Question about Samsung HLP4663W 46" Rear Projection HDTV
My Samsung HLP4663WX/XAA has red and green vertical lines across the entire screen. If this is a board problem what's involved in replacing boards and where is a good place to purchase it/them?
  • 2 more comments
  • cdlucero Nov 10, 2010
    Lines are very thin and are spaced approx. .75" to 1.0" apart but evenly spaced
    Do you have a Part # for the DMD board, and do you know where I can purchase one and what's involved in replacing it?
    Thanks for your help.
  • cdlucero Nov 16, 2010
    A few days ago I requested help on determining the problem with my TV. eagle338 at Fixya.com was extremely helpful in pinpointing the DMD board as the problem. However today I was going to order the DMD board from Samsungparts.com and the sales rep. notified me that the DMD Board (BP96-00678D) does not include the DLP Chip. Since FIxtya.com never mentioned that the DLP Chip might also need to be repaced I'm assuming that I won't need to replace it. However I want to absolutely clear before I order the DMD board.
    Charlie
  • 4,889 Answers
This is a problem associated with the light engine of the unit, most likely the color wheel and/or DMD board. How thick are the lines?
Posted on Nov 10, 2010
  • 2 more comments
  • eagle338
    eagle338 Nov 10, 2010
    Thats just what I wanted to know . You have a bad DMD module. The micromirrors are not reflecting light properly onto the color wheel. Replacing it should resolve the problem.
  • eagle338
    The part number can be found on the board itself. Its always recommended to order by part number as there may be several different versions of the same board. It should cost you around 250$ and is not very hard to replace. There are just a few connectors that have to be remove and the board has to be unscrewed from the chassis.
    Part number will be something like BP96-00678D
  • eagle338
    You are welcome. Thank you for using Fixya!
  • eagle338
    eagle338 Nov 16, 2010
    DMD = Digital Micro-mirroring Device. If this is the DLP chip(manufactured by Texas Instruments) is what you are talking about then yes, it is ON the DMD board.
Samsung TV display has gone out - has audio, but there are vertical, colored lines/bars across entire display.
Call a television engineer. Don't try and fix it yourself it always ends badly and more expensive. Could be a board, a component on a board, a bad connection, or blown capacitors. The course is 2 years full time education.
Apr 30, 2018 | Samsung Televison & Video
Tip
CRT projection TV lost vertical drive. Thin horizontal line only.
Your projection TV works but the only visible part is a thin horizontal line across the screen. What happened and how do you fix it?
Your problem is that you have no vertical drive, only a small horizontal line across the screen. In older projection TVs this is usually caused by broken solder joints in the area of the vertical IC and over the entire board. It could also be caused by a bad vertical IC. Let's approch this problem one step at a time.
Disconnect the power. Remove the back cover. Remove the board with the vertical IC which is usually the board with the high voltage transformer on it and it is usually on the right side of most TVs. You can also identify the proper board by looking for and following the wires from the yoke which is on the CRT neck. There should be a yellow, brown, green and red. The yellow and brown are the vertical wires.
Before removing any wires mark them with a sharpie or a label maker. Just make sure that you will be able to reassemble the unit without mixing up any wires.
Usually the board in question is on the right. It will be the one with the flyback on it. The flyback looks like a small cylinder with about 4 large wires coming off of it. They will be red rubber and flexible. One goes to each CRT.
You will need to remove the entire assembly to get to the underside of the boards to solder the unit or replace the vertical IC. Sometimes removing the restraints will allow enough room to flip the board over and do the work without removing all the connectors and removing the board.
Once the underside of the board is exposed, solder all connections on the boards. Be careful not to bridge any connections. Test the unit for proper operation.
If the unit still does not work properly replace the vertical IC. It usually begins with LA followed by 4 digits. It will be in the vicinity of the flyback probably towards the front of the board. The Ic will be attached to a large aluminim heat sink. Make sure that you do not bridge any of the circuits when soldering. Replace the IC, reassemble and test.
If things went well the unit should work ok.
Thanks for using FixYa and for the great rating. Please consider a testimonial. Thank you.
hardrocko
on Jan 19, 2011 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
How do I get rid of vertical black bars on a plasma television
Fix Panasonic Plasma TV Vertical or Horizontal Bars ...
? 10:21
https://www.youtube.com/watch?v=CpWZTnAXbLg
Dec 30, 2013 - Uploaded by Pet Rock's Garage
This video covers how to fix a Panasonic 42" Plasma TV model TH-42PX600U that has vertical distorted ...
Horizontal black lines on Samsung 50" plasma tv - Forums - CNET ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - This past spring, a thin black horizontal line appeared across the screen, everything else is working fine. Next day ... In reply to: Horizontal black lineson Samsung 50" plasma tv .... I tried a white wash on the TV, but that didn't removethe line. Plasma TV has 3 thin black lines
Jun 11, 2015
Black Line across Samsung 50" Plasma has appeared?
Jun 11, 2015
Vertical black line on Sony PFM-50C1 Plasma Display
Jan 28, 2007
More results from www.cnet.com
Jan 05, 2016 | Samsung Televison & Video
Should the T-CON board be replaced on a Samsung LN40C650 LCD TV to fix the vertical lines problem?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Nov 08, 2015 | Samsung LN40C560 LCD TV
I have a black line on the tv samsung
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
Hope this help......
Jun 22, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
Thin red line, green line and yellow line going across the screen
the problem is vertical collapse,i am not so sure you can trouble shoot this on your own but you can send the board to eithor pts electronics or tristate module for repair
to get a price get the number off the sticker--left hand board(looking from the back) it will start CTC195---- write down entire number before you call them
Sep 02, 2009 | RCA P52926 52" Rear Projection Television
Red blue green lines down my lcd tv screen
HP-R4252 NOT LCD TV
IF LCD TV has vertical lines try cleaning T-con board to lcd panel cable or replaced t-con board
Aug 15, 2009 | Samsung HP-R4252 42 in. Plasma HDTV
Vertical lines across my entire screen
My 42" Samsung Plasma HDTV HP-R4252 has a 2" vertical strip of green pixels down the right side of the screen.
My 3 year warranty with Circuit City expires in Nov 2008.. so I hope I'm covered.. can't call until the morning.
Samsung said it might be a logic board problem.. but they want almost $2000 to fix. I might as well buy another TV if Circuit City can't fix it.
Apr 19, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
Dlp white vertical lines
YOU NEED CHECK THE 3 CRYSTALS ( RED, GREEN AND BLUE). CLEAN IT WHIT "DUST REMOVER" ( compressed gas duster) AND REPLACE THE COLOR WHEEL.
Jan 17, 2008 | Televison & Video
Samsung HLP4663W 46" Rear Projection HDTV Logo
97 people viewed this question
Demonic-2011
Demonic-2011
Steve Allison
Steve Allison
