Question about Acer Aspire One AOA110 Linpus Lins Lite Version Notebook
My Acer 110 Linpus is not starting properly. I saw the screen with "Press F2" put after that the screen turn grey, and the arrow is seen in the middle of the screen. I can move the arrow, but nothing else happens. I have something in my memory that I would like to keep... I asked Acer support and they mean that I should use a Ubuntu version on a memory stick. I haven't tryed that. After a while I tryed to turn D2D off, and now ther isn't aything of the screen and no arrow. It's not even possible to turn it off. What can I do?
  • 2961 Answers
SOURCE: acer aspire 5101 orbicam
just double check that you havent loaded the Bison camera driver or the Vista driver as your system doesnt list the orbicam as being fitted, but you obviously have so go to the link below and download the logitech driver, as this is what i used
Posted on Sep 02, 2007
  • 209 Answers
SOURCE: How to reset the bios of the Acer 5920?
you can reset the bios setting by removing the battery, you can also remove the jumper pin from the motherboard from pin1-2 to pin3-4 wait for 10sec then return to pin1-2
Posted on Jan 14, 2008
  • 210 Answers
SOURCE: Acer Aspire 3000 wont load past acer splash screen
Thanks for the response, turn it off and remove the battery/power supply, now take one of the cards out, now put the battery/power supply back in and switch it on, if it still does not work, do the same again but put the other card back in and take the other one out, now switch on.
Let me know how it goes.
Posted on Jun 14, 2008
  • 476 Answers
My understanding of the Acer 3000 set up....NOT A NuBEE
=========== VERY IMPORTANT ==================== Before you remove any compnents - Remove Power/Battery.
I have found best results with a Default Factory Settings reinstall from eManager ,to be quite reliable and their system is reinstalled within minutes.
Any missing components ie sound, vga, modem, usb,etc can be located on the recovery disks,also another important step is to do SP2 Windows Updates to give the devices the correct functionallity otherwise expecting them to function correctly without giving them the right tools and instructions would be premature and wasting your own time trying to make it work only to do your head-in in the process.
Other Acer Issues....
Replace when they die or use AC power pack.
Sorry not upgradable for video out,dedicated/shared memory type.
mean a lengthy reinstall with recovery disks or reinstall OS from a separate machine then when Operating System is reloaded replace into Acer Hard Drive Bay now ready for Acer Reinstall.
If its important === Leave it to the PRO's
RAM / Memory.
Ram slots x 2 . MAX 2GB = 1GB + 1GB
Readily available in many sizes 128mb,,256mb,512mb,1GB and many brands,Kingston,Transcend,etc....
always put identical size ram ie 256mb+256mb... re sometimes the slowest ram is maximum speed so making them identical give double speed proformance instead of half 256mb + 1gb registers 1.256mb but runs at 512mb.
WIRELESS/Axis Points & Blue Tooth Devices.
Works well if set up has correct Axis Point to Device Security Protocols Established and properly Encrypted too.
There are some clever people out there who can hack your wireless connections so I recommend a hard wired Cat 5e @ 100MBPS or Cat 6 @1GPS,(I think thats right)lol.
A closed network is more secure the an open one,
LCD Screen Replacements/Inverters
Can be done.Mostly Matt Finish or Ultra Bright Lcds.
Replaceable and upgradable,
Note from The Author.
I have only touched briefly on the most common excerises and would like everyone to underestand some problems not covered here may require different solutions for the individuals specific problem/s.
Seek advise from trusted sources.
If in doubt try,
or email me,lol
Thanks for reading my thoughts,I hope this helps the understandings and importance of these basic steps
Posted on Jul 10, 2008
  • 5 Answers
If you have a grey rectangle where ur cam should be. Especially after a fresh install plus all the drivers. although Then here's your solution :)
Go into device manager and delete the USB controller. Then reboot. When it says new hardware found let it automatically install it. Et voila, working cam :)
Complements of TruthSeeker 69
Posted on Jan 01, 2009
How do I turn on my wifi switch on my Asus F555l
Usually hold the [ fn ] key and the [ f2 ] together or just the [ f2 ] key depending on how your "Hotkeys" are setup. If you've had a fresh install of windows or the drivers aren't working properly you can do it manually by going into the bios like so:
Step 1
Turn on your Asus Netbook. If your netbook is already on, click the "Start" button, click the arrow next to the "Shut Down" button and then click "Restart."
Step 2
Wait for the Asus Netbook BIOS screen to appear, then press the "F2" key.
Step 3
Press the "Right" arrow to scroll over to the "Advanced" tab.
Step 4
Press the "Down" arrow until you reach the "Onboard Devices Configuration" option. Press the "Enter" key.
Step 5
Press the "Down" arrow to "Onboard WLAN" then press the "Enter" key.
Step 6
If the "Disabled" option is highlighted, press the "Up" arrow to highlight the "Enabled" option, then press the "Enter" key.
