Question about Dishwashers
Dish washer is not draining - Dishwashers
  • 51 Answers
Check to see if the strainer at the botto of the tub if covered/clogged.
Does your sink drain OK?, most washers are hooked up to the same drain line
Posted on Nov 10, 2010
Dish washer
The drain tube is stopped up, use a metal coat hanger pull unit out unhook drain stick wire in and swirl around.
May 09, 2013 | Dishwashers
Whirpool dish washer has water coming out the air gap when flushing out of dish washer
I think you have a clogged line. the drain from the dishwasher goes up to the air gap and also into your sink drain pipe.
hope this helps
Jul 05, 2012 | Whirlpool Dishwashers
Dish washer not emptying
put your model # into a google search and choose a place that has parts and look up your drain pump. you probably have either a clogged drain hose, not likely, or a bad pump.
May 13, 2012 | Dishwashers
How to install drain to maytag in cabnet dish washer
ON MOST DISH WASHERS DRAIN IS HOOKED INTO SINK DRAIN.
May 01, 2011 | Plumbing
Does not pump water. Leaves dishes soappy
We really need your model number to help you properly. In the mean time you can check you sink connection and air gap for obstructions. Usually the cover just pulls up and off then you unscrew the cap to expose the drain tube for the dishwasher. More often than not if the unit fills and washes but leave soap on the dishes a clogged drain line is the problem. You may have to run something down the drain tube to clear it. Usually you will see the obstruction when you remove the cap. There is a remote possibility if it drains into a garbage disposal that food particles have clogged the drain outlet inside the garbage disposal. Hope this resolves your problems. Cheers!
Sep 20, 2009 | GE 15" Laundry Pedestal for Horizontal...
Mucky water after cycle complete
poss a blocked drain or a backe feed from the sink remuve drain hose and check.
Nov 13, 2008 | Dishwashers
Neff intergrated dish washer
Drain pump is either faulty or blocked, follow drain hose back to d/washer pump is at the end, always isolate from power supply before attempting any work
Jul 24, 2008 | Neff 24 in. S5456 Built-in Dishwasher
Have a trouble: dish-washer will not drain.
I just moved into a new house and builder had provided a dish washer drain just below my kitchen drain line.
DIsh washer install was done by me, every thing worked out OK except dish washer would not drain after a wash cycle.
Cause: drain provided by builder was blocked and needed a circular small cut before mounting drain hose over it.
Mar 21, 2007 | Electrolux 24 in. ESI6220X Free-standing...
Dishwashers Logo
35 people viewed this question
Top Dishwashers Experts
Owen Barnes
