Question about Epson RX620 All-In-One InkJet Photo Printer
Epson Rx620 I have Error - Scanner error occurred. Please See Documentation What should I do as I have no documentation?
  • Anonymous Jun 24, 2008
    scanner error occurred please see documentation
The user's manual said: "Turn this product off, and then back on. Then make sure the transportation lock is released. If the error message still appears, contact your dealer."
If you open the lid, there is a transporation lock on the lower left. Make sure you unlock it before you turn on the machine.
Hope this helps.
Posted on Jul 20, 2008
When I turn on my epson sx510w a get A Scanner Error has occurred. see your documentation. but i dont have documentation?
Dear friend,
This indicates there is a problem with the Scanner assembly.Repairing or replacing will ony solve the problem.
Mar 09, 2011 | Epson Office Equipment & Supplies
Scanner error occurred please see documentation
turn the printer off, lift the scanner, make sure the transportation lock is in the unlock position, if it is in the lock position, toggle it to the unlock
Feb 11, 2010 | Epson Stylus Photo RX620 All-In-One InkJet...
My scanner :makes a loud noise when trying to scan or copy
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} I need more information to offer a definitive solution, but I can give you some information that might help diagnose the problem.
Unless you forgot and tried to use it locked…then unlocked it after, it seems unlikely that changing the ink could directly affect anything related to the scanner. So especially if it still scans and now just makes more noise then before, we can reasonably say it isn’t a faulty locking mechanism and that the gears are probably not stripped, which would either stop it or not. So you’re looking at either something simple like the gear assembly being dry, shifted slightly, etc. or the safety by the lock that makes noise to tell you the device is locked is stuck somehow. The one can be tested by removing the little plastic safety that makes the noise when the scanner is turned on and locked; the other you might be able to test with some WD40 and see if it runs quieter.
Aug 24, 2009 | Epson Stylus Photo RX620 All-In-One InkJet...
Epson Stylus Photo RX630 All-In-One InkJet Printer "Printer Error Occurred" Please see Documentation
Press the stop/clear button then press the maintaince button(spanner) and the ON button all at the same time in that order.That will reset it.
Jul 15, 2009 | Epson Stylus Photo RX620 All-In-One InkJet...
Print error occurred. Please see documentation.
Check status monitor at your OS. Find RX620 adjusment program at indoreset.blogspot.com. Check status from the adjusment program. It is more detail. General error at display or OS status monitor can mean many posibilities error.
Jun 30, 2009 | Epson Stylus Photo RX620 All-In-One InkJet...
Scanner is making a weird noise when printer gets switched on....
Have you looked at the paper to see if there is any stuck in the printer, other than that go and do the same thing as changing your Ink cartages but don't move any of them and set it up again and see if that works.
Rgs
The StickMan
Jan 28, 2009 | Epson RX620 All-In-One InkJet Photo...
ERROR Scanner error occurred. please see documentation
Hi
Open the glass cover on top of printer, check a switch for lock and unlock on left or right hand side of the printer. toggle it to unlock position, turn it back on and check if there are errors still.
Keep me posted.
Nov 14, 2008 | Epson Stylus Photo RX620 All-In-One InkJet...
Epson Photo RX620
I use a bulk ink system which is not Epson so printer did not recognise the ink supply.
I 1) Turned printer off
2) Removerd bulk ink suppy tanks
3) Fitted Epson ink tanks [ dont matter empty or full ]
4) Turn on printer and let it go through it's start up prcedure
5) Do not turn printer off but do ink change procedure and refit bulk ink tanks
6) Do Nozle Check/Clean/Realignment
Bingo sorted
Jul 20, 2008 | Epson Stylus Photo RX620 All-In-One InkJet...
Printer problem
Hi, If you haven't got the service and manual document for the printer go to www.epson.com and download the document from that website.
From your discription of your problem, it sounds as though all of your software isn't installed properly.Try re-installing your software again from disc.
Mar 14, 2008 | Epson RX620 All-In-One InkJet Photo...
Epson RX620 All-In-One InkJet Photo Printer Logo
402 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
