Question about Weber Q100 Grill
Weber Q100 burner won't light all the way around only the 2 sides and the front the back won't light at all.
  • 2976 Answers
SOURCE: Burner won't light
Clean everything up with a wire brush. The tiniest bit of debris in the ignitor area will prevent a spark.
Posted on Mar 14, 2009
gcken
  • 140 Answers
SOURCE: Weber - Igniting the three grill burners (front, middle, rear)
it need a clean
Posted on Apr 28, 2009
  • 233 Answers
SOURCE: gas flowing to burners 1 and 2 but not 3
there could be debris in the carryover tube..(the open channelled pipe that connects the three burners together) alignment is also critical,
Posted on Jul 12, 2009
cadesertmax
  • 274 Answers
SOURCE: Rear Burner is hotter than the front burner on my Weber Grill
Since the grill is 15 years old, it is probably time to rebuild it. Replace both burners and anything else that is not working properly
Posted on Jan 10, 2010
  • 332 Answers
SOURCE: my weber genesis wont stay lit. i can light the
The new style2_bing.gif OPD valves have a small brass ring located in the female fitting on the LP tank. Over time this ring can work loose and then it does not allow the male fitting to fully depress the OPD valve thus reducing your gas flow
Using a small flat bladed screw driver tighten the small brass ring This should solve your problem
IF not you might want to remove the cap (white) on your regulator and try slowly adjusting the regulator, make small adjustments and try the BBQ My Weber if I set the front and back burners to MED I get right at 350 degrees in 60 degree outdoor temps. Adjusting the regulator will take some time to get it right but If it is not your tank it is most likely your regulator out of adjustment
Posted on Mar 31, 2010
Had trouble lighting weber Q, replaced regulator still will not light with igniter button, had plenty of spark . It will light manually with grill lighter but will have a small back blow of flames. Tired...
Are you using the valve-regulator or a conversion hose to a 20lb cylinder? a gas problem is different from an ignition problem. If an ignition issue the piezo module on that model has to have a good ground connection because cast aluminum will not ground at the electrode. make sure wires are tight and secure. Also check the "gap" at the tip of the electrode and adjust for strong blue spark. Most barbecues need the electrode gap adjusted when first installed. if an older model dirt and grease will interrupt the spark so make sure the tip of the electrode and area around it is clean -- burner and collector.
Nov 02, 2013 | Weber Q100 Grill
Burner won't light all the way around
Try reaming out the holes that aren't lighting with a nail.
Oct 07, 2013 | Weber Q100 Grill
Cant get gas to weber q100 grill
reg could be stuck down on seating or blockage in gas line , turn off gas remove line open burners , close burners reconnect gasline turn gas back on slowly see if this works .
Mar 17, 2012 | Weber Q100 Grill
Rattling noise coming from gas injector. Tendency to flash back towards the gas injector when on full.
check burners are not blocked, also air gas mix could be wrong you should be able to adjust the mix on the burner , and see if burner is not split this can also cause flash back .
Aug 31, 2011 | Weber Q100 Grill
Q 220 Burner tube is not initially igniting all the way around and then some ports are going out. New gas tank so plenty of gas
The ports are probably blocked with grease. This happened to me - I removed the burner tube and used a steel bristle brush to clean the holes - the clue is to use the brush from front to back/back to front, not from side to side - side to side just moves the grease from one hole to the next. Worked like a charm, thought I would have to buy new burners.
May 29, 2011 | Weber Q Grill
My grill is a Genesis Silver B. The front burner ignites but the middle and back burner will not. I took off the tubes and can't see where anything is plugged or restricted. I can hear gas through the...
I believe your model Weber has a Cross Over Tube Burner , on the left side of the interior of the grill, just above the middle and back burner. If that's clogged or needs replacing, that's more than likely the culprit. As, it won't carry gas to those two burners. It is easily replaceable, if necessary.
In case you have misplaced your Owners Manual, I have included a link to it. You can download and print it for future reference.
http://www.weber.com/help/manuals/pdf_files/Genesis_SilverB_LP_Owners_Guide_55008_03_21_01.pdf
Apr 09, 2011 | Weber Genesis Silver B Grill
Front Burners very low back burners not working
Front 2 burners light properly but back burner does not light. Checked cleaned spider guards, even removed the burner making certain it was clean. Reassembled the back burner but it still does not light.
Jun 23, 2010 | Weber Genesis Gold B Grill
Back burner won't light on my Weber Genesis Silver A Gas Grill
Only front burner lights (out of three) and it only has flame comming out of half of the tube.
Apr 04, 2010 | Weber Genesis Silver A Grill
Weber Q100 Grill Logo
291 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Dan Webster
Dan Webster
Are you a Weber Grilling Expert? Answer questions, earn points and help others
