Question about Casio PRG-40T-7 Pathfinder
Went to change the time on my watch and the word "OPEN" appeered where the date time is supposed to be. No buttons function any more and the time display is still operating. How can I fix this?
  • 2,382 Answers
Hi, open the backside, probably the light switch contact at the six side of the watch (attached to the steel mainframe) may have contact with the electronic circuit.... If that does not fix it, remove the batteries and put them back and if the problem still persist, you have no choice than to visit a watch repairer.....
Posted on Nov 10, 2010
I have bought a couple of lupo watches but there are no instructions so I dont know how to set them to the correct time can you help
This LUPO anion watch emits negative ions and infrared which make you calm. It soothes and relaxes your mind. How to set the time and date: This unique watch can display month, date, time & minute. 1.Press A button twice. (Date and Time displays when press once) 2.When the month figure appears, press M to set the month. 3.Press A button once again, the date figure appears and press M to adjust the date. 4. Press A button once again, the hour figure appears and press M to set the time. 5.Press A button once again, the minute figure appears and press M to set the minute. When you adjust one of among the month, date, time, minutes, just keep press A button until the desired figure appears and press M to adjust. Press M to see the date. Generally A button is to select the function. (Month, Date, Time, Minute) M button is to adjust the function.
Dec 09, 2010 | Watches
How do you set the time on the timex 440 sports watch
Hi markie_d,
To set the digital time and date on your Timex, please follow the steps below.
Timex Digital Watch
1. Press and hold the "Set" button for 2 seconds. The "Set" button is on the lower right side.
2. Press the "Date Advance" button on the upper right side. This will reset the seconds.
3. Press the "Change Mode" button on the lower left to set the hour. The hour will flash. Press the "Date Advance" button until the correct hour is displayed.
4. Press the "Change Mode" button again to set the correct 10s unit (first digit 1 or 0) for the minutes. Press the "Date Advance" button until the correct first digit of the minutes is displayed. Repeat this step to set the second digit of the minutes.
5. Repeat Steps 1 through 4 of this section to set the year, month, date and day and whether to use 12- or 24-hour time for your watch.
6. When finished, press the "Set" button (on the lower right) to return to the current time view and lock in your settings.
Hope it helps.
Thank you for using FixYa.
Oct 31, 2010 | Timex 1440 Nylon watch
I bought an old timex indiglo watch it has a button on the right middle and left bottom, how do i adjust the date?
Thank you for contacting FixYa.
  • Press the button on the lower right side of your Indiglo watch to unlock the mode function of the watch.
  • 2 Press the button on the lower left side to move through the modes. Each time you are in a mode, the digital display will flash. For example, when the time display begins to flash, you are in the correct mode to set the time.
  • 3 Change the time (or date) by pressing the button on the upper right side to advance the numbers or the button on the left side to move the numbers down. When you do this, you will be changing the first set of numbers (the hour or month, for instance); to change the minutes, press the button on the right side of the face until the second set of numbers is flashing and begin the process again.
  • 4 Press the button on the lower left side of the watch to save your settings. The button on the upper left side of the watch is not used in this process--it is the switch to turn on your Indiglo light.
  • Best regards. Jewel
    Sep 08, 2010 | Timex Watches
    Day/Date change
    The date on mechanical and automatic watches change normally between 2-4am because this is normally when people sleep. It is not broken or in need of overhaul. It has to change sometime and that is what they have tradionally used as a time for the date to change. Also remember it is normal for an automatic or mechanical watch to loose or gain time friction is the culprit here since the gears do mesh with each other.
    Fine watches like Rolex and Omega are beautiful watches but expensive to have cleaned. It should be cleaned about every 10 years or if it starts to loose a lot of time.
    Incidently most agree that the Omega speedmaster manual wind (The watch that went to the Moon) is the most accurate of the bunch and is very sought after by collectors!
    Apr 10, 2010 | Guess Dress Bracelet 87000L1 Watch for...
    I cannot change the settings for the day, date
    The depressing the top left buttom will move the watch between functions. Once on the function you want to chane, the bottom left button will select the group to change within that function and the bottom right button will adust the numbers. Hope this helps
    Mar 14, 2010 | Field and Stream F58GGS e by Field &...
    Resetting my Armitron WR330 Watch
    press and hold the ST/STP button then press MODE at the same time and you will see it go from military time to normal
    Sep 05, 2008 | Watches
    Setting time & date on Philippe Starck Fossile watch ph1080
    hold the left, bottom button (marked ....) for a few seconds....then press the top right button (marked with 1 dot) to change between the hour, minute, date etc. use the bottom right button to advance the flashing number, and when finished setting time and date, use the bottom left button to stop the numbers flashing and return the watch to normal. hope this helps, this is also how to change the date for the other question asker (works on 2 other starck/fossil watches i have and i assume the controls are the same).
    Aug 08, 2008 | Fossil Philippe Starck PH1035 Wrist Watch
    Armitron Watches
    From the time telling mode press the set button the seconds will flash.
    Press the mode button the hours will flash
    Press the adjust button to change the hours
    Press the mode button the minutes will flash
    Press the adjust button to change the minutes
    Press the mode button the month will flash
    Press the adjust button to change the month
    Press the mode button the date flashes
    Press the adjust button to change the date
    Press the mode button the day flashes
    Press the adjust button to change the day
    Press the set button when done.
    Mar 11, 2008 | Watches
    Casio PRG-40T-7 Pathfinder Logo
    192 people viewed this question
    Top Casio Watches Experts
    Kazim ERGUNEY
    Kazim ERGUNEY
    Jimmy Accardi
    Are you a Casio Watch Expert? Answer questions, earn points and help others
