Question about Car Audio & Video
Ok i am putting in a alpine head unit in a 99 neon i can get it to hold the memroy i have to put the red and yellow wire together and do the same on the wiring bracket and when i put all for together the radio comes on but in i cut the car off and cut it back on i have to reset the radio sations all over again
    President:
  • 624 Answers
The yellow wire must be connected to a constant voltage source. You have the red and yellow connected to a voltage source that only gets power when the car is turned on. The yellow wire is for the memory. Check the fuse box for a fuse that has voltage on it when the car is off and the key is not even in the ignition. That is the type of connection the yellow wire needs. The red wire can stay connected to the place it is at now.
Are you using a harness that is made for installing a radio into a 99 neon? They sell them at most all places that sell car stereos. Go in and ask for an installation harness for your car and then you connect it to the harness that comes with your radio by matching the colors of the wires and you have a nice and easy install. It plugs right into the factory harness with all the connections you need.
Posted on Jun 17, 2008
Radio will not hold sirius signal have to keep getting it refreshed
does it hold any memory, ( i.e BASS / TREBLE settings etc...?)
if not, pull the head unit out & swop the RED & YELLOW wires over, either by cutting them and re joining them red to yellow & yellow to red, or by pulling them out of the ISO block & switching them over..
Feb 13, 2014 | Alpine CDE-HD138BT - Single-DIN CD/MP3...
I own a 1999 pontiac grand am gt. I was hooking an amp up to a set of subs and got everything to work. When I finished and put my dash back together it all stopped working. My head unite (alpine cdm-7871)...
Get a multimeter cheap on ebay ,and test the red (positive wire from the radio with the key tuned to on position. should read 12v.. Key off should have 0 volts. Then check the yellow wire, should read 12 volts continuous with the car on or off. If you don't get a reading from yellow wire, you can run it from the battery into the car. Red, you would have to run from the fuse box and should only have electricity with acc on (key in ignition) If both red and yellow wires read 12v. you could have grounding issues. Use the black wire from the head unit and wire it to metal. These are the only 3 wires you have to worry about.
Sep 05, 2013 | Car Audio & Video
Alpine cde 9841r loses memory and doesnt come on automaticaly
The yellow wire from the head unit must be connected to continuous battery power--not to the accessory wire. The red wire from the head unit connects to accessory.
Dec 31, 2011 | Alpine Car Audio & Video
I'm trying to install an older model alpine cd player in my boat. When I attached the red wire without attaching the yellow wire I don't get power to the unit, when I attached the red and yellow...
The red wire will be for constant power and the yellow wire will be for your accessories power. If you dont have accessories you will have to hook it up as you have said. To power the unit off, there should be a power button in the top left area of the unit. Hold that button down for a few seconds and it should turn off.
Aug 21, 2011 | Alpine CDE-7856 CD Player
Hi, can I test a PXA-H701 and RUX-C701 without a head unit by just connecting the power harness just to a 12V car battery ? Thank you Robin
Yes, take the power (red wire) and the accessory (yellow wire) and put them on the positive, and the ground (black wire) on the negative.
Jun 06, 2011 | Alpine RUX-C701 Controller for PXA-H701...
No memory on alpine ida -x305 head unit, correctly wired yellow live all time, red ignition ,black earth.sets ok but loses memory after a few miutes when switched off. regards terry.
Hi Terry
I know you say the yellow wire is the constant live but on some cars you have to wire the red and yellow as one, what make is the car?
Regards
Dan
Feb 14, 2010 | Car Audio & Video
Trying to set the radio stations on Alpine stereo
The radio either does not have the yellow power wire connected(constant 12v) or the wire is connected to a switched source and when the key is turned off the radio has no backup power. You will need to pull the radio out and verify the yellow wire is not connected to switched voltage and connected to constant power. It is also possible that they have the red and yellow wires mixed up. Remember yellow constant power and red is switched power(with ignition key). And also disconnect your negative battery cable when working on the electrical system of your vehicle...you may short something out and damage your vehicle's electrical system or head unit.
Sep 19, 2009 | Alpine TDM-7543
I hav a 95 berrta and im tying to put a head unit
Hello chrisuftring,
Here's a link to the wiring color code for the '95 Chevy Beretta.
You'll need to match the function of each wire from your head unit and the color code for that would be in your manual. Most aftermarket units are somewhat standard as far as power, accessory, ground, and speaker connections are concerned. But the wiring colors may be different for such leads as remote, power antenna, illumination, dimmer, and muting.
An Alpine head unit has the following wiring colors:
Blue - Power Antenna
Blue/White - Remote
Pink/Black - Audio Interrupt (muting)
Orange - Illumination
Red- Switched 12V+
Yellow - Constant 12V+
Black - Ground
Gray - RF Speaker (+)
Gray/Black - RF Speaker (-)
White - LF Speaker (+)
White/Black LF Speaker (-)
Violet - RR Speaker (+)
Violet/Black RR Speaker (-)
Green - LR Speaker (+)
Green/Black - LR Speaker (-)
With this head unit, you would wire Yellow to Orange, Red to Yellow, Black to Black, Orange to Gray, Blue to Pink, Gray to Light Green, Gray/Black to Dark Green, White to Tan, White/Black to Gray, Violet to Dark Blue, Violet/Black to Light Blue, Green to Brown, and Green/Black to Yellow.
Note that there are 2 "yellow" wires in your vehicle color code. You'll have to test them to determine which one is the accessory wire and which one goes to the left rear speaker. Using a 12V "test light" is the simplest. Connect one side of the light to ground. With the ignition ON probe the yellow wires. One of them should light the tester, the other one won't. Verify that the light goes out when the ignition is OFF and your have separated the redundant "yellows". The one that lit the tester is your 12V+ switched wire and the other one goes to the left rear speaker.
Hope this helps.
Sep 11, 2009 | Dual Car Audio & Video
Car Audio & Video Logo
97 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
