Question about Canon imageRUNNER 2200
Got this imagerunner 2200 used and am trying to set it up to network scan, how or what do I need in order to do it?
  • Canon Expert
  • 231 Answers
For windows/Mac user:
instal driver on PC/Mac, instal Canon Network ScanGear software, setup ip to Canon iR2200. Run Canon Network ScanGear software, try to connect to copier. Use a software (adobe) to scan with the machine.
Posted on Nov 11, 2010
Email to scan setup canon c5051
You need to setup your printer using smtp setting.
O365 need an authenticated and secure connection to work. All requirement must be met to be able to use the SMTP services.
Server: smtp.office365.com
Port : 587
Encryption : TLS
For authentification use your username and password of your office365 account.
If your printer does not have TLS, you wont be able to configure it using office365 smtp
Dec 04, 2013 | Canon (6981A002AA) for imagerunner 2200,...
What program I need to scan files from printer iR 2200
you can use adobe /word/photoshop or any other software that supports scan input.
and u have to get the scan gear tool download first as this is a network scanner and only works in network
Jun 30, 2011 | Canon imageRUNNER 2200
Canon IR3300 Scanner
1) install Network ScanGear software from canon officiall site, search under ir 3300, and among all drivers there is scangear too.
2) when you install scangear, open it and press discover button, but the light scan on copier must be on, and set on ONLINE.
3) Then over eg. word2003 go to insert-pic.-from scaner or cam.-choose scangear- custom insert.
Jun 14, 2010 | Canon (6981A002AA) for imagerunner 2200,...
Unable to scan document
try to add your printer so that you can scan, just click start of your computer then go to all program the add printer or scansoft then restart your pc to take effect
Jun 30, 2009 | Canon (6981A002AA) for imagerunner 2200,...
Canon 2200
Unfortunately the IR2200 cannot scan to email etc. It can only do pull scanning using the Canon Network Scangear Tool (google it and download from Canon website and read the manual).
The IR2200i however can scan to email using Universal Send.
May 23, 2009 | Canon (6981A002AA) for imagerunner 2200,...
Networking imagerunner 2200
First, plug the printer into the network with an Ethernet cable. Then, go into the configuration page on the printer's display and print a configuration page. Look for the IP address. When you have that, go to the computers that need to connect to the printer. (Note that this tutorial is for Windows XP, I am not familiar with Vista but this should give you a basic overview.) Go to Start > Printers and Faxes. Click add a printer on the left hand side of the window. Select a Local printer attached to this computer, and unselect automatically detect. On the next page, click create a new port > TCP/IP port. Type in the IP address of the printer. Then choose the driver you are going to use, you should be able to find the IR 2200 driver under canon pretty easily. If not, go to canon.com and download their drivers. Once you do this, print a test page and it should print. You are then fully configured.
Please rate, Thanks!
Jan 21, 2009 | Canon (6981A002AA) for imagerunner 2200,...
Canon ImageRunner Scan feature won't connect to network
its waiting for the command from the computer. in order to use scan you have to down load the canon scan tool from imagerunner.com / support/ downloads/ office products/ then canon network utilities. look for network scan gear tool ... down load save open run setup then open the program and you can either let it search for a scanner or you can put in the IP adress for the copier. then under your scanning software ( ADOBE PRO) eg. you selesct the scan gear tool as the scanner. to scan a doc you put paper in feeder select scan online then from your computer tell your software to scan good luck
Jan 02, 2009 | Canon imageRUNNER 5000 Copier
Can not scan documents using Canon Image Runner 2200
you need to down load the network scan gear tool www.imagerunner.com support downloads office /production then look for canon network utilities... down load scan gear tool [ not color}this file will have to be unzipped then run it... this will set a program in your program files open the one that says scan gear tool when opens either type in the device ip adress or you can select discover. once you do this you select it as the scanner in your scanning software Adobe Pro etc. you also must select scan on the copier then online before scan will happen
Dec 12, 2008 | Canon imageRUNNER 2200
Unable to send scanned document
What error code are you getting? Try to scan again and let it fail. Press system monitor, scan, log. Look for jobs with Result of NG. Highlight one and press details. At the top, look for Result: NG (####). It will display an error number there. What is that error number?
751 cannot connect to server
7xx cannot connect ...
8xx could connect, but error...
801 bad user/pw or firewall
802 user/permissions
899 unknown if successful, may be normal
Check additional functions, system settings, network settings, email/ifax settings. Check SMTP server IP and authentication / encryption.
Ignore POP or recieve options as they are for IFAX.
Nov 18, 2008 | Canon (6981A002AA) for imagerunner 2200,...
My Canon Imagerunner 2200 won't scan.
Sorry that was actually me...after i posted...it asked me to register...so i did.
Okay, you need to download Canon Network scangear from the Canon website. then take your document...put it on the top feeder...turn you scanner online...open up microsoft word 2003..insert, picture....from scanner or camera select network scangear....custom insert....then scan. The machine needs to be hooked up to a network...but note...a simple cross over cable or usb between pc and the photocopier will not work.
Oct 22, 2007 | Canon (6981A002AA) for imagerunner 2200,...
Canon imageRUNNER 2200 Logo
363 people viewed this question
old marine
old marine
