Question about Sceptre X9G-NagaIV 19" LCD Monitor
I have a Sceptre X9G-Naga II and two ceramic capacitors that are in the power supply are fried. The capacitors are C11 and C12. Anybody knows the value of these capacitors and where Can i get them?
  • Bud Martin
    Bud Martin Nov 10, 2010
    Are they in the primary AC side or in the secondary DC side?
    Does it the board look like this?http://s807.photobucket.com/albums/yy352...
  • hecomm1950 Nov 11, 2010
    I think that they are in the dc side. They are two small blue capacitors next to transformer T1 and fuse F1..
    The power supply model is LM004 Rev:3 12/01/2003
  • 11,361 Answers
I think they are MOVs in the primary AC side. Can you post the pictures, or send them to me at budmrtn@aol.com. Most MOV are blue in color, ceramic cap is usually orange/yelllowish color.
Posted on Nov 11, 2010
Sceptre x9g naga v
May i know the exact detailed model/maker of your unit...?
Jun 13, 2008 | Computers & Internet
I recently acquired a sceptre x9g Naga V monitor which has developed a problem. It produces a wonderful image which may last 5 min or 5 sec, then goes black. If I turn it off or unplug the monitor the...
It may have dying power supply due to bad DC filter caps like the 17" version.
http://s807.photobucket.com/albums/yy352/budm/Sceptre%20X7G/
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Dec 30, 2010 | Sceptre X9G Komodo IV 19" Flat Panel LCD...
I have a sceptre x9g-naga III
Not an expert, but from what Ive read, this is a cfl inverter issue. I had the same problem on my Sceptre. Good luck finding parts. My solution: get another monitor.
Feb 27, 2009 | Sceptre X9G-NagaIV 19" LCD Monitor
Sylvania 42
Check the fuses on YSUS & ZSUS boards, if found the fuse blown on that board, just try to replace the board.
Dec 30, 2007 | Sceptre X23gv-Komodo 23 in. LCD TV
Sceptre X9G-Komodo IV
I recently came accross one of these monitors (Planar PE191M) with the identical issue. The resolution was to replace the two 470ufd 25V capacitors that are located on the main power board. The main power board also contains the audio circuit and more importantly the inverter circuit that drives the CCFL backlighting. The suspect caps were identified using an ESR meter; if you happen to have one of these meters you can confirm this is the issue with your unit(s), alternatively you can just replace the two capacitors and see if it resolves your issue. Hope this info helps someone out there.
Sep 05, 2007 | Sceptre X9G Komodo IV 19" Flat Panel LCD...
Sceptre X9G-NagaIV 19" LCD Monitor Logo
219 people viewed this question
Top Sceptre Computers & Internet Experts
Ricky Ostrom
Ricky Ostrom
methjd
Are you a Sceptre Computer and Internet Expert? Answer questions, earn points and help others
