Question about Canon - SUPER G3 FAX BOARD-T1 (0450B002AA)
Says load paper recv'd in memory
Hi, My fax, which usually works well, is telling me it has several faxes in its memory and that I should load paper. However, there is paper in the feeder. Any suggestions?
Thank you,
Stephanie
  • 2 more comments
  • pegaron Jun 25, 2008
    Same exact problem. Need to print previously recv'd fax. No paper when fax came in.
  • lvidra Aug 29, 2008
    We have the same problem, I filled the drawer and it printed the fax but when a new fax come in it did the same thing, put it in memory and printed a RX Report that said INCOMPLETE RECEPTION. I pulled the paper tray out and then put it back and now it took 2 or 3 minutes before it printed what was in memory and started the problem over. I swaped it out with another machine for now.
  • Anonymous Sep 08, 2008
    I tried pushing the "Reset" button and the Start button after loading new paper in the machine. It is not retrieving and printing the faxes.
  • Anonymous Nov 12, 2008
    Had Same problem. Held stopped button for seconds and this kicked the fax into life!
I unplugged mine for a minute or so and then plugged it back in and it printed the fax in memory.
Posted on Nov 19, 2008
I had same problem. I put in a big bunch of paper and then took out about half of it and it suddenly worked. Also try opening the lid and then closing.
Posted on Jul 11, 2008
The alarm keeps flashing and the message says there is a paper jam. I cannot find a paper jam, but the fax cannot retrieve items in memory either.
Hi;
  1. Remove the cartridge look inside is there any paper rmove it carefully
  2. remove the paper from cassette
  3. load the paper again
Aug 10, 2010 | Canon CFX-L4000 Plain Paper Laser Fax
I received fax however the ink is so weak that it is not able to read. I am going to replace the ink. But is there s way I can reprint the fax
Hello. yes your fax machine has a memory and it will retain the last several faxes for you. Your manual will tell you how to recall that fax. If you do not have the manual go to Sharp.com where you can download it.
Apr 14, 2010 | Sharp UX B700 Plain Paper Inkjet Fax
My Panasonic Fax machine KX FHD331 is not receiving faxes ( it is on automatic) however, it is saying "memory full" and I cannot print what is in memory.
Make sure there is no additional error messages on the screen - they usually show in a sequence one after another - maybe paper not loaded correctly,or machine is jammed or out of thermal film.
Oct 03, 2009 | Panasonic KX-FHD331 Plain Paper Thermal...
How do you get a fax from memory
May 19, 2009 | Canon FAXPHONE L80 Laser
Fax machine will not recv faxes will copy, did have it on tad
Check the phone line with a regular phone.
Make sure phone cord is plugged into the LINE port of the fax machine.
Nov 26, 2008 | Brother IntelliFAX 1270E Plain Paper Fax
CANON FAX MODEL L220
Hi Greg.
Press the red STOP button.After loading paper.
Nov 07, 2008 | Office Equipment & Supplies
I get a load paper message when paper is loaded
Probaply some paper or obstackles stuck at PE (paper empty sensor) and that could be hard to fix it cuz you may need to pull apart the printer. However, if it is 6 monthsold, warranty covers this problem.
Feb 08, 2008 | Brother MFC-7820N Laser Printer
Problems receiving faxes in memory
Just had the same trouble. I loaded paper. Tried more paper, tried less paper. No luck. Finally in deparation and trying "everything" I could think of, I pressed "stop/reset" before pressing "start/copy" and now it's working. Very frustrating!
Aug 30, 2007 | Canon FAXPHONE L80 Laser
No receiving fax
Make sure there is paper loaded and there is not a jam any where in the machine. Also check you r receiving settings
Jun 05, 2007 | Samsung SF-3100 Plain Paper Inkjet Fax
623 people viewed this question
old marine
old marine
