Question about Whirlpool Royal A-909 Bathtub
2netzero.comthere is mold around the water spouts.
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 135 Answers
Spray water spout with bathroom cleaner and scrub mold off with damp wathcloth.
Posted on Nov 11, 2010
Water leaks between the pull down spout and the bathroom tile
It sounds like your spout supply nipple has sprung a leak. There isn't much of any other way water can flow between your spout and tile wall. It's pretty important that you don't use the fixture until the problem is fixed. Because the water coming out that you see is also probably flowing into the wall and causing water damage and MOLD. You need to remove the spout and replace the nipple that is supplying the water to the spout. There could be a defect in your spout too, but likelihood of that is less than your nipple threads giving in to some electrolysis from the bronze/copper in the spout or somewhere in your water system. To prevent it from occurring again, use a brass nipple to replace the galvanized nipple in it now. Red brass, no yellow brass. Good luck with your problem and always know where and how to turn your water off to your house before attempting a plumbing repair.. Most spouts screw off. Counter clockwise, use a pair of channel locks by inserting the rubber coated handle into the opening on the spout then using the leverage of the channel locks to unscrew the spout off of the wall. It is not a repair that requires to have the water off to your home before attempting to repair. It only emits water when the tub valve is turned on. If it doesn't unscrew, twist it until the under side is up and you will see a slot where you can insert an allen wrench to loosen it and then slide off. Inspect the spout while it is in your hands to see if it is damaged of if the nipple sticking out is damaged. one of the two must be, because water flowing from behind the spout is definitely not normal and definitely something you need to fix right away, before your wall and floor behind your tub are damaged or start to grow mold.
May 04, 2014 | Delta Faucet Delta RP17453 Pull-Down...
How to clean water tank as water dispenses with some black stuff
If you look up inside you will mold around the spout. this is were your black stuff is coming from. THe water system is completly sealed and cant be cleaned. However you can flush it. Use a cleaner with bleach in it to remove the mold from dispenser. You also may need to change the chute door . It leaking air is where the mold came from. Ihope this helps.
Aug 21, 2011 | Jenn-Air JCD2389G Side by Side...
Water comes out spout and shower head at same time
Hello gruber d, you need a new spout. When a spout is working properly you raise the knob on top and it slides a baffle over the outlet at the spout. Once the water is blocked from flowing out of the spout it forces water up and out of the shower head.
You may also remove the spout and see if you can get a closer look and see if you can make some kind of adjustment to it.
Removing the spout;
1. Put a cloth around the spout to protect the finish.
2. Adjust a pipe wrench to fit over the spout and the cloth.
3. Turn the spout counter-clockwise to loosen.
My goal was to provide timely and accurate information. If this has been helpful to you, please
consider taking a second to click on the, " this was helpful ", button.
Than you!
Jan 13, 2011 | Grohe Grohmix Thermostat Valve & Trim -...
Lisbon monobloc kitchen taps just installed the
Put some cooking oil around the o-rings to sofen them up so they would seat around all fitting surfaces. Hope this helps.
Aug 12, 2010 | Home
Need info on how to hook up ice maker lines
OK the ice maker is the boss. It calls for water. Nothing else in the ice box controls the ice maker water but the ice maker itself. How? Fancier models use capacitance of ice mold to correctly fill the ice mold. On board intel monitors the temp of the ice mold by sending power through it and checking for differences in capacitance in the mold. When it hits the sweet spot it monitors the temp till it temps inside the mold determine ice is there and kicks in the harvest cycle. Older styles simply put a measured amount of water into the ice mold at the end of each harvest cycle. You gotta first run a water line to the water valve and then run a line from the water valve up to the Ice Maker fill spout behind the ice box. Nothing to it.
May 02, 2010 | Refrigerators
The coffee side has started leaking profusely from the top, back of the water area when brewing.
There is a red hose that connects at the back and top of the unit. Make sure the hose has not come undone and also check that the top lid with the holes is not blocked with coffee grounds. However, the most probable problems will be the hose otherwise you will mostly have steam coming out the back.
Hope this helps!
Dec 07, 2009 | Krups XP2070 10 cup Coffee Maker/15 bar...
Delta RP34357 Traditional Diverter Tub Spout has been leaking around base and/or water running along bottom of spout toward wall from opening; today, whole spout blew off wall when faucet was opened only...
If this spout is less than one year old, I would contact my general contractor to get his plumber over to look at it. Most GC's (general contractors) will warrant their work for one year. If it is not under warranty, you should be able to fix this problem. Spouts do not typically blow off like that, so I am wondering if there is not an underlying circumstance. At any rate, I will assume the best and tell you how to reinstall the spout. There are several variations on spouts, but the one that is most common is a slip connection. Meaning that the spout will slide over a 1/2" copper water line protruding about 3" from the tub. After sliding the spout on, there is an allen screw on the bottom of the spout that snugs up against the copper pipe (again this is the most common type of install). If yours is different, let me know, and I will walk you through other processes. Before sliding the spout back on the copper, use plumber's putty around the opening that the copper is sticking out of. This will help to prevent water from getting behind the tub. Also, after the install; check the spout to make sure there are not any leaks. If no leaks are detected, use a clear silicone tub/shower caulk and go around the faucet. The caulk does not have to be a 1/4" bead to be effective. Run it around the spout, and using a moist towel, go back over the caulk to remove the excess. If you have done it right, you will not even notice the caulk, except for the gaps. Hope this is helpful.
Nov 20, 2009 | Delta RP34357 Traditional Diverter Tub...
Mold inside reservoir tube
use vinegar run about 1 1/2 cups thru machine if not clean completely try getting a pipe cleaner thru tube
Oct 04, 2009 | Saeco Magic De Luxe Espresso Machine
Mold/Bacteria formed behind ice dispenser spout and above dispenser lever. Can spout be removed for cleaning? If not, How to clean?
Remove the dispenser cover by gently prying starting at the bottom going round and round a little at a time to prevent from breaking it. When it's off the screws will be exposed to access the other components.
Although you may can clean it by just spraying everything you can reach with a spray bottle of bleach and water mix and let it set for a while and then rinse with clean water. Test an inconspicuous spot the check for damage. Or another mold killer may work just as well.
Sep 30, 2009 | Refrigerators
Mildew in the water spouts
try using liquid wash detergents placed in a plastic ball inside the drum, instead  of using powder placed in the soap drawer, because the residue of powder left in the drawer allows bacteria to build up, thats what causes the 'black deposit' you speak of, its very difficult to remove
Jan 02, 2007 | Frigidaire GLTF1670A Front Load Washer
Whirlpool Royal A-909  Bathtub Logo
41 people viewed this question
Top Whirlpool Home Experts
Craig Butler
Craig Butler
john h
Mike
Are you a Whirlpool Home Expert? Answer questions, earn points and help others
