Question about Sharp AR-M257 Black and White Copier
Como puedo recuperar el password del admin en sharp ar-m257
007tech
  • 95 Answers
SOURCE: AR-M257 service code L1-00
L1-00 is determined as "scanner feed trouble". The scanner unit (which holds the mirrors) is not moving as it should be. There are a few possibilities. Firstly, does the mirror unit move when the copier is turned on? if not it could be a disconnected/broken scanner wire or bad drive motor or simply dirt/debris or a loose wire binding the unit up.
If the unit moves on power up then it could be a bad sensor or a bad board not registering the signal from the sensor.
You can check the operation of these items in SIM mode : press the following keys one after the other "P" "*" "C" "*" then press 1 and enter/copy button and you'll see the option available.
I hope that helps.
Posted on Mar 31, 2009
  • 143 Answers
SOURCE: i have a sharp ar-m257 has a service code H4-20.
Your main heater lamp has gone bad.
Posted on Aug 01, 2009
  • 118 Answers
SOURCE: How do I get to the black toner reading on a Sharp AR-M257 copier
Hold down the Copy button and you should see a readout for the total copies printed from the copier and the percentage of toner left in the unit.
Posted on Aug 28, 2009
Sharp Tech
  • 63 Answers
SOURCE: drivers Sharp al 1642cs para vista 64bits
Ir a la ficha www.sharpusa.com de atención al cliente a continuación, descarga de productos. Categoría de producto elegir impresoras y multifuncionales. para el modelo seleccionado modelo no figuran a continuación, el tipo de modelo en AL1642CS. Para el tipo de descarga a continuación, elegir controlador presión de búsqueda en la parte inferior.
translated by goole
Posted on Oct 15, 2009
hamzaskilltd
  • 316 Answers
SOURCE: How do you fix problem H4-20 on Model AR-M257
heat roller low temperature detection
Posted on Jun 26, 2010
Previous admin no longer here, no one knows web password for AR-M257. How to reset?
Maybe order the service manual
http://www.servicemanuals.net/ServiceManual/SHARP/ARM237/572062/detail.aspx
Jan 09, 2015 | Sharp Ar-M257
Sharp AR-M257 clearing user names in scan feature
Please log in machine with you browser with machine ip address
and user name and password is admin and Sharp and go to address book and remove anything you do not want.
Dec 04, 2013 | Sharp AR-M257 Black and White Copier
Como puedo.desbloquear mi skout
Como puedo recuperar mi cuenta en SKOUT si le di mal uso como lo recupero porfa digame
Jun 04, 2012 | Sony GPS
What is the default username/password on a Sharp AR-M257 copier?
The default username/password is
admin ( all lower case)
Sharp ( capitol S, the rest lower case).
Hope this helps.
Jan 05, 2011 | Sharp AR-M257 Black and White Copier
El estereo me pide un codigo y no lo tengo como lo puedo descodificar
Lamentablemente, el codigo de desbloqueo es unoco para cada vehiculo; Usted necesariamente debe visitar a su representante Honda presentando el VIN de su vehiculo para poder otenerlo. Dificilmente alguien en Internet podra ofrecerselo, no se deje enga?ar. Este codigo es unico y cumple la funcion de asegurar que el propietario del vehiculo es quien puede activar el car radio.
Gracias por usar Fixya.
Dec 09, 2010 | 2001 Honda Accord
COMO PUEDO QUITAR EL MODO DEMOSTRACION DE UN SONY BRAVIA 32BX3000
Entras al menú .... ajustes.... inicio automático. Ahí empieza una configuración inicial del TV y encontraras una seleccion de Modo entre Tienda y domestico. Seleccionas domestio y listo.
Un saludo...
Nov 02, 2010 | Sony Televison & Video
Que significa el codigo f2-02 de una copiadora sharp ar-m25
me marca codigo f2-02 copiadora sharp AR M455N
ke puedo hacer sera que es le chip o el cartucho.
Oct 01, 2010 | Sharp AR-M257 Black and White Copier
QUE TAL SOY CLAUDIO BERTON DE MENDOZA ARGENTINA, I MAIL claudio.ugarcop@speedy.com, SE DESCONFIGURO EL CODIGO DE ENCENDIDO DE LA LLAVE Y NO CONTAMOS CON EL CODIGO MAESTRO, NI OTRA LLAVE DE EMERGENCIA de...
Saludos Claudio:
Sugiero visitar al representante de la marca; esta es muy especifica y no existe informacion de referencia en el Web acerca de este tema. Lo siento.
Iveco Assistance Non Stop ofrece tanto la asistencia en ruta como el traslado del vehiculo hasta el concesionario mas cerca.
Con solo realizar una llamada telefónica 0800-44- IVECO o 0800-44-48326 , profesionales calificados asisten al instante el vehiculo.
Además si el vehiculo esta en garantía el servicio es completamente
gratuito y con prioridad de reparación en el momento del Service.
Suerte.
Mar 09, 2010 | 2000 Chevrolet Tracker
Mi internet esta disponible a cualquiera como puedo bloquearlo necesito ponerle un candado llame a soporte tecnico y me cobran por su asistencia es ridiculo si estoy usando sus productos
No porque te compres un coche los del concesionario tienen que enseñarte a conducir...
Supongo que tienes un router WIFI, y que no hay encriptación en él. Obviamente necesitaríamos saber que modelo de router tienes y que tipo de direccionamiento IP estas usando para tu red local.
A grandes rasgos, tienes que conectarte con tu router (a menudo vas a poder entrar poniendo http://192.168.1.1 en un navegador). Quizas te pida un nombre de usuario y password para conectar. Si es asi, tendras que saber cual es. De fabrica una combinaciones validas serian:
usuario: admin password: admin (o dejar el password vacio)
usuario: root password: admin (o dejar el password vacio)
usuario: root password: root
usuario: 1234 password: 1234
usuario: 12345 password: 12345
Una vez dentro del router, tendras que buscar donde se define la encryptacion del enlace WIFI, escoger un tipo de encryptacion (por ejemplo WEP), y poner una clave.
Si has conseguido llegar hasta aqui y te estabas conectando por WIFI, en este momento se te desconectará la conexion. Ahora tienes que decirle a tu PC que utilice encriptacion para conectarse.
Tambien seria aconsejable cambiar la clave del usuario de administracion (el que has usado para entrar en el router).
Suerte.
Jun 23, 2009 | Linksys (WRT54GC) Router
Sharp AR-M257 Black and White Copier Logo
107 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
