Question about SimpleTech 1TB External USB 2.0 Hard Drive - Gray Gun Metal
I have a SimpleTech Simple Drive Model 96300-40001-001 that was working fine but now there is flashing blue light and I can not access this drive
    Brigadier General:
  • 10,406 Answers
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files.
For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge guarantee".
Posted on Nov 11, 2010
My SimpleTech SimpleDrive Pininfarina 500GB... stopped working
open the hard disk casing remove the drive check it on some other casing
May 06, 2014 | SimpleTech SimpleDrive Pininfarina 500GB...
I have a 500gb simpletech hard drive that I have lost the power adaptor. I need to know what size to buy.
The simplest way is to ask SimpleTech
Your Part number: PRO500Q
Customer Support Phone Number Tel: (949) 477-7700
(6:30AM-5:30PM PST Mon-Fri)
or send them a tech support request at...
http://www.simpletech.com/webspeed/webtech/indextech.php
Aug 11, 2009 | SimpleTech 500GB SIMPLEDRIVE EXT HD-USB...
Simpletech Signature 500gb "is not accessible"
Right click on MY COMPUTER and select MANAGE.
Go to DEVICE MANAGER and expand the DISK DRIVES category on the right side window.
You should see the Simpletech drive listed under there. Delete the Simpletech drive and click on OK. Restart the computer.
Windows should re-detect the simpletech and re-install the built in drivers automatically.
Jun 17, 2009 | SimpleTech 250GB USB2.0 7200 RPM External...
Simple Tech USB Drive will not work
I have a Simple Tech USB Drive that will not work. When you plug it in the lights blink, but you cannot access the drive. How do I fix the drive and get my information out of the drive?
Oct 20, 2008 | SimpleTech (SP-U25/120G) 120 GB USB Hard...
Simpletech external simple drive model 96300-40001-001--flashing blue light
do you mean that you used this as a "Data" drive and do not have the data stored on your pc...
that is basically the same as having no backup... if it is important, store the data in more than one location.
it is possible that a power surge killed the usb adapter on your storage device.... you may be able to transplant the HDD onto a working adapter or USB->HDD bridge to get your data back
Aug 22, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
Can't detect my drive
It could need a power adapter if it cannot draw enough from your usb port. I would try another port on the back of your PC.
Aug 02, 2008 | SimpleTech STORAGE, SIMPLETECH 500GB PIN...
Simple tech 500 gb external hard drive
It is not necessarily the hard drive itself that has failed. More likely it is the enclosure and the hardware within in that enables you to access the device. The only way to know for sure, is to connect the hard drive inside your PC and see if you can access it. If it accesses fine when inside your PC, you should be able to buy a new enclosure for your drive and be back up and running with very little effort. If the drive cannot be accessed when hooked up inside your PC, it is unfortunately dead.
Good luck
Jun 28, 2008 | SimpleTech Computers & Internet
Simple tech 500gb usb hard drive
Youve damadged the harddrive, is the harddrive spinning or making any noise?
Jun 16, 2008 | SimpleTech SimpleDrive Pininfarina 500GB...
SimpleTech 1TB External USB 2.0 Hard Drive - Gray Gun Metal Logo
381 people viewed this question
Top SimpleTech Computers & Internet Experts
Marvin
Marvin
Joaquim Martins
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
