Question about Epson Stylus Photo 1280 InkJet Printer
Epson stylus 1280 printer
Printer stoped printing-the red and green light are both solid-when I try turning it off then holing down paper feed button then power button till power button is flashing nothing happens
  • 2 more comments
  • Jod Lourie Jun 17, 2008
    a solid red paper feed light and a solid green power light
    Thanks Binary! I replaced both cartridges and it worked-usually the printer utility shows me what cartridge needs replacing but this time it just said communication error instead so I could not figure it out-I like your service
  • Johann Toledo
    Johann Toledo May 11, 2010
    Just a clarification. Without pressing anything and just turning on the printer. What lights do you see after the printer is turned on after about 20 seconds?
  • Anonymous Mar 13, 2014
    power button does not work. nothing happens when power button pressed
Good suggestion. thank u.
Posted on Aug 11, 2008
  • 54 Answers
Based on the lights you are already out of one or more ink cartridge or an ink cartridge is not being recognized/expended.
-You cannot print if any ink cartridge is expended.
-Leave the empty cartridge installed in the printer until you have obtained a replacement.
Once you start the ink cartridge replacement procedure, you must complete all the steps in one session.
1. Open the printer cover and press the INK REPLACEMENT button, located under the printer's cover. The print head moves to the center and the lights flash.
2. Lift up the ink cartridge clamp. The cartridge rises up from its holder.
3. Remove the cartridge and dispose of it carefully. If ink gets on your hands, wash them with soap and water. If ink gets in your eyes, flush them immediately with water.
4. Unpack the new ink cartridge and remove the yellow tape. You must remove the yellow tape from the top of the cartridge. Do not remove the clear seal underneath the cartridge. Do not touch the green circuit board on the back of the cartridge, or you may inhibit normal operation and printing.
5. Tilt the new cartridge toward you slightly as you insert it. Lower the cartridge so that the tabs rest on the hooks. Do not place the cartridge tabs under the hooks.
6. Press down firmly on the ink cartridge clamp until it snaps in place.
7. If you need to replace the other ink cartridge, repeat steps 2 through 6 before continuing with step 8.
8. Press the INK REPLACEMENT button and close the printer cover. The printer begins charging the ink delivery system.
9. Wait until ink charging is finished (the power light stops flashing and the red error light goes out).
Posted on Jun 17, 2008
My epson tx700 printer dispaly ink pad at end of life and printer not start
A fix from a forum:
Procedure 1 We found this procedure to work for the Stylus Photo 1270 type printer, and understand that it also works for the 870 range and even earlier models like the Stylus Color 740. The error is indicated on these printers by all four lights on the printer flashing. Even if you press the power switch on the printer, the lights continue to flash, and the printer does not turn off!
  1. Turn off your printer, ensuring that the print head is at it's home location and locked in place as normal;
  2. Power off the printer at the wall or by removing the power cable, for at least 20 seconds;
  3. When you restore power to the printer at the wall socket or by reinserting the cable, if the lights come back on straight away, the printer's power switch was 'on' - switch it off and return to step 1;
  4. Hold down the paper-feed button and the button with the ink-drops next to it, and then turn on the printer, still holding the buttons down;
  5. When the paper-out LED flashes, release the buttons;
  6. Press and hold the Cleaning button, until several lights flash - this will take a few seconds (i.e. then release the button);
  7. The printer will now attempt to reset, including resetting the EEPROM memory and running a short (about 10 seconds) cleaning cycle.
Procedure 2
  2. Hold down the paper feed button only;
  3. Turn on the printer;
  4. As the paper feed light starts flashing, release the button;
  5. Immediately hold down the ink-drops button for some 10-20 seconds or until the printer springs into life;
  6. Allow printer to complete it's processing, then turn off for a few seconds, and back on again for a newly working printer!
