Question about HP ProLiant ML370 G5 (458341-001) Server
HP ML370 G5 server, no video, no HD leds flashing, fans on systems doesn't stop (lots of noise), no beep alerts, no alerts on iLO diagnostic, what could be the problem?
FreeTech
  • 426 Answers
SOURCE: NO DISPLAY
sounds like a bad mother board, have you taken out the mem and see if it beeps?
Posted on Jun 19, 2008
sksree406
  • 61 Answers
SOURCE: HP Proliant ML370 Server
Remove all the cards except dispaly from the slots,disconnect all  hdds and start the server in minimum hardware and check.reset bios .Is there any LEDs in the mother board is glowing amber or red colour??Please try these diagnostics.
Posted on Oct 31, 2008
sksree406
  • 61 Answers
SOURCE: HP Proliant ML370 Server: Very Urgent Please
Open the system cover and check whether any LEDs showing amber or Red colour
  • 17 Answers
SOURCE: HP Proliant ML370 Server: Led shows red light
Your server definetly has issue booting first of all this is a little old server model so first open and blow air from a blower (&not use vaccum cleaner)
since problem could be anything frm a struck cpu fan or anything
then poer donw theM/c and locate the RAM its a smal hardware in green color vertically fitted to the motherboard it will have locks at the both ends press them downwards the RAM will pop out then clean the side that was inside the motherboard with eraser and nothing else(it might damage the RAM) then fix it as it was aligning the notch it should work
If this does not work out then tell me exct LED and sybol near it
Bye for Now
Posted on Jan 24, 2009
SOURCE: Compaq ProLiant ML370 G3
How big if your environment? How many users? Do you have remote access needs? If your environment is under 75 users then you might want to consider moving to Windows Small Business Server. It's a great little package that includes Exchange with it. You can also get the premium edition which includes Sharepoint.
Don't forget licensing needs during this whole process too. You want to make sure you are covered properly with software licenses from Microsoft when making the migration.
The hardware specs seem adequate but it will depend on the amount of users in your environment and workload for it.
I've included three links to different options for migration:
This link is pretty good to explain using the Microsoft tool.
http://www.petri.co.il/active_directory_migration_tool_usage_w2k_windows_2003.htm
This link provides info on the swing migration which is a bit more popular in the small business arena. Works pretty good. I've done it a few times.
http://www.sbsmigration.com/pages/14/
This link is for Acronis products that allow for easy ghosting or copying of data from one server to another. The good thing about this tool is that your SIDs are kept the same. So I don't know if its a big deal (depends on your environment size) but it can be a pain to rejoin workstations to a domain if new servers are added without successfully moving necessary settings. I've used this tool a few times. It's quick and easy.
http://www.acronis.com/enterprise/products/ATISWin/
I look forward to hearing more from you. Please update me on the questions I asked and if I can help further I will be glad too. Don't forget to rate the solutions once we're done! Thanks.
Posted on Mar 31, 2009
High fan noise
This can be an issue with some dirt that are now on those cooling fan that you have that you will need to clean to avoid further damage.
Mar 14, 2013 | HP ProLiant ML370 G5 Server
On one of our HP DL360 G5 systems every time after soft reboot the server cannot be booted back. This is 100% reproducible also with Cold boot. Can someone help us find what internal component is...
The simplest way is to check Insight Manager. Type localhost:2301 on a web browser locally. Or, servername:2301 for remote access. You need local Administrator password.
Insight is only available if it was set up with a Smart Start disk. It's that pack that comes with all HP servers, but can be downloaded as well. Best practice is always install.
Don' know what IML is, and ILO has no baring to problems.
There is Insight Manager link on specs.
http://h18004.www1.hp.com/products/quickspecs/12476_na/12476_na.html
Nov 12, 2012 | HP ProLiant DL360 G5 Server
My hp ml370 g5 server is not booting when i switch it on i only hear the high sounds of the fans with out stoping till i fed up and power off it manulay . this problem used to happens from time to time...
my hp ml370 g5 server is not booting when i switch it on i only hear the high sounds of the fans with out stoping till i fed up and power off it manulay .
Jun 27, 2011 | HP ProLiant ML370 G5 Server
Compaq Proliant ml370 g2 does not boot, beeping every 30 seconds, no video output. Internal Health LED is RED, Harddisk Health LEDs all green Component Health LEDs all green (RAM Banks are...
hdd fault caused by surge video card failure ram failure hdd failure depends what the beep codes are they are coded the length and duration tells you what the fault is ie three short beeps or two long ones try bleeping computer.com or check out bleep codes
http://h30499.www3.hp.com/t5/ProLiant-Servers-ML-DL-SL/Proliant-ML370-G2-server-strange-beeping/td-p/3221528#.VJgYMsgDQ
Apr 28, 2011 | HP Compaq ProLiant ML370 G2 Server
El proliant ml370 g5 no prende. los leds aparecen de color rojo, los coolers prenden y apagan constantemente
Abre la tapa y comprueba que el ventilador de la CPU está firmemente sujeto y presionando la CPU.
Feb 28, 2011 | HP ProLiant ML370 G5 (458341-001) Server
HP Proliant ML350 G5 wont boot ,just spining.
The G5 Series is fairly new, if you're within warranty, call 1800-okCompaq.
Could be a bad cable, a bad monitor, or bad computer hardware. Any display at all or any beep codes?
On the back, the ml350 G5 will likely have an additional Network interface jack-- this may be labeled ILO. The ILO network connect allows you to use another PC on the same network to access this system (like a remote control via VNC or RDP) even if it won't power up--literally. Inside the ILO page, (you'll need the IP address of the ILO, the default account is administrator, and the default password is listed ona paper tag attached in the rear or on a sticker. If you can get into ILO via web browser: https://ipddress of ilo, you can check the Integrated log, which can shed some light on any failures.
Mar 19, 2009 | HP Compaq ProLiant ML350 G5 Server
HP ProLiant ML370 G5 (458341-001) Server Logo
355 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
