Question about Philips Magnavox 9P6034C 60" Rear Projection Television
Philips 60pp9202 has volume but no picture - Philips Magnavox 9P6034C 60" Rear Projection Television
  • Philips Master
  • 1,210 Answers
You may a bad ground on the power supply board,and this may include a vertical IC that is having problems. Another thing for me to suspect would be the convergence board is on the fritz. At night sometime remove the back cover and see if you can see the ends of the picture tubes are lit while the TV is on. If they are I would say,yes the convergence ICs are bad. And finally , you may a bad small signal board. This is a small card next to the RCA connections and RF connectors inside this TV. This small signal card is quite expensive to replace. Also, this is my first calculation of errors on this unit. The last answer is my best guess. You will have to decide if you really want to repair this. Once again this small signal board is expensive. Thanks for asking and show a few hands of support.
Posted on Nov 10, 2010
Pictures are blurry and colors not bright Philips 60PP9202 HDTV
Something easy to try: with set unplugged remove back cover and locate the three large lens (black plastic housings) and clean the lens with either a lens cloth or a paper towel with glass cleaner sprayed on it.
The lens are your light source and if dusty the picture will be darker and look somewhat dull.
Let me know if you have questions.
SD TECH
Jan 15, 2012 | Philips 60PP9202 60" Rear Projection...
Philips 60pp9202 I get no sound, no picture and a chirping noise
Chirping in a phillips is usually related to the HOT ( Horizontal Output Transistor) or the Flyback ( HV Generator having a issue.
Dec 11, 2009 | Philips 60PP9202 60" Rear Projection...
Philips 60pp9202 - Sound and OSD, no Picture
I contacted my cable provider and he told me the tv defaulted to antena and reran auto set up I get picture but no sound cable man is coming to fix weak signal hope it fixes sound
I may need parts>>>haha
Sep 21, 2009 | Philips 60PP9202 60" Rear Projection...
Philips TV model 60PP9202/17F veins circuit board destroyed
Email the team at www.TvRepairKits.com - they may have a photo or service manual for that model.
Jun 14, 2009 | Philips 55PP9401 55" Rear Projection...
How can i access the menu to adjust picture without the remote
On front of TV Press and hold vol- and vol+ together menu should apear then.
Jun 11, 2009 | Philips 60PP9202 60" Rear Projection...
Green Screen
Sounds like the coolant in the green picture tube needs changing.
Jan 12, 2009 | Philips 60PP9202 60" Rear Projection...
Philips 60PP9202, no picture
If the set has sound the flyback is fine the proble is the SSB witch is the video processor part number 310432716308.
Jul 28, 2008 | Philips 60PP9202 60" Rear Projection...
Picture problem
Convergence overhaul needed =====
1)Pull chassis
2)Replace Stk392-110 IC's x 2
3)reset alignment
  Usually a 400.00 repair at a tv shop......T.
Oct 18, 2007 | Philips 60PP9202 60" Rear Projection...
VOLUME
Check first to see if n menu speaker are off or then you may have to change audio amp IC. in 7700 location before changing look for blown round black fuse 2A 250V, 1700's
Aug 07, 2007 | Philips 60PP9202 60" Rear Projection...
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