Procedure 3 - for 1290 and possibly 890 printers 1290 printer with green (power / data) and red (ink / paper feed) lights flashing alternately:
  1. Switch off printer with panel switch;
  2. Switch off printer at mains switch - leave off for 20+ seconds;
  3. Hold down roll feed and sheet feed buttons;
  4. Switch on at mains;
  5. Switch on at printer panel;
  6. Continue to hold down roll and sheet feed buttons until both green and red lights flash together in synchronisation, not alternately;
  7. Switch printer off and then, after a few seconds, on again at mains switch;
  8. When red and green lights are both flashing in synchronisation, release the roll and sheet feed buttons;
  9. Press and hold down the ROLL FEED button (the one at the extreme left) and keep it down until the machine finishes whirring, cleaning etc and the green light comes on steady;
  10. Release the roll feed button and all should be well.
Apr 25, 2011 | Epson Printer
The ink pads are at the end if their service life.
Depending on what type of printer you have:
Procedure 2
Mar 13, 2011 | Epson Office Equipment & Supplies
Does not print
***hi there,il be willing to help you on that. ****
the nozzles of the printer might be clogged by dried inks thats why when your printing, its feeding the paper, as if its printing but no inks on the paper. print a nozzle check to see which part or color have clogs, if there are gaps or breaks, do head cleaning untill no more gaps then try printing.
Running a Printer Check
1. Load a few sheets of plain paper in the sheet feeder. 2. Turn off the Epson Stylus NX100 Series. 3. Hold down the nx100_tx100_ug.1.96.1.jpg Stop button as you press the nx100_tx100_ug.1.96.2.jpg On button to turn the Epson Stylus NX100 Series back on. Hold down both buttons until the nx100_tx100_ug.1.96.3.jpg On light begins to flash, then release the buttons. 1. Load a few sheets of plain paper in the sheet feeder. 2. Turn off the Epson Stylus NX100 Series. 3. Hold down the nx100_tx100_ug.1.96.1.jpg Stop button as you press the nx100_tx100_ug.1.96.2.jpg On button to turn the Epson Stylus NX100 Series back on. Hold down both buttons until the nx100_tx100_ug.1.96.3.jpg On light begins to flash, then release the buttons. 1. Load a few sheets of plain paper in the sheet feeder. 2. Turn off the Epson Stylus NX100 Series. 3. Hold down the nx100_tx100_ug.1.96.1.jpg Stop button as you press the nx100_tx100_ug.1.96.2.jpg On button to turn the Epson Stylus NX100 Series back on. Hold down both buttons until the nx100_tx100_ug.1.96.3.jpg On light begins to flash, then release the buttons. 4. Check the nozzle check pattern that prints to see if there are gaps in the lines. nx100_tx100_ug.1.96.5.jpg 5. If there are no gaps, the print head is clean and you can continue printing. If there are gaps or the pattern is faint, clean the print head. If your printouts are unexpectedly light, or dots or lines are missing, you may need to clean the print head. This unclogs the nozzles so they can deliver ink properly. Print head cleaning uses ink, so clean it only if quality declines.
You can also clean the print head by holding down the stop button on the printer for three seconds. (This only works when the red ink light is off.) Run a nozzle check to confirm that the print head is clean.
Caution: When you don’t turn on your printer for a long time, print quality can decline, so turn it on and print a few pages at least once a month to maintain good print quality. ***if my troubleshooting steps are helpful, pls vote for me, i will appreciate it, so that I can be a part of fixya, thanks, Godbless****
Jan 10, 2010 | Epson Stylus NX100 InkJet Printer
The green and red lights are on.They arent blinking just on.And when i go to print a job nothing happends.
The green light is the power light, the red light indicates out of paper or an empty ink cartridge.
Dec 05, 2009 | Epson Stylus Photo 1280 InkJet Printer
Epson CX7450 paper jammed
In some cases, this is cause by a nozzle that got clogged during the jam. You can run head cleaning utility either from the printer or from the computer.
