Question about KitchenAid Architect KEBS207S Electric Double Oven
Kitchenaid double oven kebs207 lower door will not unlock after clean. Ample time for cool has been allowed, power shut off/on after 15 min, clean, cancel/off buttons will not respond or any buttons will not respond.
SOURCE: Cleaning Inside Glass Oven Door of KitchenAid KEMC308KSSO
To dismantle the kitchenaid pro line oven door: there is a lever over the hinges that attach a door to the oven. The lever is right on top of the hinge. Pull the lever up. When that lever is in the up position, you can pull the door out.
Posted on Aug 13, 2008
  • 6 Answers
SOURCE: KitchenAid Superba double oven: can't set clock.
If you turn the center knob (marked 'time') to the right, it sets the timer; but if you turn it sufficiently far to the left, it goes into clock set mode. When you get to the correct time, press start.
Posted on Jun 30, 2009
SOURCE: We put this unit on self clean and now it wont turn on nor open.
I had the same problem with a Superba wall oven. In my case, the bracket mount for the door lock warped due to the heat of the self clean cycle. We were able to open the door by inserting a coat hanger into the slight opening at the top of the door and sliding the lock lever to the left. It was a pretty easy self-repair - 1) turn off breaker 2) slide oven out 2-3" 3) remove oven front trim pieces 4) remove screws that mount control panel 5) this should give you access to the door lock mechanism.
good luck
Posted on Feb 21, 2010
Testimonial: "Thanks"
SOURCE: wattage for double oven
im getting a indesit fid201 double oven does it have to be hard wired or can it go on a 13amp plug
Posted on Mar 17, 2010
  • 13 Answers
SOURCE: I have a double KitchenAid superba built-in oven,
there should be separate fuses for the top and bottom oven. check all of them if this is not the problem maybe your burner in the bottom oven is burnt.
Posted on Dec 09, 2010
How do I unlock my Competence oven door?
Unplug the unit or shut off the circuit breaker for 5 minutes. Plug the unit back in or turn on the circuit breaker. Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool.
Dec 04, 2017 | Ovens
Replace light in KEMC378KSS microwave
The oven lights are 12-volt, 5-watt maximum halogen bulbs. They
will come on when the oven door is opened. On double oven
models, both upper and lower lights will come on when either
door is opened. The oven lights will not work during the Self-
Cleaning cycle. When the oven door is closed, press OVEN
LIGHT to turn them on or off.
To Replace:
Before replacing, make sure the oven is off and cool.
1. Disconnect power.
2. Remove glass light cover by grasping the front edge and
pulling away from oven
3. Remove bulb from socket.
4. Replace bulb, replace bulb cover by snapping back into wall.
5. Reconnect power.
Feb 04, 2013 | KitchenAid KEMC378KSS Electric Double Oven
F5E1 or FSE1 error code DOOR LOCKED LATCH NOT OPERATING
On this double oven, each door has it's own latch mechanism that consists of a motor, a position switch, and the door switch used to activate the cavity lights. Because the error indicated a latch failure (and the bottom door was locked), Start by cycling the power to the unit. Each time the power is removed and then applied to these ovens, both latches will lock then unlock the doors to ensure they are in the home open position. By doing so, you might be able to get the bottom oven door opened allowing me access to the latch assembly. With the latch removed, I try to begin a clean cycle so you could watch the motor operate and you will probably find that it will start to turn, but never would rotate enough to lock the door. Since the position switch was not actuated at the end of the motor operation, the F5 E1 error was again displayed. Replace the motor assembly
E
Nov 23, 2011 | KitchenAid Architect Series KEMC308KSS...
I used the self-cleaning feature and now my oven will not turn back on.
Their is a high limit thermostat that has tripped,on older model and on some newer models it has a red button on it that can be pushed in to reset it.Other times once it goes out it must be replaced.
For the upper oven its behind the control panel,for the lower its behind the grill between upper and lower oven
I hope this helps you to understand why your oven wont heat,
Gene
Aug 05, 2011 | KitchenAid Architect KEBS207S Electric...
No power on stove after using self clean oven door is locked and cant be open is there a braker swith somewhere
A self cleaning oven that won't open after the self cleaning cycle is usually the oven has not had time to cool down from the high temperatures of cleaning. You should wait at least an hour to open it. You can also try to unplug the unit or turn of the breaker to the over for at least five minutes. You will then have to reset the clock and then try to move the door lock. If that does not work, you can set the self clean cycle again for but only allow it to work for 15 minutes, then cancel the cycle and let the oven cool and then again try to move the door lock or open the door If that does not work, then the lock will have to be accessed and moved manually to open the door
Some ovens need the door to be manually unlatched before the controls are set to the off position before they can be unlocked.
Mar 07, 2011 | KitchenAid Ovens
My oven display has a error display of E5F7,oven too hot.. The doors will not open. They are locked in the self-cleaning mode. How can I open the doors or can I do something to override or reset the the...
This problem is caused by defective material in the core
of the solenoid on the door latch. The solenoid works
properly at normal temperatures, and at the beginning of
a self-clean cycle. However, when heated, the plastic
core binds the metal plunger, and will not allow it to unlock
at the end of a cycle. Once cooled, the solenoid will
again work properly. When a technician inspects the
solenoid while it is cool, it will function normally.
SOLUTION: Replace the solenoid with service solenoid #4452224.
Oven repair in Mission Viejo, CA
Appliance repair in Mission Viejo and Orange County, CA
Jan 26, 2011 | KitchenAid KEBC208 Electric Double Oven
After using self cleaning feature...oven door locks up...4th time this has happened...kitchenaid says "no known issues with your unit or the problem you reported...can you halp
Hello - we have had this same issue a number of times as well. Do you lose all power on the unit too? We do - have discovered that using the self-cleaning isn't really a good idea with these ovens. The ovens aren't really made to heat to such high heats that are used in the cleaning cycle and during that last hour of cleaning it hits it highest peak - and it blows it's fuses. We recently blew 2 fuses at the same time, locking both doors (Double oven) and knocking out the power for the entire unit. Our repair man said that the average on wall ovens is anywhere between 6 - 12 cleanings before you will blow the same fuses and the whole cycle starts all over again. Our expense was $350. So, self-cleaning now means elbow grease around this house. How this information was a bit helpful for you.
Jul 02, 2010 | KitchenAid KEBC208 Electric Double Oven
I cannot unlock my door after self cleaning, it has been several days i pushed the 9 and unlock key but it will not open.
Unplug the unit or shut off the circuit breaker for 5 minutes. Plug the unit back in or turn on the circuit breaker. Set the clock and gently try moving the door lock lever (is so equipped) or opening the door.
or
Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever (is so equipped) or opening the door.
If these procedures fail to correct the condition, the lock must usually be accessed and moved manually to open the door.
Some model ovens require the oven door to be manually unlatched before the controls are returned to the OFF position or else the door may not be able to be unlocked. Check the owner's manual for proper operating procedures.
Feb 23, 2010 | GE Profile JT952 Electric Double Oven
Oven door is locked and won't open
oven door locked during cleaning then would not unlock after cooling
Jan 19, 2010 | GE JKP86 Electric Double Oven
I need to get my oven unlocked. The cleaning cycle went haywire
or
Oct 25, 2009 | Whirlpool RBD305PD Electric Double Oven
KitchenAid Architect KEBS207S Electric Double Oven Logo
143 people viewed this question
Top KitchenAid Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
