Question about GE Washing Machines
I've had this machine since 1992. The drum, I think, is grinding or rubbing against something. I plan to open it up and see if there is some kind of bumper that is worn. Your help is appreciated. Paul
  • 1 more comment
  • parundel Nov 11, 2010
    Thanks for the reply--bearings make sense. Now, is there a manual that will instruct on bearing work?
    (resending) Thanks for the reply, bearings sound right. I need an instruction manuel to do bearing work. Can you help me out?
    Thanks for your time and effort.
  • 2,382 Answers
Hi, except there is some thing inside the washer that is broken, i would say the drum bearings have started to wear out badly. It's even obvious that the drum bearing is bad since you said it has a grinding or rubbing against something. All you need do is to replace the drum bearing and the noise will stop.....
Posted on Nov 10, 2010
  • Tunde Autos
    Tunde Autos Nov 11, 2010
    Sincerely speaking, i don't know where to get instruction manual for a 1992 washing machine except contacting the company that manufactured it if they still have the manual....
Something is grinding up against the drum so we can't do a spin cycle...probably a coin or something. How can I get to the outside of the drum to check?
You have to separate the front and rear of the tub to get at basket, which is a major job. You might take a flash light and look through the holes in the basket to see what's rubbing.
Sep 26, 2013 | Kenmore HE2 Plus Front Load Washer
My machine seems to be creating "plucks" on garments. I've run my hand around the drum for any "spikes". Any idea why this is happening please?
I'm sorry to say that this is potentially very bad news. The problem you describe is quite possibly because the main bearing on the drum is worn out, allowing the inner drum to "flop about", when this happend, garments can get trapped between the inner and outer drums, causing pulls in the material and stain marks as the material is rubbed hard against the rubber gasket.
To test your bearings, open the door of the machine and by putting a little lifting pressure on the top of the inner drum, attempt to rock the stainless steel inner drum up and down.
The outer drum is mounted on springs and shock absorbers, so it will rock about (and it should do this) but the inner drum should not move up and down in relation to the outer drum. There should be ABSOLUTELY NO PLAY between the 2 drums, even the tiniest amount will mean the bearings have failed.
If the bearings are bad enough then other symptoms will typically include:
A clonking noise as you lift and release the inner drum (this is the inner drum rattling on its bearings and/or hitting the outer drum)
You will have become aware of the spin cycle becoming far noisier recently and possibly even a grinding crunching noise when the machine spins.
The drum may feel like something is crunching or stopping you turning it when you spin it by hand with the door open.
A leak from under the machine, which you will probably be able to trace to the back of the machine, coming from the centre of the drum. This is a result of the failing bearing allowing water to escape through the seal at the rear.
This is NOT a job for the uninitiated DIY enthusiast as it will mean stripping the machine and removing the drum from the chassis, splitting it, removing pressed in bearings and then sourcing and re-fitting new bearings.
To be frank, the cost of a bearing set (if they are replaceable, and most are) will be about ?£20 ($30) or so. But it's a long and horrible job if you haven't done it before. I know professionals who claim they can do a bearing change in under an hour, I've done a few and it takes me about 2 hours by the time I've ripped the machine apart and reassembled it after the bearing swap. A local repairer will probably attend and swap out your defective drum for a refurbished one and then take yours away so he can refurbish it and put it back in his stock. Sadly, this will take the price up to the point where you need to question if the expense is worth it or do you get a new machine instead.
Jul 28, 2011 | De Dietrich LZ9619 Front Load Washer /...
I have a 2002 gmc sierra 2 wheel drive and when I take off initially and when I turn left I hear a grinding/grumling noise.
Loose or damaged Wheel-Bearing causing other parts to rub together, like the brake components or your wheels are too big or shocks weak, or exhaust hanging and are rubbing against something.
Perhaps oil is leaking from your rear axle housing dut to bad seals (check inner of wheels) and around axle housing - remove plug and check that your finger can reach in and touch it. Could be a sign of rear end failure or simply the backing plates on the brakes behind the rotors and the drums (steel disk) sometimes rust on the drums can grind against the backing plates if they are weak or warped (clean this area).
Jun 15, 2010 | 2002 GMC Sierra 1500
The dryer squeals extremely loud when drying. It sounds like metal scraping against metal.It appears the drum may be rubbing against something. I have lubricated all moving parts.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer2_bing.gif Repair Squeaks, Grinding, Clicking and Knocking Noise
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Asker's Testimonial " This should give me an ida of what to look for once I open er up " -
May 27, 2010 | Maytag Neptune MDE5500AY Electric Dryer
The dryer was squeaking when it was on but know it
possible worn bearing.the more wear on the bearing the lower the drum will be.the drum sounds like its rubbing the bottom of the dryer.check for black dust behind the dryer
Feb 20, 2010 | Amana Dryers
My 95 toyota corolla makes grinding scraping noise when going uphill. It's coming from the right front of the car. Almost sounds like it's coming from the breaks or transmission. A mechanic thinks it could...
Bad motor mounts will not usually cause the kind of noise you describe they will cause more vibration to be felt at all times.
Sometimes the brake rotor dust cover plate can rub against the rotor and make a grinding/scraping sound. Raise the car, remove the wheel, and check the clearance between the dust cover and the rotor.
If your shocks/struts are bad the tire could be rubbing against the strut. Check the strut.
Dec 12, 2009 | 1995 Toyota Corolla
Washing machine noisey when drum turning
Hi, Try these out:
  1. Balance the load
  2. Level the machine
  3. Inspect the water pump for a blockage
  4. Inspect the coupling
  5. Inspect the transmission
  6. Adjust the drive belt tension
  7. Check the motor bearings
  8. Check the drum brakes
please rate my suggestion...
May 18, 2009 | GE WJSE3110A Top Load Washer
Creda Simplicity Drier
Sounds like the rear bearing has gone
Sep 08, 2017 | Washing Machines
Broken washing machine
the machine water ceal and bearings must be changed before it spoil the drum.there is small metal under washer drum to give u sine noise if the drum unstable.and if you keep using the the machine,drum get demaged.mostly all front loading machines are like that.the test is,open back cover check if there is rust on the centre shaft,that means leaking throw the ceal and bearing.open the door and try to list up the inner drum if plays means problem with bearings as above.
Jan 08, 2008 | Hotpoint Aquarius WMA52 Front Load Washer
Washing Machines Logo
57 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
