Question about Garden
Please describe how to remove back tire from lawn tractor troy built
I have a Troy Built 21" with a Honda engine model 12AV835Q711. I am searching desperately for help. I need the part number and/or how to replace the plastic bracket that holds the drive control cable in place underneath the mower. I've searched high and low and can't find anything on line. THANK YOU
Posted on May 14, 2011
  • 297 Answers
The back wheels are held on by a bolt threaded into the rear axle. To gain access you need to pop off the little black cap with a screwdriver, Then with a 12mm socket remove the bolt and large washer( used to hold the plastic cap), then slide the wheel off. If it wont slide off, due to corrosion ( Rust), then soak it with WD-40 or some type of penetrating oil. Note, some tractors have a keyed axle, if yours does....dont lose it, and when you reinstall the rear wheel, install the key AFTER you install the wheel. Do it from the out side NOT the inside, or it will ( could) push off when reinstalling the wheel. If that happens you wont have any drive on that side.
Hope this was helpful
If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
Posted on Nov 11, 2010
Where can I get all three belt diagrams for a troy built bronco riding lawn tractor model# 13AV67KG
Troy Bilt Deck belt Replacement - YouTube
? 11:46
www.youtube.com/watch?v=w3SrErGTyoY
Apr 1, 2014 - Uploaded by Murray Mayhem
I got a good one troy bilt bronco having problems finding the right deck belt for it. I use the model number under the seat but they are too long ..
Jul 09, 2015 | Troy Garden
Fuse blows on lawn mower troy built bronco rider when seat switch is pluged in
bypass the seat switch with a paper clip and see if it blows out again if so follow the wires and see where its rubbing on metal
Jul 30, 2012 | Garden
Change blades on a lawn tractor pony? troy built
just jack it up so you can get under the deck and unscrew the bolt on center of ech blade take note on how the curves of blade are angled do one at a time incase you forget but bolt back up tight and you are ready to cut if you try to resharpen the blades make sure you balance them or they will mess up the deck bearings
Nov 02, 2010 | Troy Garden
Troy built lawn tractors, belts
You may have a pully that is not spining freely. Or you may have a pully that is not positioned straight. Ariens had a problem with that. so your troy built may have the same.
Apr 19, 2010 | Garden
I have a Troy Built 6605 lawn tractor. The engine
check your belt might be off a pully or maby your spring is off
Nov 09, 2009 | Garden
I have a Troy Built lawn tractor, after removing
Clearly the cable either broke, came loose.
Aug 22, 2009 | Garden
I have a Troy bilt 17hp 42 inch cut ride on lawn
yes they have a charging system, not like a car but a charging system one the less. as i said before either under or around the flywheel. some newer mowers also have an electronic regulator.
Jul 31, 2009 | Garden
Troy built lawn tractor keeps stalling out while mowing lawn. It starts up again, but mowes for a couple of minutes then stalls out.
Have you checked your air filter..it sounds like it could be dirty and needs replacing..if this dont help..just comment back and i will get it..and i will help you further..Keith
Jul 04, 2009 | Garden
Troy built lawn tractor won't start.changed plugs.
i have a troy bilt riding mower,i start the mower it only runs for 15 to 25 min's ,so i changed the coil to see if it would run long. but after a few minunts it stop again so i don't know if maybe it's my carb. what could it be.... help
Jul 03, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Garden Logo
109 people viewed this question
Top Garden Experts
roeb
john h
Marvin
Marvin
