Question about Harman Kardon HK19.5 Computer Speakers
I am not able to get any sound from my speakers. Technician said that my sound card is fine
  • 27,725 Answers
Control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make sure you have selected the right speakers or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers if you have tried this you might try
control panel,administrive tools,computer management,device manager,sound,right click select properties to either troubleshoot,uninstall,rollback driver or scroll to sytem speaker right click select properties you will see at the bottom use this device enable/disable this device
hope this helps
Posted on Nov 10, 2010
No sound out of my Altec Lansing ADA 745. Computer Sound card is fine.
If other speakers are working, then 745 is defective or the volume switch is set to mute. Please check that, repair it if required.
Aug 27, 2012 | Altec Lansing Technologies Audio Players &...
When i plug in my head phones the sound is still coming thru my speakers. my headphones work fine and there in the right whole. please help!
first you can re install your sound card may be your operating system in not detected your head phone properly.if you still have the same issue after re installing your sound card driver ?? u must re install your operating system and install your sound card driver properly. if you still have the same issue?? this problem about your audio jack so remove the audio jack and insert good one this is must have a experienced laptop service technician.
Sep 09, 2011 | MSI WIND U100 Notebook
I can hear the sound in headphone but built in speaker are not working. what to do
Hi, Check the following,
  • Speakers, connecting cables and Sound Card are working fine by connecting to another computer.
  • OR
  • If the connection ok increase your volume and open the cable from the pc.
    Now you will touch the stereo jack, can you can listen a sound when touch the jack. If you will not get any sound, think there is the problem in your amplifier or audio system has not any voltage. To confirm the voltage check by multi miter or can go any local Technician .If the voltage is ok, think your sound system defected and should go to Technician.
  • If your sound system is ok
  • Speaker Cable connect to an audio port (Audio/Video port in system box).
Hope this helps ,
May 17, 2011 | Acer Extensa 5620-4020 Notebook
Dimension 8400 has sound with headphones, but no sound from speakers on the Dell monitor.
  • OR
If the connection ok increase your volume andopen the cable from the pc.
Now you will touch the stereo jack, can you can listen a sound when touch thejack. If you will not get any sound, think there is the problem in youramplifier or audio system has not any voltage. To confirm the voltage check bymulti miter or can go any local Technician .If the voltage is ok, think yoursound system defected and should go to Technician.
Hope this helps.
Feb 23, 2011 | Dell Computers & Internet
Last week my computer crashed down. We can't contact the technician who used to fix our computer. Now we found a new one who can reformat our computer but this time, he installed windows 7. Now, our...
Make sure the speakers are hooked up properly and also that the sound card drivers are installed, you can verify this by going into the device manager. The main speaker wire has to be hooked up to the output of the computer sound card.
If the sound card drivers are installed and the speakers are hooked up properly and your still not getting sound, try the speakers on another computer that you know has sound. If the speakers work then its a sound card driver issue on the original computer. If the speakers don't work on another computer then you know the speakers are bad.
Apr 15, 2010 | Logitech X-240 Computer Speakers
No sound on the Vista comupter. speakers plugged
Dose the sound card have surround sound on it, might need to enable the surround on it. Or try to plug the speaker cable in the black or green hole. And see if that matters. Good luck!!
Oct 03, 2009 | Creative Labs SoundBlaster Live! Sound...
What's the best sound card?
Sound Blaster is certainly a good name when it comes to sound cards, they've been around forever. If you're looking for quality audio and full use of your 5.1 speakers, SB live 5.1 will do the trick.
May 09, 2009 | Creative Labs Inspire T5400 Computer...
No sound. Sound card or speaker failure??
These speakers only accept digital input in form of 3.5mm mini-din digital out from your source.
Nov 09, 2017 | Boston Acoustics BA735 Computer Speakers
Genuis SP-G06 not working as no sound. Don't have driver discs, can't find driver download on net. Any help please??
The problem may not be with de speakers. They don't need drivers, try reinstalling you'r sound card driver... If that doese'n work, it means the speakers may be broken... But try the sound card thing firs...
Good luck,
Dan
Jan 19, 2008 | Genius SP-G06 Computer Speakers
Motherboard sound and old speakers
what really matters is the quality of the usb speakers. check specifications such as wattage first and find reviews if possible. however usb speakers will probably not come close to separate speakers. i'd recommend buying a cheap sound card ($20 or so). these work great overall. $20 spent on a sound card will be a better trade off than $20 spent on speakers. just use your old speakers with the new sound card and you'll have plenty of power. after this i'd recommend headphones as they work great in this case. finally moving the sound card would probably work fine, but i have doubts.
hopefully that helped
Dec 30, 2007 | Dell - 0089D Sound Card
Harman Kardon HK19.5 Computer Speakers Logo
Top Harman Kardon Audio Players & Recorders Experts
Don Hart
 Grubhead
Grubhead
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
