I have given up on loggin into the the device. All I want to do now is RESET everything back to default and rename my network and give it a new password.
  • 3,289 Answers
Most of these devices have a hardware switch to perform a RESET. You didn't include a manufacturer or model, so it'll be up to you to locate this switch. Typically, it is located in a recessed area (so it won't be activated accidentally) and must be held 10 - 30 seconds (again, depending on brand / model / etc.) where upon the device will reboot and be reset to factory defaults.
Factory defaults may conflict with other equipment on the network, so it may be best to disconnect the router from everything except for the local computer before the reset switch is activated. You'll have to reboot your computer (or reset your computer's IP address) after the reset of the router. You'll need to know the factory default IP address, username and password of the router - which is available from the manufacturer for that particular model. After that is obtained, login to the router by accessing the the default IP address in your web browser.
Posted on Nov 10, 2010
I cant loggin consol
At the back of the device is a small hole wich some has the "reset word'. Insert a paper clip for 10 secs and release with the divice on.
Feb 03, 2014 | Port Designs Oring / IES-3242GC /...
Want to reset my password and get back to my original Facebook account
I made a new password before when loggin in how do i retrieve my st and add it to the new email
Mar 12, 2013 | Facebook Social Network
Need to reset password
To reset your VersaLink 327W gateway to the factory settings:
Hold the reset button on the back panel of the VersaLink gateway for 30 seconds.
•All your settings will be lost including network encryption information,
MAC Address filtering information, and any SSID information you have entered.
•The gateway user name and password will revert to the default of Admin as the user name
and Password as the password.
•You will need your user name or password to reconfigure the unit..
Your VersaLink 327W gateway is now using the default settings for the network
configuration. This includes the default SSID and network encryption key.
You must re-configure your VersaLink gateway to match your previous settings
that were assigned to all other devices on your wireless network. Otherwise,
no other network devices will be recognized.
If I could be of further assistance, let me know. If this helps or
solves the issue, please rate it and give a testimonial for my response
Dec 04, 2011 | Westell Wirespeed VersaLink...
Belkin N300 router, renamed network, having many issues with my 4 yr old Dell 1520 connecting to the net, network often say 'unidentified network'. takes lots of fiddling to connect. however,...
The best solution is to delete your network and create a new one
Also reset your Belkin Router to factory default settings.
This would take care of your issue.
If you need suitable assistance you can also get online technical support. I would suggest you to contact TheBestPcDoctor. I get my issues fixed by them.If you need you may also contact them @
www.thebestpcdoctor.com or via 877-407-9229
Oct 05, 2011 | Belkin Surf N300 Wireless N Router
I have lost my network security key. My router is a Netgear
If you have lost it for good your best bet is to reset your router to its defaults and then set a new one. You should find a button, usually red, on the back of the router. Press that for about 30 seconds or until you see the lights cycle. The router will now be returned to its defaults and you will be able to log into it using the default credentials and set it back up. Good luck.
May 04, 2011 | Computers & Internet
D-link dwl-3200ap not given the right default address which is 192.168.0.5 instead give an ip of 169.254.16.219 and no default gateway given, it's blank
Try to reset the network adapter. This can be done by finding the network and right-clicking it and selecting Diagnose.... It should give a few options, select Reset network Adapter.... If that doesn't work, consult D-Link Tech Support....
Jan 08, 2011 | D-Link AirPremier DWL-3200AP 802.11g/b...
Does a 10 second reset on a Netgear router reset everything. Even the password on the network and so on?
it should only set the password on the router
Unfortunately, there is no way to recover a lost or forgotten password from a router or access point; you will need to reset the device to factory defaults. However, once the device is reset to factory defaults, you can use the default username ("admin") and password (either "password" or "1234" depending on your router) to reconfigure your router settings.
or
if there a small hole in the front or back of the router push a hair pin in to reset to factory settings
hope this helps
Jan 02, 2011 | NetGear ProSafe FVG318 (606449041668)...
Can't find wireless network
The router probably defaulted back to its factory settings. Use your manual and reset your router back up. It may be as simple as renaming your router.
Jul 17, 2010 | Linksys Wireless-G WRT54G Router
Password problem. I can not loggin to my acer 5315 laptop.
Try this, open the other account. Go into control panel, User Accounts, then you should see all of the accounts. You can't change or delete the password on the account you are talking about because you have to know the other password to do it..you'll have to delete the account or rename it if possible. If none of that can be done then I'll give you a website that you can download a windows password recovery program.
Apr 13, 2009 | Acer Aspire 5315 Notebook
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
