indicator turns off to unlock the control. The End of Cycle button is located at the extreme right of the console. Unplug the machine for at least 15 minutes to reset the central control unit if the control cannot be unlocked using the End of Cycle button. Let us know if the control cannot be unlocked even after the machine is unplugged.
Mar 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I was doing a load of laundry and the washer "froze" i tried to cancel the load but it wont stop.... i ended up unpluging it and even when i plugged it back in its still stuck!!!
Locking controls
The Control Lock prevents unintended use of the washer. You
can also use the control lock feature to prevent unintended cycle
or option changes during a cycle. When CONTROL LOCKED is
lit, all buttons are disabled. You can lock the washer while it is
operating.
To lock the controls
Select and hold END OF CYCLE SIGNAL for 3 seconds.
The CONTROL LOCKED status light glows.
Select and hold END OF CYCLE SIGNAL for 3 seconds until the
CONTROL LOCKED Status light turns off.
Nov 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore He2Plus Washer: Controls Locked button lites up & beeps
plug it back in and there should be a buttong somwhere toward the corner and in small lettering"un-lock/lock" hold that button for 5 secs and see if it un-locks the board. if it dont the your board might be bad....hopefully this helps
Jul 30, 2009 | Washing Machines
Control locked light is on.
The procedure for clearing this is to press and hold the "end of cycle" button for three seconds. It should be all the way on the right of the panel. Let's try this first. before we look at anything else. Hope this helps and let me know what happened. Good luck.
Jul 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
303 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
