Question about Acer Aspire One PC Notebook
I'm connecting to a tv with a VGA cable from my Acer netbook. My tv says No Signal. Windows makes the "ba dum" sound when I connect/disconect the cable, but under my display settings, it doesn't show the TV as a monitor. I have two monitor choices (1 identifies as the netbook's screen, I don't know what 2 is) that do not change when I plug in the VGA cable. help please?
  • 565 Answers
Don't forget that the TV source or input needs to be set to "PC". Once that is done turn the netbook OFF, then plug the VGA cable into the netbook and start the computer. The computer screen should automatically show up on the TV.
Posted on Nov 10, 2010
Acer netbook sound not working when connecting tv
LOL, nope, that's the way it works. The sound will come from the netbook. If you want the sound to come from the TV you will need to run a audio cable out of the Netbook's Headphone Jack to the RCA input Jacks on the TV.
Bascially you will need a cable with a 3.5mm Stereo Male end for the Netbook headphone Jack and the other end will have 2 RCA Male for the TV's Audio Jack.
You can buy them at:
http://www.cablewholesale.com
just look for audio cables
3.5mm Stereo Male to 2 RCA Male
They are real cheap 6 ft. less than $2.00, 12 ft. less than $3.50
You can get 25ft or 50ft also
Apr 10, 2012 | Acer Aspire One Netbook
I have an Acer one aspire but cannot link this to my HD tv, I have bought a VGA to component cable but it will not display image even though I press the FN key and F5. it works on a smaller TV via VGA to...
A VGA to Component cable is used only in special monitors - it won't work on tv's because the signal is completely different between them and the tv can't decode it: in the VGA you have an RGB signal with separate synchro while in the Component you have a Luminance signal with integrated synchro and 2 colour difference ones. So a converter is mandatory , one like
http://www.electronicsshowplace.com/hdmi-converter-p-251440.html
Aug 17, 2011 | Acer Aspire One Netbook 8.9" Notebook
What cord do I need to connect my acer notebook to the t.v for netflix
this is pretty easy. Since you're acer aspire doesn't have an HDMI out port, then you're gonna need a VGA cable to connect your acer's video signal to the TV.
This cable should do: http://www.amazon.com/10ft-Resolution-mo...
Now, since it's not HDMI, you won't get audio coming out the TV, only your laptop. But if you want audio out your tv, all you'll need is audio cable, which you can connect to the headphone jack (audio out) and then into the AUDIO IN jack on your tv.
the audio cable: http://www.amazon.com/Cables-Unlimited-A...
After this, just hook it up while your tv is turned on, switch to the VGA channel on your tv, and a window should come up on your tv asking you to configure the settings. For audio go to the control panel while the audio cable is hooked up, go to sound settings, and switch the default audio to speakers, or headphones, im not so sure what it is on a netbook
Aug 16, 2011 | Acer Computers & Internet
What cable do i need to connect netbook to my tv?
You need a VGA cable typically or maybe even a HDMI cable it depends on the connections your TV AND your netbook have. Typically you will use VGA though thats how mine is connected. Once you have it set up though do not forget about sound. VGA does not send sound through your speakers on your TV. You will need seperate speakers or an audio input on your tv through your netbooks head phone jack.
Ebay sells they for pretty cheap I would look there first.
LIke this if it helped YOU!!!! Please!
May 16, 2011 | Televison & Video
How do I connect the Acer netbook to the TV?
The only option is using the VGA port on the Aspire One to hook it up to the TV.
Your TV must have a VGA in port for your to be able to hook your computer to your TV. All you need is a regular VGA cord.
Mar 26, 2011 | Acer Aspire One Netbook 8.9" Notebook
I am using an acer aspire one netbook on xp. i can not make the external monitor that i attach to the serial port to work. is just shows, "no signal" When i press fn f5, it still won't work. please help.
Hi, Could you please post the Model Number of the computer.Are you trying to connect using a VGA cable or a HDMI ?Fn+F5 key combinations are used to toggle the display between the laptop and the External Monitor.Try these steps
1.Remove all cables,Turn OFF computer and Monitor
2.Start the computer and wait till it boots to windows nrmally.
3.Start the Monitor,then plug the cables between laptop and Monitor.
4.Check with Fn+F5 to toggle display
Jun 30, 2010 | Acer Aspire One Netbook 8.9" Notebook
Connecting my netbook to my tv
Hi
You will need a male to male, 15 pin D-SUB VGA cable to connect the webbook to the TV. You also have to make sure that your television supports such a connection. If not and it has side AV then you can get a male to RCA VGA cable.
Then you will need an audio cable as VGA does not carry a an audio signal. You will need a male to male mini stereo jack.
Connect the VGA cable to your computer and then to the TV. Then plug the audio jack into the headphones socket of the webbook and to the PC IN or audio in on the TV.
Turn the webbook on and if you have to use the Fn key and one of the F keys to switch screens (it usually does it automatically but the keys are usually between F4 and F7)
Regards.
Feb 09, 2010 | ASUS Eee PC 900HD Netbook
How do i connect my acer pc to my 42 in jvc hdtv
You have to purchase a good quality 3DFX video card to ba able to hook into TV
Jan 20, 2010 | Acer ASPIRE T180-UA381B DESKTOP PC
I have connected my old dell laptop to this TV with VGA cable and audio cable and it worked with no problem. Have new Acer Aspire one netbook- connected to computer with same cables - can see windows...
First, you want to make sure the laptop's internal/external display mode is set properly. On Acer netbooks, this is usually changed by holding the "Fn" key, and pressing "F5". Either the TV or the computer display should flicker when you do this. There are 3 modes:
1 Computer only
2 TV Only
3 Computer and TV
If changing between thos emodes doens't work, continue on.
I am going to assume you are running Windows XP. Please correct me if I am wrong.
To display your desktop on an external monitor, you'll need to change/check some settings. Your netbook is most likely attempting to set it's display settings automatically, but it is expecting a computer display, not a television, so the resolutions and refresh rates are conflicting. That's why it will only display on one and not the other. Before Windows loads, the netbook is using a very low resolution,so it displays on the TV. Once Windows loads, it switches to some non-standard resolution that your TV cannot display and defaults back to your netbook screen.
The solution is to find a resolution that your television will display:
1.Right-click the desktop, and then click Properties.
2.In the DisplayProperties dialog box, click the Settings tab.
3.Click the Display list and select your external monitor (..the TV. It will most likely be display #2).
4.Select the Extend my Windows desktop onto this monitor option.
5.Select 640x480 in the "Screen Reolution" section for Display #2.
6.Click Apply or OK.
Note: If you see the background change on your television, mmove your mous there to make sure it's working. If it DOES work, go back to the "Screen resolution" section for Display #2 and find the highest resolution your television will display
Sep 19, 2009 | Westinghouse SK-32H540S 32 in. LCD TV
Transfer dispaly to external monitor
use your fn key together with f4 from your keyboard. it will display to your monitor.
May 25, 2009 | Acer Aspire One Netbook 8.9" Notebook
Acer Aspire One  PC Notebook Logo
420 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
