Question about Sony PlayStation Portable (PSP) Console
How can i put internet in my psp?
Well i just bought a psp and im tryin to put internet but it doesnt let me...
  • 5 more comments
  • ivonne_pagan Nov 25, 2008
    i dont know how to get to the internet i dont know the parts to my psp i need help with mostly everything
  • eumikawiggin Dec 25, 2008
    what is WEP Key and how do i get one for my psp portable
  • Anonymous Jan 07, 2009
    yes
    i try to make work but it does' t
    MY PSP SAYS THE WLAN SWITCH IS NOT TURNED ON
  • Anonymous May 04, 2009
    My wlan says that a connection error has occured when i go 2 play with my bro
  • Anonymous May 07, 2009
    a connection error has occurred
    a connection to the access point could
    not be established.
    check the security settings for the
    network and try again.
  • 31 Answers
To connect to the internet;
  1. Check that you have your PSP® (PlayStation® Portable) system set up for Wireless (WLAN) networking in Infrastructure Mode.
  2. Make sure the WLAN switch on the left side of the PSP® is turned on so that the PSP® can connect to the internet.
  3. Make sure you are within range of a wireless access point (or hotspot) that allows connections to the internet.
  4. Select how can i put internet in my psp? - icn_www.gif (WWW) under icn_network.gif (Network) from the home menu and prehow can i put internet in my psp? - icn_btnx_color.gif//i.fixya.net/uploads/images/icn_btnx_color.gif" alt="icn_btnx_color.gif" class="h_mi" />.
  5. Use the up and down buttons to select the address bar and press to display the on-screen keyboard.
  6. Use the on-screen keyboard to enter the address for the web page you want to display.
  7. When you have finished entering the address, how can i put internet in my psp? - icn_btnx_color.gifter button and press icn_btnx_color.how can i put internet in my psp? - icn_btnx_color.gif/>.</li>
<li class=Select a connection and press icn_btnx_color.gif.
  8. To hide the on-screen menu, press icn_btntriangle_color.gif.
Setting up Infrastructure Mode;
Infrastructure Mode allows you to connect your PSP® (PlayStation® Portable) system to the internet through a wireless network (WLAN) access point.
Required items:
  • A PSP® with system software version 2.0 or later.
  • A wireless network(WLAN) access point with internet access, such as:
    • A Wi-Fi hotspot (such as those at cafés, hotels and airports).
    • A home wireless network, which might include:
      • A subscription to an Internet Service Provider (ISP)
      • A DSL or cable modem
      • A wireless broadband router
  • Settings used for the SSID, WEP/WPA-PSK encryption and WEP/WPA-PSK key, as specified when the wireless access point was configured.
To set up Infrastructure Mode on your PSP®:
  1. Make sure how can i put internet in my psp? - icn_settings.gifon the left side of the PSP® is turned on so that the PSP® can connect to the internet.
  2. Select (Network Settings) and press icn_btnx_color.gif.
  3. Select Infrastructure Mode and press icn_btnx_color.gif.
  4. Select New Connection and press icn_btnx_color.gif.
  5. Use the on-screen keyboard to enter a name for the connection, then press the right arrow button to continue.
  6. To set the Service Set Identifier (SSID) for the access point, select one of the following:
    • Scan: searches for and then displays a list of access points (or wireless networks) how can i put internet in my psp? - icn_btnx_color.gifSIDs.
    • Enter Manually: allows the user to enter the SSID using the keyboard. Select this option if you know the SSID of the access point.
  7. If you choose the Scan option in the previous step, select the access point to be used and press icn_btnx_color.gif.
  8. Confirm the SSID and press the right directional button.
  9. To enter security information for the access point, choose one of the following:
    • None: does not set security information.
    • Wired Equivalent Privacy (WEP), WPA-PSK (TKIP), WPA-PSK (AES): all set security information. Press the right arrow button to move to the screen for entering WEP or WPA (Wi-Fi Protected Access) keys. Note: The WEP and WPA key fields display eight asterisks no matter how many characters you enter as the key.
  10. After entering the security information, press the right arrow button to continue.
  11. To select the address setting method, choose one of the following:
    • Easy: the following information is automatically set
      • IP address settings: Automatic
      • DNS settings: Automatic
      • Proxy server: Do Not Use
      • Internet browser: Do Not Start
      Note: Most home networks will allow you to use the Easy address setting, which is recommended.
    • Custom: you can manually enter detailed setting information, such as when you are using a static IP network. For details, see the instructions supplied with the network device or the how can i put internet in my psp? - icn_btnx_color.gifprovided by your ISP.
  12. After selecting the address setting method, press the right arrow button thow can i put internet in my psp? - icn_btnx_color.gif
  13. Check the settings, using the left arrow button to return to previous screens to make any necessary corrections.
  14. To save the new connhow can i put internet in my psp? - icn_btncircle_color.gif"http://i.fixya.net/uploads/images/icn_btnx_color.gif" alt="icn_btnx_color.gif" class="h_mi" />.
  15. To test the connection, select Test Connection and press icn_btnx_color.gif.
  16. If the connection is successful, information about the network connection will appear. Press icn_btncircle_color.gif to end the connection test.
You can also check http://www.us.playstation.com/support/psp
for more information.
Posted on Jun 17, 2008
Im trying and tryin but my internent wont work but it used 2 work last year now my internant doesnt
want kind of internet is it broadband or dial up or any other ...'
check that ur driver is up to date...
Jul 09, 2011 | Computers & Internet
Psp doesnt read the umd
hi,
you may hack your PSP in order to run ISO's (UMD copies on your memory stick), if you dont know how, search on the internet, or contact me by email. a_n_s.modding@live.com
Sep 27, 2009 | Sony PlayStation Portable (PSP) Console
My psp ver 4.01 is not working. Help me guyz!
psp firmware is corrupted, you be need to continue thats update..
1. update via UMD, the umd that are use must have same firmware version or higher (5.03). check it in other psp. make sure you have a fully battery, then turn on psp.
2. update using sony media go, it a pc client for sony device.. connect psp to pc via usb cable, you will need a internet connection on pc. and it will update to the latest version - 5.51.
hope this help..
Aug 28, 2009 | Sony PlayStation Portable (PSP) Console
WPA internet wont work on my psp
The PSP does not support WPA2. It does however support WPA.
Aug 12, 2009 | Sony PlayStation Portable (PSP) Console
Iwas tryin to customize my
im guessin u were tryin to modyfy ur psp and things went wrong? and u didnt save all the files as back up? thats bad.u need sumone who got a pandora batt and magic mem stick im guessin? sorry if im not right but u rather vague on ur discription??
Mar 27, 2009 | Video Game Consoles & Games
Dont know the password
Passcode for wifi internet?
If it is for the wifi internet, try "admin" or "password" as passwords, they are the default passes for wifi networks ;)
Feb 09, 2009 | Sony PlayStation Portable (PSP) Console
How do i put music on my psp?
hi. you sound like you need some help with a psp. well 1st you cant put music on it i am sure so if you bought it to do that then you should give it back
Oct 29, 2008 | Sony PlayStation Portable (PSP) Console
Cant get may psp and my wii consoles to work
This is the password to your wireless network.
May 15, 2008 | Belkin (F5D7230-4) Router (587009)
Error
no idea but you could take it to a gamestop or best buy and have them check it out. or go back to the store you bought it from and have them see.
Mar 30, 2008 | Sony PlayStation Portable (PSP) Console
Psp reset
go to ebay, and put PSP Unbricker into the search bar......
Oct 11, 2007 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
328 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
