Question about TallyGenicom 2280 Matrix Printer
THS error I am having THS error on the display panel, occasional I have to press the online button before the printer continues printing the print job sent
    Novelist:
  • 169 Answers
The print head operating temperature may need to be calibrated for the operating environment of the printer.
The print head cable may be damaged or incorrectly plugged into the print head or logic board.
The print head may have a fault.
There may be a fault on the logic board or interconnect board
The first thing that I would recommend doing would be to calibrate the print head operating temperature, this can be done in the following way;
·Start with the printer powered OFF and at normal room temperature
·Hold down the ONLINE and SETUP button and power the printer back on
·Keep the ONLINE and SETUP button held down until the display reads ‘PRINT TEMP. CAL’ along the top line
·Press the button under ‘TEMP CAL’ (button 3)
·Using buttons 2 or 3 change the Temp Setting to match the temperature of the room the printer is used in (change this value by at least 1 degree even if it is correct to force the printer into recalibrating.
·Then press SET to save the settings.
Once the Temperature has been recalibrated power the printer OFF and back on again, this should resolve the problem.
If once the print head temperature has been calibrated the printer displays ‘Head Hot’ or alternatively displays a ‘THS’ error this indicates the printer has a hardware fault. The next step would be to identify which part may be causing the problem.
I would recommend first checking the carriage cable to ensure this is not damaged and makes good contact at each end. Then you would need to look at a logic board or print head failure.
Posted on Oct 01, 2009
I am having ths error on the display panel, occatinoal i have to press the online button before the printer can print
Posted on Dec 12, 2008
  • sunky Dec 12, 2008
    pls i need maintenance kit for hp laserjet printer &hp deskjet printer
I have light in this ( !) what that is mean?
If ! light displays a solid light it means that the printer front door is open, print cartridge is missing, or a flash option has been installed that is not supported. Please Close the door, install a print cartridge, or install a supported flash option. The printer will automatically reset.
If ! light and Continue button (green button) displays a solid light, it means a printer error. The printer memory is too full to collate the print job. To continue printing press and release continue button to clear the message. To cancel press and release the X (red button).
You may also press Continue button twice quickly to see the secondary error code. For further assistance, please call Lexmark Technical Support.
Jun 13, 2011 | Lexmark E260D - QTY 4 - LMB OFFER Laser...
Our printer is flashing Tractor1 tear. We are not able to print nor can we get this to quit flashing. I have tried turning it off and back on still having the same issue. Help?
The "Tractor 1 Tear" message is not a error as such, this is an information message showing the printer is set to the front tractor feed (tractor 1) if you press the button directly under "Tear" the printer should move the paper to the tear possition.
If the pritner is not printing I would recomend checking the following;
  1. Ensure the printer is set to "ONLINE" press the button you should see ONLINE TRACTOR 1 TEAR on the display
  2. Ensure the printer is loaded with paper, press the button under "Tear" the printer should move the paper forward if it is loaded into Tractor 1.
  3. If you are not using Tractor 1, ensure you select the paper path you are using within the menu and move the paper selection lever.
  4. Observer the LCD display for any errors that may be seen when print jobs are sent.
  5. Try printing a menu print on the printer this will identify if the printer will print, the menu can be printed in the following way.
    -Power the printer ON holding down the button, keep the setup button held down whilst the printer initializes.
    -When the printer has finished initializing ensure the printer is OFFLINE
    -Press and release the button to enter the MENU
    -Press the button under "MENU" on the LCD display
    -Press the button under "PRINT" on the LCD display
    The printer should print a menu settings page, if this prints OK the most likely causes for the problem are;
  1. The computer system is not sending jobs to the printer (check the correct printer is selected on the computer system)
  2. Connectivity problem (check cabling, IP Addresses etc)
  3. The wrong printer driver is being used
Mar 04, 2011 | Tally T2240/24 Matrix Printer
Error : Hard disk full How to free memory in hard drive of IMAGE RUNNER 400S machine
hai
power on the copier, press the 3rd function key of panel board (lick. PRINT or OPTION/IF)
panel display go to printer mode ........ WAIT....
then ......... GO TO SET -UP YES or NO press NO
then ........automatically re boot the system
then.........display PRINT PAGES
CONFICRATION press CONFICRATION
now.......conficration data senting to print that time display CANCEL JOB, RIP, INFO etc.,
press the CANCEL JOB then YES
now .. old data automatically ereased.
then copier OFF / ON
best of luck.
Feb 26, 2011 | Canon imageRUNNER 400S Copier
When printing I am getting a paper width error
The print job you are printing is wider than the paper, or the pritner is detecting the edge of the paper incorrectly.
You can disable the Paper Width Sensor, but it means that any data which is printed outside the paper area will be lost. You may also print on the platten which may reduce print head life.
I would recomend checking the width of the print job or paper size set on the system.
