Question about Samsung DVD-V9800 DVD Player/VCR
Second hand DVD/VCR 9800. DVD works beautiful. VCR has no color & is grainy as if my connection is off.
  • 1 more comment
  • Lydia Fortune Nov 10, 2010
    I'm sorry but the terms you used are Greek to me. I will have to look in the vcr menu and see if there is anything like that there. By leads, I'm assuming you mean the cables (yellow, red & white). They work fine for other projects. I found out too late that the vcr has to be hooked up separately from the dvd. This is fine for the dvd I think because it connects directly to the pr, pb & Y outlet on the back of my tv. The vcr hook up is so standard that I wondered if that was the problem. I've got one free AV VIDEO input left on my tv (I've got a digital cable set up that's taken up everything else). I was thinking about getting some kind of cable that I could reduce the three-prong vcr cable to a single 1/4" jack and plug it into that VIDEO in patch. At a loss. I'll try finding what you suggested. Info on the vcr is really lacking. Thanks
  • Lydia Fortune Nov 11, 2010
    I have discovered the problem. The vcr leads are fine. I plugged it into the A/V input in the back of my tv and the picture had color. Problem: sound inputs are being used by my cable set up. I guess that means disconnecting the sound to cable tv and replacing it with the Audio In cables from the vcr every time I want to use it. What a drag! I've had combo units before and never had to do this separate plug in business. Is there any such splitter animal that would solve my problem?
  • Lydia Fortune Nov 13, 2010
    I did not understand the reply. Figured it out for myself and fixed the problem. Wasted $12. The solution: Since the cd player was already running and I was only missing sound from the vcr, there was no need to check my connection. I just needed to patch the video to the A/V section of my tv. Additional help not needed.
  • 4,102 Answers
Hi as you get a good picture with the dvd then this tells us you are tuned in to the correct channel and thats not the problem, the next thing and most likely cause is going to be the head that the tape runs on this is a big silver cylinder at the back of the vcr part, what you need to do is go out to a tv repair shop and buy a vcr head cleaning kit, dont buy a cheap one as these dont work but buy a mid to high end one then follow the instructions on cleaning the head it will say something like pour cleaning fluid onto the cleaning tape provided then play the tape in the vcr this will then clean the vcr head and should solve your problem and get it working as normal.
now if after doing that it still dont work properly then the chances are it may need a pro to take it apart and clean the head by hand this may also solve the problem but if it dont then this points to the fact that the playback head is damaged and will need replacing, now the problem with this is getting the parts its not easy to trace parts for vcr's any more as they have now stopped making them, you may be lucky and find your local repair shop might still have spares in stock but if he has not then the chance of getting the spare parts is slim.
give the cleaning a go first and see what happens you may find this will then solve the problem.
let me know how you get on or if you need further assistance ok
Posted on Nov 13, 2010
  • Samsung Master
  • 5,138 Answers
Tuner will be your problem.
Samsung Parts 1-800-627-4368
Posted on Nov 11, 2010
  • Samsung Master
  • 12,061 Answers
I wonder if you just need to make sure your FORMAT is set correctly on BOTH units, it needs to be either USA: NTSC or Europe: PAL.
Check these settings in your menus, and ensure both are the same.
If not that then try a different set of leads..
Posted on Nov 10, 2010
Why does my dvd only play lack and white
Maybe a fault in the dvd player, connect another one to the tv to see which is at fault
Oct 12, 2014 | Insignia IS-DVD040924 DVD Player/VCR
Have connected dvd/vcr but the tv screen is blue. Can you help please.
You MUST select EXTERNAL Input, NOT a Channel. You MUST connect up via, the INPUTS at rear, either COMPONENT, or COMPOSITE, Or, HDMI. Except for HDMI, ALL Cables, go Color Jack, to Color jack. 3 for composite & Audio, and 5 for Component & Audio.
Apr 23, 2010 | Sanyo DVW-7200 DVD/VCR
No picture
have you connected up correctly, have you selected correct EXTERNAL inputs, you do NOT "tune" a Channel to see picture, you choose external AV input on set. Must connect color to color. 3 for Composite Video AV.Yellow, Video, Red & White Audio. and 5 cables for Component 3 for Video , & 2 for Audio Blue, Green, Red, Also Red & White, Audio.
AV
Mar 18, 2010 | Panasonic DMR-ES10 DVD Recorder
Where to put scart leads into dvd and video player and panosonic tv
Look at the rear of the TV/VCR/DVD & you will see long black sockets where the Scart cable is connected onto, these are normally indicated as AV1/2 etc. You can then take Scart from DVD to TV on AV1. Then on AV2 take the second scart from VCR to TV or you can take the second scart from the DVD to the VCR & from the VCR to AV2 on the TV.
Nov 29, 2009 | Panasonic CT-32SL14 32" TV
I have a toshiba D-VR610KU combo. Cannot get the
ACCORDING TO THE TECH AT TOSHIBA: THE UNIT MUST BE CONNECTED TO THE TV BY AN HDMI CABLE FOR THE DVD PART & (ON THE BACK-RIGHT HAND SIDE OF THE COMBO) YOU NEED TO CONNECT A SET OF THE RED/WHITE/YELLOW CABLES FROM (VIDEO) "OUT" OF THE COMBO & "IN" TO THE RED/WHITE/YELLOW TV(AV-1) PORTS FOR THE VCR PART TO WORK.
Oct 15, 2009 | Toshiba D-VR600
Sharp Aquos LC-37D44U only shows B&W images from DVD & VHS source
First thing- why not just use the HDMI instead of standard def cables in the first place? Anyway- If the RCA-video (yellow composite cable) is not producing color, 1 of 2 things may be wrong: 1. You accidentally connected the a/v cables [yellow white and red] to [red green and blue] component inputs or vice versa, or.. 2. Your TV or DVD player is somehow set to the wrong video format. Check the DVD settings for video output format and video connector type. Format should be NTSC, and connector should be composite and/or s-video for the cables you're using.
If this is only happening when connecting the DVD player through the VCR, then check to make sure the same cables connecting the DVD player to the the VCR are also connected to the TV from the VCR.
BTW- if this is just to record DVDs to a VCR, I'll tell you it's not worth it. If your DVD player has an HDMI port, your picture quality will be so much better than if you're watching a VCR copy of one. Your new HDTV will look worse than an old standard def TV. Worse; I'm not kidding.
I hope some of this helps.
Jun 01, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Grainy picture on LG 50PC5D plasma
Did you try another HDMI cable?
Did you try another DVD player?
If the above try-outs does not work for you, then the fault is most likely with the HDMI input processor area. For this the set will require service.
Jerry G.
Feb 03, 2009 | LG 50PX4DR 50 in. Plasma TV
Sony VO 9800 Chroma Output
There is a converter called the YCP-688 that did exactly this-- converted the Y/C 688 signal coming out of the Umatic deck to a Y/C 358 signal that any modern device with a s-video port (VCR, edit deck, capture card) could accept.
The company went out of business in 2007 , don't know if they are still for sale-- here's a link to it-
http://www.smithav.com/ycplus/docs/688.pdf
Nov 17, 2008 | Sony VO-9800 VCR
Vcr only plays in black and white
Hi Ryana,
Check if the recorder is set to output in 'S-Video' or 'SuperVideo' mode, if your TV doesn't understand S-Video you'll get a grainy B&W picture. The VCR should be set to output in PAL for the UK and most of Europe.
Hope this helps
Andy
Jun 26, 2008 | Philips DVP620VR DVD Player/VCR
Samsung DVD-V9800 DVD Player/VCR Logo
91 people viewed this question
Henry  Thomas
Henry Thomas
