Question about Whirlpool LER5636P Electric Dryer
Front load dryer, estate by whirlpool, plastic handle broke. Bought a new one but can't get it to snap on??
  • 1028 Answers
SOURCE: Whirlpool Duet Washer Model No. GHW9100LW, Serial No. CSM2608446, Type No. 199-AWM075/GY
not unless you make it yourself ..replacement handle is just like the 1 that broke
Posted on Aug 20, 2008
  • 33 Answers
SOURCE: Brand new Whirlpool Duet Sport gas dryer & burning plastic smell
I would consult the place of purchase. If they do not stand behind the product, then get the manufacturers support #. They will stand behind their product, especially if it is a possible fire hazard. THe smell you are smelling could be anything, but without being there and taking off the cover and doing a visual check. it's hard to dianose. It is possible that something that is plastic has fallen out of a pocket and gotten inside the unit while it was drying clothes and fallen onto the igniter housing.
Posted on Nov 30, 2008
  • 124 Answers
SOURCE: replaced high temp sensor on whirlpool front loader
Hi, Here is what is happening.
  1. Yeah fixed it by replacing hi temp sensor.
  2. Then sensor went out again.
  3. Reason there is another sensor that controls heating element. One is high temp, which controls the heating element from overheating. The other controls normal heating element temp range. What normally happens is the temp range goes out & heating elements overload the high temp sensor causing it to fail. Usually best to replace as pairs. Make sure your using the proper temp sensors as well. If you get temp range hotter than high temp results same problem.
Hope this cleared up your problem & fixed you for good. Please rate. Good Luck! If I can Help further please send comment.
Posted on Mar 13, 2009
MicrowaveSvc
  • 9047 Answers
SOURCE: How to replace cracked plastic door frame on Whirlpool microwave?
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screw(s) you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
In some cases, you then have to gently rotate the handle to unlock it.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Jul 20, 2009
blueextc3221
  • 15935 Answers
SOURCE: My Whirlpool Duet front loading dryer does not
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question*****
Posted on Sep 30, 2010
I have a Whirlpool GHW9400PL0 front loading washer. The door won't stay closed, and I think it's because the plastic latch on the base of the machine broke. The latch portion (white plastic) looks...
you have to inspect that switch carefully,, its actually got 2 , a secondary switch latches just before the spin cycle, I'll try and locate the part for you
Jul 09, 2011 | Whirlpool Duet GHW9150P Front Load Washer
We broke the door handle on our Malber 1000 Can we order a new one and can we fix it ourselves?
Mike, in Washington D.C., again. Of course you can do it yourself. First call Joel (Malber in NY) at 800-600-8913 or 516-294-6660 . Tell him which model machine you need a door latch for (if you aren't sure, check label in rear). Once you've received your new latch assy (about $20): Open door, and notice white plastic "ring" around glass is actually 2 pieces (front and rear) snapped together - with a seam around periphery. Unsnap (separate) them by either getting your fingernails into the seam and pulling them apart - or prying them open with a spackle knife or thin screwdriver blade. Once it starts coming apart, just work the opening all the way around. Remove front "ring" and set aside. Using a 1.5mm Torx screwdriver, remove 2 small screws holding broken latch assy. Note the way the ends of the spring go under the 2 screws. That's the way it has to go back. Slip new latch assy into place, pressing vertical "hinge pin" and ends of spring into slots (near screw holes). Replace 2 screws. Test latch with door open - is it working? Try closing door. All good? Replace front "ring": Open door and, while pulling out on latch handle, slip the ring over the latch handle and get it into approximate position. Let go of latch (it snaps into "closed" position) and adjust ring so it doesn't bind the latch handle (meaning it's free to move). Now, beginning anywhere on outside edge, begin snapping rings together - and continue all the way around. Test that door latch still operates smoothly and that door latches shut properly. FYI: There is no adjustment for this latch assy - it just fits precisely where it's supposed to. Good luck and God Bless ...
Sep 26, 2010 | Malber WD1000 Front Load Washer/Dryer
Door handle broke off
www.splendide.com
1-800-356-0766 #5 (503-656-2280)
503-722-9202
service@westlandsales.com
Monday-Friday, 7:00am - 4:30pm (PST)
Apr 28, 2010 | Splendide 2100 Front Load Washer / Dryer
Two 8182233 plastic baffles broke
This is a common problem on front loaders,Once you get the new baffles they just snap in.They have clips.
Jan 08, 2010 | Kenmore Elite 45986 Front Load Washer
Need help replacing handle on whirlpool microwave model MH1150XM
Remove two screws on top at front in order to remove plastic front vent grill. Then the door lifts off pin hinges. Lay door flat on surface. Plastic trim snaps off with gentle prying (start at bottom middle and bottom hinge side). Then remove six screws holding notched metal section with door latch. This piece will also snap out (several visible clips holding it around edges). Then remove door handle screws, Replace handle and reverse process to put back together.
Jul 29, 2009 | Whirlpool MH1150XM Convection/Microwave...
Malber WD1000
door handle broke at plastic insert. Looking for replacement parts.
Jul 05, 2009 | Malber WD1000 Front Load Washer/Dryer
Whirlpool ghw9400su0 paddle broke off tub
go to www.repairclinic.com enter your model number and scroll down all the way and click the red 100 you'll see. when new page shows up look for part number 1059587. I think this is the part you need and see the price diff. between your quote and the actual price. You may just want to order from them and do it yourself. It does look as if it snaps in.
Apr 08, 2009 | Whirlpool GHW9200L Front Load Washer
Bought a new whirlpool estate washer today. brought it home. pulled yellow strap and removed long straight metal pin. (evidently broke 2 shipping pins off because they fell into their little plastic cups...
this is poor delivery,,jostled unit,,,you just broughjt it so your under warranty ,,by the time i tell you what to look for,,the warranty tech will be out ,,its better to let them handle it,,,if you open unit it will void your warranty...
Jan 18, 2009 | Maytag PAV2300 Top Load Washer
Aug 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool LER5636P Electric Dryer Logo
20 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
