Question about Tag Heuer Formula One
Crown stem is broken how do i repair - Tag Heuer Formula One
98b104 crown broken
best to go to a bulova dealer to get the original fitted as its most likely the stem is sheered of inside the old crown if however it has just unscrewed from the stem any good watchmaker should be able to refit it and reseal it
May 08, 2014 | Bulova 98B104 Mens Watch Gold Tone...
Hello I have two nixon men's wrist watches that
just bring your watch to Nixon watch experts. they have spare and tools to repair your watch.
Jul 14, 2011 | Watches
The stem broke off of carrera watch. How much should repair for this problem be?
mcdevito75 here, A new stem and crown Approx. for your Tag Heuer, $125.00 that"s if the stem is broken, if the stem just pulled out it may be able to be saved. Check here at fixya, bottom of page, click on repair service directory the watches.
Jul 03, 2010 | Tag Heuer Automatic Chronograph Series...
Unable to reset brietling colt, even after ajusting stem to 1st and 2nd postions.
mcdevito75 here, Let"s hope your description of the problem with your watch is wrong. Try this sequence, First, wind your watch, the automatic continues to wind your watch when you where it but to get it started, wind it 20--30 times. 2nd, your crown locks down, turn the stem Clockwise to un-lock it (the stem) now pull the stem all the way out then back in 1/2 way to set date. Set DATE to DATE before the real date turn crown counterclockwise. Now pull out crown all the way and turn clockwise to set the DATE and time (real Date) push the crown back in and turn counterclockwise to lock the crown. If this doesn"t work, look for a small watch repair shop in your area for this adjustment.
Jun 28, 2010 | Breitling Aeromarine Colt Ocean A64350...
Stem falls out
It can happen to ANY watch! Take it to a reputable watch repair shop and let them fix it....just needs some loctite but the stem needs to be removed from the movement so the crown can be correctly put back on!
Jan 13, 2010 | Invicta Watches
Screw down crown wont lock
There are only two things that can cause screw down crown to malfunction. First is dirt and second is weakened/damaged thread. In first case you need to use ultrasonic cleaner by immersing the crown AND case to get rid of any dirt and grime sticking on both threads. If the matter is weakened/damaged thread - you will have to fit new crown and (possibly) new case tube on which crown is screwed onto. This can be done by decent watchmaker only.
Rate me, plz.
Jan 06, 2010 | Watches
My crown fell off the stem of my Gucci watch. How
If you still have the crown you may be able to put it back on yourself. However for a secure repair you would need a watchmaker to repair this.
To try yourself get some RED locktite (available at any Ace hardware store or automotive store) Put a small amount on the threads of the crown. Then screw the crown onto the stem as much as possible.
Let it sit for about 10 minutes so the locktite can cure. Then you can try using it to set the time or whatever.
If this does not work you will need a watchmaker to repair this.
Prices to fix this would vary.
Hope this helps.
Ken
Yellowstone Watch Inc.
www.yellowstonewatch.com
Nov 01, 2009 | Gucci G Watch ladies' YA100510
Winder is lost
You need a replacement stem and crown. I would replace the stem just to be sure you arent putting a new crown on a damaged stem.
Sakgen is very good about repairing their watches. Unfortunately this doesnt fall under their warranty but the repair directly through them is an average price for this part.
Generic after market crowns are also available at local watch repair shops. Make sure that if you go this route that you select a shop that can reseal the watch to is water resistance rating so you do not void your lifetime limited warranty on the movement. This mean they must have a pressure testing chamber and be able to supply printed proof of resealing.
Sep 23, 2009 | Skagen 355LGSC Wrist Watch
I pulled on the crown and it came off the stem
Do not open the watch yet, as you do not know how to get the stem out.
Take an eyeglass and examine the crown. You will find the small hub in the centre of the crown. If the centre of this hub is hollow and you can see the thread in it- you will be able to screw it back on stem (all watch crowns are screwed on to stems, never pressed).
If the centre of that hub looks filled with metal, then the stem end is broke and you will need replace stem AND crown (the metal filling the hub is the broken end of stem).
In case if the crown still in tact, let me know by asking questions and I'll guide you through all the process HOW TO.
Rate me, please.
Mar 24, 2009 | Watches
Broken stem off aromen gobletover 50yrs old maker bleirristall made in bavaria.germany 24% clear stem any chance of repair have broken pieces was my Mothers passed away meens the world to me please help...
Is the stem broken near the crown? Or do you think there is enough stem to take out of crown? If not you probibly will have to go to a watchmake (NOT a watch repairman) to make you the stem. If there is enough metal to take stem out of the crown you may be able to get someone to solder the stem back together. I do that reguarly with stems that are vintage, and I don't want have the time to remake the whole stem. Let me know. Good Luck!!!!
Jul 09, 2008 | Watches
Tag Heuer Formula One Logo
229 people viewed this question
Top Tag Heuer Watches Experts
Jimmy Accardi
Are you a Tag Heuer Watch Expert? Answer questions, earn points and help others