The paper width sensor can be turned off in the following way
Start with the printer power OFF
Hold down the ONLINE button and power the printer ON
Keep the ONLINE button held down until the display reads TEST MODE then release the ONLINE button
When the display reads ASCII80 ASCII136 press the button under BACK (button 1)
The display should read APW, if it does not keep pressing button 1 until it does
Press the button directly under APW (button 2)
Press button 2 (under the <) to change the setting to read APW=OFF
Press the button under SET (button1)
Press the ONLINE button to exit this test menu, then power the printer OFF and back on again
Once the APW has been set to OFF it is then worth testing the printer to see if this resolves the error.
Feb 18, 2010 | Tally Matrix T2280 Printer
What button do I press to generate a Fax report - this is not always generated automatically.
Sounds like your Fax Options are set to print on error only. If you want to have both confirmations and error pages do the following:
1 Press Menu until “Fax Setup” appears on the top line of the display. Press Enter.
2 Use the scroll button to find MSG Confirm. Press enter.
3 It may be selected to On-Err. Use the scroll arrow buttons to get to On. Press Enter.
4 To return to Standby mode, press Stop/Clear.
This should make your fax print out a confirmation on a successful or failure transmit of your fax.
If you want to print out the last few sent or receive faxes:
Printing a Report
1 Press Menu until “Reports” appears on the top line of the display.
2 Press the scroll arrow buttons to display the report or list you want to print on the bottom line.
•Phone Book: Phonebook list •Sent Report: Sent fax report •RCV Report: Received fax report •System Data: System data list •Scheduled Jobs: Scheduled job information •MSG Confirm: Message confirmation •Junk Fax List: Junk fax number list
3 Press Enter. The selected information prints out.
You can find your manual in English by clicking here.
------------------------------------------------------ Please rate this post if it helps you! :)
Dec 08, 2009 | Samsung SCX 4521F All-In-One Laser Printer
Describe your Tally Matrix T2280 Prion power up
Calibrating the temperature resolves the THS error in most cases.
The ‘Temp Cal’ functions can be carried out in the following way;
· Start with the printer powered OFF and at normal room temperature
· Hold down the ONLINE and SETUP button and power the printer back on
· Keep the ONLINE and SETUP button held down until the display reads ‘PRINT TEMP. CAL’ along the top line
· Press the button under ‘TEMP CAL’ (button 3)
· Using buttons 2 or 3 change the Temp Setting to match the temperature of the room the printer is used in (change this value by at least 1 degree even if it is correct to force the printer into recalibrating.
· Then press SET to save the settings.
If the printer continues to display the THS error, the problem can be caused by;
Incorrectly seated print head
Damaged or incorrectly seated head cable
Fault with Main Board, Interconnect Board or the print head.
Jul 09, 2009 | Tally Matrix T2280 Printer
Unable to cancel print queue
You can cancel a print job from within Windows by going to Control Panel -> Printers and double-clicking on the appropriate printer. Right-click the print job you want to cancel and select Cancel from the context menu. Anything already sent to the printer will continue to print.
You can also cancel a print job from the printer by pressing Cancel on the control panel. This applies to whatever is currently printing.
(You may want to remove any paper from the paper tray first.)
Clicking the cancel print icon stops the job from continuing to spool, but whatever is still in the printer's memory will continue to print until exhaused or the job is cancelled from the printer's control panel.
Apr 14, 2009 | Office Equipment & Supplies
Printhead (R), Check Printhead - Canon IPF5000
that confirms Right Print head is may be Out of Ink or near to low ink level.
check whether there is any option to Disable Alerts in printing preferences..print settings >> printer settings
Feb 18, 2009 | Canon imagePROGRAF iPF5000 InkJet Printer
THS Error on warrantee printer tally serial printer
Apr 09, 2008 | Tally Matrix T2280 Printer
Printout blank
Hi Seng, Run a self test from the printers control panel. 1. Press the printer?s ON LINE button to take the printer offline. 2. Press the Control Panel MENU button until TEST MENU appears on the display. 3. Press ITEM until SELF TEST appears on the display. 4. Press ENTER. The Self-Test will print. 5. Press ON LINE to return the printer to the online state. If it prints than you have a software issue if not it's hardware. For Software Check the Density Settings. Make sure it's not set too light. Also try printing from another app, maybe you have a corrupt print job. If you have a hardware issue come back here and I'll help you sort through those. Let me know, Dude
Nov 23, 2006 | HP LaserJet 4 plus Printer
TallyGenicom 2280 Matrix Printer Logo
549 people viewed this question
Top TallyGenicom Office Equipment & Supplies Experts
Toby
Toby
Level 1 Expert
Kolbrun...
Thomas Charalabizas...
Level 1 Expert
Are you a TallyGenicom Office Equipment and Supply Expert? Answer questions, earn points and help others
