Question about Tissot T-Touch T33159851 Wrist Watch
Hello, I just open my Tissot T-Touch Expert because the push-buton for display activation stert to dosn't work and I remuve and put back the battery and now the watch doesnt work any more. Please can you help?
  • 3,083 Answers
I found another fellow on the web that changed his battery out, then it wouldn't come on, and he took it to a watch repair service, and they informed him it would be more to fix than buy a new one.
I suspect that the push button switch was orginally dirty, or partially oxidized, but it's also possible that the battery contacts, themselves, are oxidized. I would normally advice taking it in to an expert, since this is an upper end watch, and see what they think. If they feel the cost would be too much, I would try to take apart, and clean the battery contacts inside the watch with a qtip and alcohol, and then spray a bit of electrical contact cleaner on the push button switch (they're hard to get out to clean, and I just spray them).
I would at least have a jeweler check it out and give you an estimate or advice, then go from there.
Good luck, and hope this helps.
Posted on Nov 11, 2010
Hello i have replaced the battery on my tissot t touch expert & display not working? Any suggestions. Battery was completely dead before change?
If the battery was dead too long the fumes from the battery might have damage the electronics and that's not good it will have to go back to tissot for a new movement What I'm going to tell u is very inportant. Never let a watch set dead I don't care if it's a windup or an automatic or even a battery watch. U must always keep the running because all the lubriactions will set up and not performed properly. Just like a car setting dead too kind In ur case the battery has cause the problem
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gerald_b9936683ef6d97c6
Apr 22, 2017 | Tissot Watches
T-touch dont display altimeter, meteo and thermo. How can i reset it ?
I have the same problem with my t touch one, the first model with round push button, after take it to a battery replacement and service, and ask a tissot representative store, I receive two answers and both says that I have to change the movement... means ... the machine, and if is under warranty will be free, is maybe 6 or more years old so no more warranty, sad but true, I let it be. I will not spend at least 400 USD. to do it, so, try to enjoy the rest of functions left and a nice looking watch.
Oct 28, 2013 | Tissot T-Touch T33759851
Reset a t-touch expert
Shortcut battery with AC contact. AC can be found on the sides of watch movement(very tiny). You have to use pointed tweezers: one end on battery+, another on AC contact for three secs
If you take a jeweler's lupe near where the arrow is you will see the word "reset" in the plastic.
There is a deep hole in the plastic with contacts below. That is the reset, and that is why you must use very sharp pointed tweezers to make contact with the back of the battery.
I think if you do not have sharp tweezers, you can probably put a sewing pin down the hole, and then connect with a small screwdriver to the back of the battery
Jan 30, 2013 | Tissot T-Touch T33159851 Wrist Watch
Tissot t-touch battery problem
How do I reset my tissot t touch expert
Steps to Synchronize the Hands
  1. Press the centre pusher (T). The watch should beep once.
  2. Touch the centre of the touch-sensitive face until opt appears, in opt select 24H Cm (or 12H Fft or 24H Fft or 12H Cm) is shown in the digital LCD display.
  3. Press and hold the centre pusher (T) for approximately 5 seconds. The watch will beep once and then again, a second time, after 5 seconds have passed. After the second beep, the digital LCD display should read SYNCHRO. If not, return to step one.
  4. Press the upper pusher (+) to advance the hour hand until it is positioned exactly at 12:00. (PH press T button to to switch to minute hand adjust)
  5. Press the lower pusher (-) to advance the minute hand until it is also positioned exactly at 12:00.
  6. When both hands are aligned together and pointing directly at 12:00, press the centre pusher (T) to save the setting. The hands of the watch are now synchronized
Jan 29, 2013 | Tissot T-Touch T33159851 Wrist Watch
How to reset the tissot touch expert? After battery replacement...
hello my tissot watch clock hand are not schronize on the digital number
Dec 13, 2009 | Watches
How to reset tissot t-touch after battery replace? I could not find the AC point,there is many points under the battery but not accsessible when the battery is inserted.
AC point is not located under the battery. It is at the edge of movement. Get an eyeglass with good magnification and you will find it.
Rate me, please.
Aug 06, 2009 | Tissot T-Touch T33159851 Wrist Watch
Hi guys, my Tissot Touch watch has a non sinc problem with the digital and analog time. any solutions? thanks, Rodney
The Tissot Touch watch is expected to need "SYNCHRONIZTION" periodically. (that is, to synchronize the digital and analog portions.) The Tissot manual tells how to do this. This manual came with your watch and is available online from the Tissot website.
good luck, Rodney
Jun 30, 2009 | Tissot T-Touch T33159851 Wrist Watch
Activate T Buton gose to Alarm function.
As with many watch manufacture houses novadays watch technology differs from house to house. Tissot is no difference as T-series watches was developed by Tissot itself.
You have to follow the steps one by one as instructed in your watch manual. Probably you will need reset your watch completely, depending what actions you've allready done.
In case if you lost your watch manual, go to www.tissot.ch and find out everything you need.
Regards
Arthur
Dec 16, 2008 | Tissot T-Touch T33159851 Wrist Watch
Tissot T-Touch T33159851 Wrist Watch Logo
171 people viewed this question
Top Tissot Watches Experts
Ansel Alberto
Ansel Alberto
Mohamed Ismail
Mohamed Ismail
Are you a Tissot Watch Expert? Answer questions, earn points and help others
