Question about Bosch SHU5315UC Dishwasher
Letter F appears on screen, and dishwasher does not start. Sounds like pump runs for a bit then stops. Door is closed. What is wrong?.
  • 4,323 Answers
Hi
Error code F indicates that dishwasher control has detected a fault with dishwasher filling. This is due to faulty water inlet valve. Please check for clogged water inlet valve. Water inlet valve part#35
You can buy it from this link---
Bosch SHU531 water inlet valve
Hope this helps... Please post back if you need more information
Daniel
Posted on Nov 10, 2010
Electrolux dishwasher won't run through a cycle?
So it would be desirable to write the ERROR appeared in
Dado
Aug 02, 2014 | Electrolux 24 " White Built-In Dishwasher...
Superba 8524570
Is there something stuck inside, underneath, being turned along with the motor? burning smell usually means something got caught and the belt snapped. Not expensive and don't know if it's an easy DYI. Shouldn't cost too much to have it repaired or you can google the brand and model and the word belt, see what you find.
Mar 01, 2014 | KitchenAid Dishwashers
Doesn't close tight enough to start
It sounds like your door-closed sensor (a microswitch) is out-of-adjustment. If you can locate this sensor, try gluing a tiny piece of plastic or wood to it. This will do the same thing as pushing really ******* the door and allow your dishwasher to operate normally.
Dec 26, 2017 | Bosch SHE5AL02UC Builtin Dishwasher
Bosch dishwasher runs w/door open. Wont stop pumping water out
That was exactly my issue-I've tilted it 45d, emptied the tray and it works!
May 25, 2009 | Bosch Integra® 500 SHX46A0 Dishwasher
Bosch SHX46A (6 years old) Selected regular cycle, pressed On and closed door. Cycle did not start normally. Pump runs, but no water is coming into the DW. I confirmed the water supply line is turned on....
From your description, I doubt that the problem is door latch is the cause.
The first thing that a modern dishwasher does before it begins to fill with water is run the drain pump.  It appears that this DW is not progressing to the next cycle (inlet water) and because the pump runs even when the door is open, I agree that the controller card may have failed.
If possible, inspect all the wire connections (remove main power before you do this) ... if there is a loose connection, the controller could do odd things.
Good Luck!  Please report back what you find, OK?
Apr 14, 2009 | Bosch Integra® 500 SHX46A0 Dishwasher
I own a Kitchen Aid KUD102frss dishwasher. The door is not closing properly. It appears to be the latch. The start button blinks
you might have started a cycle and opened the door by mistake.  try pressing HI TEMP, AIR DRY, HI TEMP, AIR DRY close door to latch, press cancel.
it worked with mine.  you can give it a try.
Aug 20, 2008 | KitchenAid Dishwashers
Have Whirlpool dishwasher Gold Series, Model GU9805CGB1 which stops part way through wash cycle with the led indicator blinks on the normal cycle.....if we ope nthe door and shut ...it continues until part...
sounds like the door is losing contact with the door switch, first thing i would check is the door strike.Metal strike plate located on the tub itself that the door latch catches as it closes. its a spring metal striker, i would try bending it down a little bit to ensure better contact with the switches inside the door itself . next id open the control panel and check to make sure your door switches are secured well, wires are tight.
Mar 22, 2008 | Dishwashers
Dishwasher not starting or emptying
bit difficult to diagnose this but worth while splitting the door and carefully examining the wiring loom where it goes round the corner at the bottom of the door. its quite common to get breakages at this point as it flexes every time you open or close the door
Mar 20, 2007 | Miele G880 Dishwasher
Cranky dishwasher
You want to make sure that the dishwasher is level and secure first of all. Then I would look into the door latch assy. Sounds to me that you are not making all the latch switches when closing normally. When you are slamming it, you are making the switches. The heating element runs through the neutral side of switches, therefor if the switch is broken or the latch is not making, no heating of the water. This results in a default or very long wash time. Check this out first....Catriver..post back.
Oct 15, 2006 | KitchenAid KUDS24SE Built-in Dishwasher
Bosch SHU5315UC Dishwasher Logo
287 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