1. Make sure that there are no error lights (red lights), just a solid green light.
2. Take out all cartridges from the printer and put them back in.
3. Once the printer is done charging the inks and you have a solid green light again. Hold down the Ink Button for 3 seconds, after this you'll hear movements within the printer, this is the head cleaning process.
4. Once the printer stops making noises, and you have a solid green light again. Power Off the printer
5. Once the unit is OFF, hold down the paper button while turning the printer ON. Once you see the blinking green light release BOTH buttons. The printer will then print the nozzle check pattern.
* Note: The nozzle check pattern should display all colors in the printer and there should be no gap or break between the lines itself.
6. Do this step 3-4 consecutive times. and that should resolve you concern
Feb 21, 2009 | Epson Stylus CX3200 All-In-One InkJet...
Red & Green Lights keep flashing on Epson Stylus Photo1280
I had the same problem. You need to reset the waste ink counter:
1. Turn printer off, unplug power cord. Disconnect computor interface cable (back of the printer).
2. After one minute, reattach power cord, but not the computor interface cable.
3 Hold down the LOAD/EJECT and CLEANING buttons simultaneously (cleaning button has ink drop on it) .
4 Turn printer on. Release all buttons as soon as the paper out light flashes.
5 Quickly press the cleaning button, and hold for 10 sec while paper out light flashes.
6 Release the button and the printer will initialize.
7. Once the initialization is complete, turn the printer off.
8. Reconnect the interface cable.
9. Turn the printer on and try to print your document.
This process worked for me. Good luck!
Feb 01, 2009 | Epson Stylus Photo 1280 InkJet Printer
Epson 1280 red ink low light will not go out. Have tried replacing both ink cartridges and have disassembled the unit and cleaned the waste pads. I have tried the reset sequence posted on here but it...
Epson color 777 Printer isn't working, the print light is on, but so is the red error light, ink jets are filled, had that confirmed, plenty of paper, what's the problem?
Jan 16, 2009 | Epson Stylus Photo 1280 InkJet Printer
Epson 1280 Will Not Take Paper through to print?
Follow the instructions below in an attempt to resolve the issue you are experiencing.
1) Turn off the printer and remove all paper from the paper tray.
2) With the printer off, check for any obstructions such as torn paper or foreign objects.
3) Place 20-30 sheets of paper in the printer, ensuring none of the paper is torn or creased.
4) Make sure that the paper is flush with the far right edge of paper tray, move the left edge paper guide over so that it touches the left side of the paper.
5) Attempt printing.
Apr 19, 2008 | Epson Stylus Photo 1280 InkJet Printer
Epson 1280 Printer breakdown
it is the wasted ink pad, they are full.
to have your printer work again
turn off the printer.
press and hold the ink and paper button while turning on the printer, wait for 5 seconds then release the button and press the paper button for at least 10 sec.
if done correctly , you will see the carriage start moving
Jan 20, 2008 | Epson Stylus Photo 1280 InkJet Printer
EPSON STYLUS C86
Let's Try first if it can print without using your computer just to check if printer is working fine by itself.
step1
Make sure its not connected to the computer and there is paper loaded on the printer. Turn off printer, press and hold paper button (middle button) then press and release the power button (right button). If you can see a flashing green light release your hold on the paper button.
If it prints by itself good go to step 2 if not check what lights do you see. Solid red light on ink light (tear drop button) means one or more inks is empty. Epson printer will not print if one or more ink is empty.
step2
Check if computer can detect printer goto start/control panel/systems/ click on hardware tab and click on device manager
On device manager click on Universal Serial Bus controllers press on the "+" sign check if there is USB printing support on it
Check if there is a mark (ie. ?, !, red x mark). If none good there is no conflicts. If there is a mark right click on USB printing support and click on update driver and install recommended
Oct 21, 2007 | Epson Stylus C86 InkJet Printer
Epson Stylus Photo 1280 InkJet Printer Logo
504 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
