Question about Dyson CRO1 Front Load Washer
Overload affected performance. Even when only got 1 item in machine. Makes lots noise when spinning and inner large plastic seal looks like something caught on it and shredded some of plastic.
  • 27 Answers
This fault can be caused by the drum halves becoming tight .they move together due to limescale deposits between the drum spiders. the noise is most likely a failing drum bearing
if the plastic seal is damaged then it will need a new drum assembly
they are no longer available from dyson due to supply problems
you may be able to get another machine from ebay and fix yours using parts from each machine to make one good one
Posted on Dec 04, 2010
Drums not turning sounds like it's spinning on spin cycle but its not moving
Posted on Jun 04, 2011
Frigidaire front load washer model GLTF1240ASO makes a loud noise durring spin cycle
Most likely the drum bearings are gone, especially if you have some play. You need a bearing and seal kit which is fairly inexpensive but it is a pretty big job. The entire inner drum must come out so it requires the disassembly of quite a bit of the machine.
Jul 09, 2013 | Washing Machines
Whirlpool model #WFW9150W front load washer. Washer makes lots of noise when operating
If it sounds like a freight train in spin cycle most likely it is your bearings. If it makes a clunking noise during the wash cycle you have a broken support. The best way to tell is to spin the basket by hand and listen for the noise. Check to see if the basket is making circles and not ovals. Pull back the rubber seal and look signs of the basket rubbing against the outer plastic tubs. If is either one of these it is cheaper to buy a new washer than to fix it. Fixing it involves rebuilding the machine. If it only makes the noise when it starts to drain you need to check your pump for foreign objects.
Jul 12, 2011 | Whirlpool WFW9150W Front Load Washer
When it spins, the washer makes a loud noise. it rattles. Also when it is doing the rinse cycle I can hear a vibration/rattling noise.
I'm sorry to say that tis is potentially very bad news. the problem you describe is almost certainly because the main bearing on the drum is worn out, allowing the inner drum to "flop about".
To test your bearings, open the door of the machine and by putting a little lifting pressure on the top of the inner drum, attempt to rock the stainless steel inner drum up and down.
The outer drum is mounted on springs and shock absorbers, so it will rock about (and it should do this) but the inner drum should not move up and down in relation to the outer drum. If the bearings are bad enough then symptoms will typically include:
A clonking noise as you lift and release the inner drum (this is the inner drum rattling on its bearings and or hitting the outer drum)
You will have become aware of the spin cycle becoming far noisier recently and possibly even a grinding crunching noise when the machine spins
The drum may feel like something is crunching or stopping you turning it when you spin it by hand with the door open
A leak from under the machine, which you will probably be able to trace to the back of the machine, coming from the centre of the drum. This is the result of the failing bearing allowing water to escape through the seal at the rear
Jul 07, 2011 | Maytag Washing Machines
Hi I have a Hotpoint WD61D washer dryer and during the spin cycle of the wash the machine makes an almighty racket. Sounds like something is broken or loose inside and often it sounds like there is a...
Hello.
From the symptons you describe, it is 1 of 2 possibilities that is causing the problem.
1- the main drum bearings have collapsed, thus causing excessive movement on drum, this is turn allows the drum to catch the outer plastic drum, thus breaking pieces of it off.
2- The main drum shaft has fractured, causing the drum to turn off center, again causing the inner drum to catch the outer drum, and breaking the plastiof the outer drum.
Either way, it entails a strip down to determine problem, and at the age the washer is, I would not cosider it a viable repair, as either way, it will be a repair bill in excess of well over a £100.00,and could be a lot more if the plastic outer drum has to be replaced, which is a distinct possibility.
Take the plunge, and treat yourself to a new washer.
Feb 19, 2011 | Washing Machines
Hello: I have a Whirlpool GHW9400PL0 front loading washer. When I look under the front seal looks like an inner stainless tub inside a plastic tub. The edge of the plastic tub is all chewed up and machine...
if you contact whirlpool they might help but the bearings that help that stainless steel drum spin smoothly are gone and because its bounced around a bit it shredded the plastic tank its about $400 for the parts to do this job and every single part comes off and back on it takes experienced guys that do them every day about 2 hours of struggle and pain to do it. i would highly reccomend a new machine in this case.not worth it
Jan 10, 2011 | Washing Machines
Wfw8300sw01 - makes loud noise sounds during spin
The bearings have collapesd due to the seal going faulty. If bearings can be accessed to from the outside, it is possible you could do the repair. If big bearing and seal is accessed from the inside, suggest tech. do it as it gets dirty and a lot more complex.
Sep 20, 2009 | Washing Machines
I replaced the coupler between gear box and moter and the cogs in the agitator now when spinning out the washer makes grinding noise
Murph!
Good job on the coupler and agitator cam! Way to go!
Now for the grinding noise... I assume that it wasn't making that noise before you worked on it, right? (except for the noise it makes when the coupler has failed. It make a kind of grinding noise, too.) So I'll assume that this is a different grinding noise.
2 things will cause this in "spin".
1.) Something is caught between the inner and outer tubs. Since you've had the cabinet off, you know that there is a perforated steel inner drum (the one with holes in it) and a plastic outer drum to contain the water. I've seen nails, paper clips, etc... get through the holes of the inner tub and get caught there. When the unit goes into spin, the object will spin along with the inner tub and rub the outer tub making a scraping/grinding noise.
To find out if this is the problem, remove the agitator again... yes the entire top and bottom portions of it. Now CAREFULLY inspect the inner tub and look for anything that may be stuck in the holes. It'll be small, so use a good flashlight.
2.) The "drive block" has cracked/broken and allowed the inner tub to drop to the point that it's grinding on the outer tub base. This one is a bit more intense than the fix above. If you would, please verify that there's nothing in the inner tub before we proceed to the next step.
Note----> I don't doubt that you can't handle the next repair. It's just that I want to eliminate the simple stuff before moving to the more complex stuff.
Let me know what you find, OK? Also... BEFORE you remove the agitator, look at the distance between the bottom of the agitator and the base of the inner tub. Use your finger for measurement. You should NOT be able to fit the tip of your finger between the two. If you can, write back 'cause then we'll be going into the drive block (#2) repair.
SG
Apr 15, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Makes a lot of noise while spinning.
FIrst look for something between the inner and outer tub, like a screw nail or bobby pin.
It could also be a tub bearing.
is it a front loader, or top loader. How old, make, model?
need more info
then feel free to ask more questions.
Jul 08, 2008 | GE Washing Machines
Makes a noise like there are rocks or coins when it spins
If it is thumping... you have a broken spider on the inner stainless steel drum. Major defect with this machine. You'll need to call to get a new washer tub assembly... comes complete with inner stainless steel drum and outer plastic drum already assembled and ready to install. Good luck.!
Jul 01, 2008 | Frigidaire GLTF1670A Front Load Washer
Washer problems
Open the door, pull back the door seal then grab the plastic outer tub with one hand and the inner basket with the other hand. If you can lift on the basket and wiggle up and down, the tub bearing is bad.
Jun 19, 2008 | Frigidaire ATF6000ES Front Load Washer
Dyson CRO1 Front Load Washer Logo
295 people viewed this question
Top Dyson Washing Machines Experts
Starnley Johnwells
Starnley Johnwells
Gerry Harvey
Gerry Harvey
Are you a Dyson Washing Machine Expert? Answer questions, earn points and help others
