Question about Price Pfister R897EBK Brushed Nickel Catalina Single Handle Shower Only Tri
Slowly lost hot water pressure, took valve apart-now need to see a diagram of how it goes together/ half moon/teardrop shaped openings/orientation to the two(hot and cold) water pipe openings
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 135 Answers
Here is a link to a pdf file with an exploded view of that faucet that shows how all the parts go together:
http://pricepfisterparts.faucetdirect.com/mediaBase/manufacturers/PricePfister/PartDiagrams/PRD_8art_14962_EX-808-01.pdf#page=1
Posted on Nov 11, 2010
Ford Ranger 2006 A.C. 3l. engine, Cabine temperature stay hot when knob is at cold position.
Sometimes it is the knob. The shaft of the control knob is a half-moon shape. The knob is half-moon shape with a metal clip around the opening for the shaft. When the knob cracks it spins around the shaft and you can not see this going on because it is behind the front side of the knob.
Water control valve- some systems use a water control valve to regulate water going into the heater core. These can be vacuum or cable operated. There will be a valve in the heater water line and can be stuck in one position causing your problem.
Air flow valve- some systems always have flow of hot water in the heater core, they just use a duct flap to route the flow through the core at one setting and close the flow when you want cool air. Sometimes the cable slips out of the fixture and will not move the duct door.
If you pry off the heater knob you will be able to see if it is cracked, just be careful not to scratch the face of the dash. You might be able to Web search for these components or even find a Youtube video showing how and where these components are located.
Hope this helps.
Mar 02, 2018 | Ford Cars & Trucks
Yamaha razz wiring diagram
What color is the wire?
Jan 13, 2018 | Motorcycles
No hot water pressure in bathroom
bleed the system,sounds like an airlock issue
Apr 05, 2017 | Water Heaters
I installed a new Price Pfister 08 series tub & shower single control, pressure balancing valve body.The temperature adjustment is set at full travel for temperature. The water doesn't get very hot at...
No and you can thank you government rep next time you see or talk to him for this. The valve is set to give no more than 110 to 115 degree water and cannot be changed. If you want hotter water you will need to install a non-scald faucet. Now if you are not getting to the 110 degree mark then you will need to disassemble the valve body and look for debris in the hot water inlet side.
Now when it is apart turn the water on low and flush the piping out before putting it back together.
Feb 11, 2011 | Price Pfister Universal 0X8-310A Pressure...
I have a hotpoint hot water heater it's about 6 years old. When I turn the hot water on it runs very slowly the water pressure is very low and it's like this throughout the house how do I fix this problem...
You have clog in the water line.
Since all hot water pipes are involved, clog is probably near water heater.
Buy pressure gauge at hardware store that threads onto hose connection.
Brady BTG 100 at Amazon
Picture of gauge
Check outdoor pressure for baseline pressure in your home.
Turn off electricity to hot water heater for an hour or two so there is not scalding water.
Open drain valve on water heater to see if water heater is clogged with sediment.
http://waterheatertimer.org/Water-heater-will-not-drain.html
Put pressure gauge on drain valve and compare with outside pressure.
Open hot water spigot on bathtub and see if tank pressure drops ... if tank pressure drops significantly with bathtub spigot on, then clog is on incoming cold water before tank, and could be on outgoing hot water pipes too.
If tank pressure stays about the same, then clog is on outgoing hot water pipes.
Clog can be sediment caught in cold water shut off valve located above tank. Open and close valve and test pressure again. Take apart incoming cold water pipes above tank and check for sediment. Replace valve. Look at condition of cold water nipple on top of tank.
Sediment caught at hot water elbow near tank.
Sediment can fill up old pipes. Take apart hot water pipes above water heater and see condition.
Look at condition of hot water nipple on top of tank.
You may have to take apart pipes up to first or second elbow.
Pipes can decay at joint where copper pipe connects to galvanized pipe. Check for copper to galvanized connections on cold or hot pipes and replace section of galvanized pipe. Copper pipe will probably be good, the galvanized pipe will deteriorate. Replace copper-to-galvanized joint with 3/4" non-conducting union from hardware store
Dec 06, 2010 | Water Heaters
White 1418 sewing machine
If you have taken the hook out that is the half moon shape first of all make sure the needle is at the top of the machine, hook in, gate up and that is all there is to it.
Apr 10, 2010 | White Sewing 1418 Mechanical Sewing...
Unit only works upside down!
there is a water level next to the ocilater make sure that the canal is clean. try some water and vinegar
Apr 07, 2009 | Venta VS 100 Humidifier
Location of ge profile water inlet valve
may be to much water trap door open light on door (ajar)
Mar 14, 2009 | GE Profile PSW26P Stainless Steel Side by...
Low cold water pressure
Could be sticking plunger in valve, if youn have ascertained that the pressure is o/k,\then I would suggest a new valve is called for.
Dec 08, 2008 | Washing Machines
Price Pfister R897EBK Brushed Nickel Catalina Single Handle Shower Only Tri Logo
484 people viewed this question
Top Price Pfister Home Experts
Mike
Tim Whalen
Are you a Price Pfister Home Expert? Answer questions, earn points and help others