Step 7
Press the "F10" key. Press the "Enter" key to save your changes and exit the BIOS. Note: If you are missing your hotkey drivers you can find them here under the ATK section (Use the latest version)
Feb 26, 2015 | ASUS Computers & Internet
Asus Eee PC 1005HA wontl load OS
what key do you see during the boot up process
you should see a certain key it will be very quick you might have to restart a few times to get a good look
try pressing the delete key
hope it helps
Apr 09, 2012 | ASUS Eee PC 1000HE Netbook
Hi there! i just bought a new acer aspire m5641 (the rep told me that the computer doesnt come with an OS but when i booted it, linpus is installed) on my CPU there is a sticker that states...
Stop: 0x0000007B error code refers to memory issues
You need make some changes in your computer before installing XP
1. On start up, press F2 to enter BIOS 2. Expand the "Drives" section 3. Go to "SATA Operation" 4. Change this from "RAID Auto/AHCI" to "RAID Auto/ATA"
You will be able to install XP now
Jun 30, 2011 | Acer Aspire M5641 PC Desktop
On by Aspire One with Linpus Linux Lite v1.0.15.E, I am connected to my network but cannot connect to the browser. I get a message: "Firefox is already running, but is not responding; To open a new...
This could happen after your netbook crashed or turned off while Firefox was still running. When Firefox is running, it puts a file called "parent.lock" in your Firefox profile directory. If you delete that file, Firefox should start properly again.
I'm not sure exacly where the profile directory is on your system (I currently don't use Linpus Lite anymore), but it should be somewhere in your home directory in .firefox or .mozilla. Maybe this page could help you find it.
Feb 26, 2011 | Acer Aspire One PC Notebook
Whenever i try to turn on my Acer Aspire One it says: """ Intel UNDI, PXE-2.1 (build 082) Copyright (c) 1997-2000 Intel Corporation For Atheros PCIE Ethernet Controller...
The problem you are mention is related to the boot order of your computer. You computer is trying to boot from the network wireless card instead of the primary hard drive. To solve this, you will have to enter the BIOS and change the boot order.
With the laptop turned off, switch it on and when you see the ACER logo press the F2 key. You will enter the BIOS. Now press the right arrow key in the directional pad until you arrive at the "BOOT" tab, you will see something like this:
Now change pressing F5/F6 the boot order, putting the hard drive at the top. Press F10, then "Y" and "enter". The laptop will reboot and the message should disappear.
If it doesn't disappear you will have a failure on the hard drive, which you will have to replace by a new one.
Feb 08, 2011 | Acer Aspire 7720 Notebook
I have an acer aspire 9300-5317. She has been a great computer but I recently have been having problems. I am looking to format and reinstall but for some reason I get no acer slash and therefore no bios...
you ca try few steps first try with F10 or when you turn on press tab to show psot screen or physically you should reset coms by removing and fixing your coms battery try and get back to us!!!!!
Nov 27, 2010 | Acer Computers & Internet
Turn it on and it explain about a inconvience start up menu press f2 and something about start up menu in safe mode or start safe mode networing but then it goes to the xp loading screen n just...
Boot priority is disabled and enable in bios screen .you have to press F2 whilst booting to get to this configurable facility For some machines its F11,F8,or evenF9
Here you should be able to reset default settings also please use tab and arrow keys to navigate through bios and dont make any serious changes untill you are sure of the outcome
Sep 05, 2010 | Acer Aspire One Netbook 8.9" Notebook
When are turn on my laptop.. It shows only windows screen with "press f2 to change set up" and "press f12 to change your boot order" at the bottom of the screen. Later, it turns out to a blank screen.
Hi, you haven't said what operating system you have, but here are two options. Restore windows with your windows CD. Or you can boot into safe mode by pressing the Del or ESC key during initial boot, select start in safe mode, from where you can reset your operating system to an earlier time before the problem. Both of these will not loose any saved files.
Aug 07, 2010 | Acer Aspire One AOA110 Linpus Lins Lite...
Cant get into the network center on my acer aspire 1 ,
If this is an aspire One with linpus lite linux,
The network center disappearing is an issue with the linux update server that seems to corrupt the OS.
The solution unfortunately is to reload the OS from the recovery disk.
The aspire ONE does not come with an ODD so you will need to use the disk on a unit that has an ODD to make the recovery USB flash drive.
You will need a USB flash drive that has at least 2GB of storage, a computer with an ODD, and the linpus recovery disk that came ywith your unit.
1. Boot to the linpus disk, one of the options should be to make a recovery USB drive, make sure that no important data is on this USB drive as it WILL be formatted and erased.
2. Follow the on-screen instructions and then insert the recovery flash drive in to the USB slot of the Aspire ONE.
3. Re-start the Aspire ONE and press F2 to go in to setup.
4. Change the boot order to boot from "USB HDD" and press F10 to save and exit.
5. Unit will reboot and recovery will start.
Jun 26, 2009 | Acer Aspire One PC Notebook
Notebook will not start up
first u put u r note pad in water then eashad so ta\hat u get complete solution ok
May 04, 2009 | Acer Aspire 9410 Notebook
Acer Aspire One AOA110 Linpus Lins Lite Version Notebook Logo
57 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
