Question about Krups Burr Coffee Grinder
Krups coffee grinder switch problem
I agree the switch is probably the problem.
How do you get the grinder open to check the wiring? Is this something I can do myself, and is it worth it to get a new switch?
  • Anonymous Jul 30, 2008
    the switch is pushed into the housing. how do I open the housing?
  • billandmargo Oct 30, 2008
    Same problem--the switch breaks loose from its mount and falls into the grinder shell. I'm guessing it is not easily repaired.
Had the same problem.  Took out every screw I could find, and pried open the stainless steel shell (not easy) and eventually disassembled it to the point where could get at the broken switch. Cut the wires to the switch and tied them together with some black electrical tape effectively bypassing the safety switch, then put it back together. Tools I used were a screwdriver and a pair of pliers. Thing has worked for 2 years since.  It will run without the lid on, so dont stick your fingers in.
Overall took me about 45 minutes, but well worth it instead of adding to landfill and spending more money.
Posted on Feb 07, 2009
Krups Grill FDE3
If NO LIGHTS come on and not a single thing operates, I too would say that it's most probably the THERMAL SWITCH, activated when the motor gets too hot and is in danger of damage. A very cheap electronic device, quick and easy to remove and replace.
Mar 10, 2014 | Krups GVX2-12 Electric Burr Grinder
Motor shorting out?
check ur switch better replace the switch
Jun 17, 2008 | Krups Burr Coffee Grinder
EA6935 krups powdered coffee inside grinder and coffee grounds noncompact
You will need to pull the grinder apart & clean it out. Most likely cause of the grinder blocking up is a leak somewhere inside the machine dampening the grounds as they exit the grinder. They bind up, won't fall out and there is your blockage. You will need to find and fix the leak, there are many, many places for the leak to be, it's a job for a Krups Service Agent. I have outer housings with cutouts in them so I can run them and look inside at the same time to find those troublesome leaks.
Feb 28, 2014 | Krups Coffee Makers & Espresso Machines
Krups XP7230 outgoing used coffee is not compact
Grinder is not working normally and probably inner plastic part which remove coffee from the grinder is broken.
Feb 28, 2014 | Krups XP Coffee Makers & Espresso Machines
Grinder in Krups Espresseria EA8000 stops and whirrs.
Hi, i had similar problem on my Krups. Inner star plastic part which remove powdered coffee is maybe damaged. You need to replace or overhaul your grinder or you can replace inner star plastic part by yourself. Coffee grinder spare repair part plastic inner star Krups Mhle...
Feb 11, 2014 | Coffee Makers & Espresso Machines
GVX2 krups coffee grinder; how to open it?
I have the same issue. You need to take both dials off, then on the bottom, there are 4 tabs on the inside. Seperate the halves and you will see them. Towards the front and halfway back. Pry the halves apart enough to push the top towards the bottom and it slides apart pretty easy. The tricky part now is finding the replacement part. I have super glued my switch and I want to do something to try and repair it further. Maybe epoxy. I called Krups and they can't sell the part to me. I called one of their service centers and they can't sell the part to me. So, if someone knows where to get the part, I am all ears :)
Nov 25, 2008 | Krups Burr Coffee Grinder
Krups coffee mill
There are four slots in the bottom through which you can see the attachment clips. These clips are not mounted on the base but clip into the base. There is a special 4 prong tool that is used to depress these but if you don't have one, which you most certainly will not have, you need to use four small nails to open it up. Looking at them from the bottom, the clips look like a capital E with an extra horizontal leg. try to drive your nails in to the middle of the back of the E, that is on the flat side. After you have done this use a claw hammer to pry the bottom off by inserting the claws into the seam between the bottom and the top and twisting until something gives. You will probably get the bottom off without destroying more than one of the clips. No matter, you can tape or glue the ****** back together.
If power lose was your problem, remove the switch from its clip then test it to see if depressing the button causes the contact rod to touch both of the copper plates which are mounted on opposite sides of the switch, be careful while making this test - you have to have the grinder plugged in and you do not want to be touching any electrical contacts, the blade or the motor. Also beware of the torque from the motor causing you to drop the grinder. Also, beware of the torque from the motor causing you to drop the grinder in the unlikely event that it is working.
If depressing the switch doesn't cause the switch shaft to come in contact with both plates then get a pair of plyers and bend the copper plates down so that contact can be readily be made.
Retest to confirm the fix works then reassemble, using tape, glue or whatever and then -- it's coffee time!!
Jul 23, 2008 | Krups 203 Grinder
I have a 12 month old KRUPS XP7240 coffee maker. It has just ceased to grind the beans. I suspect that the grinder or hopper to the grinder is blocked? Any suggestions how it might be...
You need to open the machine which is easy see my other post on leaking krups xp7240. The grinder can be taken out by removing two torix screws. Probably the electical brushes are gone. Take the grinder engine to a repair shop where they replace them.
May 19, 2008 | Krups XP2070 10 cup Coffee Maker/15 bar...
Coffee grinder
Mine had a piece of the top/bean lid broken off and lodged in the groove preventing the lid from going down far enough to release the safety switch which is on the right (as you look at the front) in the bottom of the groove. Note that there is another safety switch in the body of the grinder above where the ground coffee comes out that must be working as well.
MLK
Feb 19, 2008 | Krups GVX2-12 Electric Burr Grinder
Krups GVX2-12 Electric Burr - Thermal Fuse
Open the grinder by removing both knobs.
The front knob is held in place by friction. Use two flat head screwdrivers to pry it off.
The side knob is held in by tabs you have to push. Pry forward to expose the tab, and use another screwdriver to press the tab, and use the other screwdriver to press the tab on the other side.
Now look at the bottom of the grinder. There are four tabs on the outer shell, use screwdriver s to pry the tabs to separate the bottom of the grinder from the shell, and pull off the shell. Your fuse should be attached to the motor wiring coil.
Jan 01, 2008 | Krups GVX2-12 Electric Burr Grinder
Krups Burr Coffee Grinder Logo
1,004 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
cyfred
Level 1 Expert
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
