Question about TruTech Televison & Video
How do I connect DVD to TV please - TruTech Televison & Video
    Problem Solver:
  • 17 Answers
On rear of tv you will have video and audio input jacks red and white are audio yellow is video , make sure they are input jacks the jack will be labled and and on back of dvd player will be red white and yellow jacks that are labled output using the cables supplied with the dvd use the red and white insert them on dvd out corresponding colors and the yellow into the video out, now on the tv take the other end of the cables and insert them into the audio and video inputs again with the corresponding colors audio red and white and video yellow ,,,I hope this helped
Posted on Nov 10, 2010
I have lg dvd model dv257 pm, problem is there is no audio and video output but reading disc is proper plz give me solution for it.
your connection is wrong. Get a RCA wire. Yellow is video and white & red are audio.
Connect the wires to Output from the DVD. Video out and audio out. All that will be connected to the DVD will be output. The DVD is feeding out to the TV, so it is giving.
Now the all connections to the TV will be input. Because the TV is receiving from the DVD. Connect from the DVD to TV respectively.
Turn on the TV and DVD, then press Souce/AV on the TV. Now you should see a display and hear sound from the DVD through the TV.
I hope the above is clear. If not, please let me know.
Good luck.
Jan 04, 2012 | LG Televison & Video
How to connect austar and a blue ray DVD player to tv
Good luck.
Jan 04, 2012 | Televison & Video
I have a sony triniton color tv medel 3 KV-DR34M89. How do i connecft and play a DVD on it.. i treid connect the yellow,red and white cables on all the slots but no success. please advise
Connect cables:
Connect yellow to yellow (dvd player to TV)
Connect white to white (dvd player to TV)
Power on DVD and TV and insert a DVD into the player, press PLAY.
Use your TV remote to select the proper input:
Your remote should have a button like INPUT SELECT or Video, keep pressing until you see the DVD players output.
Feb 20, 2011 | Sony FD Trinitron WEGA KD-27FS170 TV
Hi i have an alba tv , im trying to connect a dvd player. I have connected the scart leads etc.I can not get onto the av channel so i can watch a dvd. Please help
Firstly, please make sure you have connected the SCART cable correctly. This should be connected to a SCART OUT socket on the DVD player to one of the SCART IN or EXT sockets on the rear of the TV.
If you have correctly connected the SCART cable the TV should automatically switch to the AV channel when you switch the DVD player power on or insert a disc.
Switch your TV on, then switch the DVD player off and then on again. If the TV does not change to the AV channel you may have the SCART cable connected incorrectly.
Not all TVs automatically switch to the AV channel when the AV device is switched on. On some TVs the AV input is on channel 0 or 99. On other TVs the AV input is not assigned to a specific channel. On these TVs you need to look for a button marked "AV", "INPUT" or "SOURCE" - either on the TV remote or on the buttons on the front of the TV. The easiest way to do this is to insert a disk into the DVD player and start it playing. Then press the "AV" "INPUT" or "SOURCE" button (whichever one you have) repeatedly until you find the signal from the DVD player.
Please check your connections and try using the "AV" "INPUT" or "SOURCE" buttons. If you are still unable to watch your DVD player, please post back with the following information:
1. Model number of the Bush TV
2. Brand and model number of the DVD player
3. If you are using any remote other than the ones supplied with the TV or DVD player, the brand and model number of the remote.
I will then be able to tell you exactly how it should be connected and which buttons (if any) you need to press to access the AV channel.
Hope this helps. Happy New Year!
Regards,
BElectric
Jan 01, 2011 | Televison & Video
We're not getting any sound from the dvd's. I have two cables (green/blue/red) and (red/white). but I'm at a loss how to connect from DVD to TV. Help please!
If your TV has the green, blue, red inputs then connect these 3 cables for the picture. DVD to TV, green to green, blue to blue and red to red. If your TV only has a yellow input, then connect the green cable only from the DVD yellow to the TV yellow. Now for the sound. Connect the DVD white to the TV white. Connect the DVD red to the TV red with the red cable. The white and red inputs will be next to the yellow and the green, blue, red inputs on the TV. Next select the TV input using your TV remote. Select the input for the DVD connection.
Sep 04, 2010 | Sony DVP-NS400D DVD Player
I have a new vhs dvd player recorder that will not record.
please note in your vhs dvd manual it tells which dvd (maxell, tdk etc.)are compatible with the recorder
okay do you have a cable/satellite box connected to tv/monitor? yes or no
yes- is the the tv on ch 3? cable connected to cable box in, cable box out connected to dvd in,(on dvd set up menu make sure broadcast is cable) dvd out connect to tv... ? please note some dvd recorder will not record HBO (you can record on vhs tape)
no connect antenna to dvd in, dvd out goes to tv.....
hope this help...
May 20, 2010 | Quasar VHQ400 VHS VCR
How do i connect awa set top box with a dvd player and tv, setup yo tv is easy but i also want to use dvd player
Hi
Thanks for using FixYa. Please see this diagram to check the set top box, DVD player and TV connections---
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Sep 26, 2009 | Televison & Video
I can't record normal tv progrma from HD tv
My dear friend where you connect the antenna source to the dvd or to the vcr or tv because ,if you wanna record anything you need to connect the antenna source to the dvd and put the channel you wanna record on him
Jul 25, 2009 | Televison & Video
Lg tv and dvd
please connect the RCA wire yellow,red,white with TV set's output connections and other side connect with speaker systems input connections that's all
Nov 04, 2007 | LG 42LC2D 42 in. LCD HDTV
Some sound missing from DVD playback
plug out your dvd for about 2hrs and plug it in back then start all over.good luck.
Apr 01, 2007 | Zenith ZHX-313 System
Televison & Video Logo
Top TruTech Televison & Video Experts
Jason Morris
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
