Question about GE Refrigerators
I used a GE Helical 13w 12oVAC 60Hz 200mA FLE13HT3/3/SW bulb for the top light in my fridge and it only lasted for about 3 to 4 months. Is this do to the cold in the fridge or maybe the door being opened and closed turning the light on and off more often than a bulb in a table lamp, or could it be just a defective bulb? Should I try another one of this type bulb in my fridge? Thank You for your cooperation in this matter
You should use a standard 40 watt appliance bulb (usually clear). The life of compact florescent bulbs is greatly shortened by turning it on and off frequently. They work best being left on for 15 minutes or longer. Cold temperatures can also shorten bulb life as well.
Posted on Dec 29, 2008
Can't find replacement bulbs in Toronto. They are VIVA PBCFS1370.
Tina - I just tried to find this bulb for one of my customers. Amazon had a bulb listed with a photo of the VIVA PBCFS1370 bulb. If you read the comments - someone said they sent a Levitron bulb which does not fit. I think you are stuck going back to where you bought the Hunter fan (I assume big box store) or to Hunter directly. A regular 13W GU24 bulb seems to be slightly too wide to fit in the fan. Hunter's part number is 6755101000 and they were $12 each - but that is in the USA. Isn't that a nuisance!
This links to Amazon site - appears to be wrong bulb:
Leviton 9865 13W Compact Fluorescent Replacement Lamp
or could be this one:
TCP 33213SSP 13 Watt 60 Equal 2700K Warm White CFL Spring Lamp Squat GU24...
Oct 04, 2015 | Hunter 52" Ceiling Fan With Light And...
Can I use a 23W CFL bulb in place of a 13W, if the desk lamp says to use a 60W max bulb?
OF COURSE less than 60 watts is it not . and they are a lot cooler
May 08, 2015 | Dryers
I need to replace a bulb in ceiling fan.The dead bulb is a 30 Watt Slyvania #FC9T9/DSW/RS I need to know the size as no one carries it.
You should be able to use one of the following as a replacement:
S6505
FC12T9/WW
32W T9 4 Pin Base Warm White Circline Fluorescent Light Bulb
Satco
S6507
FC30/SW FC9T9/SW FCL30LEX
30W T-9 9in 4-Pin
Satco
11085
FC12T9/KB
32W -Bulb: Circline T9 -Base:4-Pin G10q Single-End -
GE
20037
FC12T9/WW/RS
32W -Bulb:Circline T9 -Base:4-Pin
Sylvania
20233
FC12T9/DSW/RP
Sylvania
391227
FC12T9/SOFT WHITE
32W -Bulb:T9 Circline -Base: 4-Pin
Philips
Dec 01, 2014 | Dryers
Over the Range Light Stopped Working
It is a good chance that the bulb (s) have burned out. I would think they would last longer than that but things are not as good as they used to be. Unplug the microwave before removing the bulbs. Especially if they are the screw in type. GE usually has two bulbs in there and they could be the halogen type that just plug in or the screw in type.
Mar 28, 2014 | GE Profile JTP18 Electric Single Oven
What wattage r bulbs on saver bulbs equal to regular bulbs
8w = 45w filament bulb
11w = 60w filament bulb
15w - 75w filament bulb
Mar 28, 2013 | Computers & Internet
Light issues
lights are controled by the light sw . ck them or replace them . / some times the lights are not in tight. remove the light and use some pam on the base and reinstall . if buld is good .... mm
Apr 18, 2010 | Amana ATB1832AR Top Freezer Refrigerator
Ice dispenser won't work, light won't work.ge side by side fridge
A GE uses a 12 volt bulb . It will not come on , if you went and bought a bulb with the same receptical end . HAS to be a 12 volt .
Sep 12, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE GTS20ICNCC Refrigerator light bulb burns out quickly
Use the correct wattage bulbs. If they fail often then you may need to get it checked by an electrician.
Filament bulbs easily burn out. What you can do is to buy cheap bulbs and replace as soon as they burn. This is the problem which is why tube lights and LEDs were invented!
Sep 07, 2009 | GE Refrigerators
How do I get a stuck light bulb out of the refrigerator?
Simple, use a hair dryer (on high heat) on the base of the bulb for a few seconds. The bulb will come out easy. Cold expands and is what made it stick. This has worked every time for me.
Mar 26, 2008 | GE Hotpoint Top-Freezer Refrigerator
Light bulb replacementR
A fridge light bulb is usually a 40 watt appliance bulb with a screw base. It is heavy duty to last in the temperature. If it is not easily accesible to unscrew and replace, there may be plastic cover to unsnap.
Dec 27, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
900 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
