Question about Sharp Aquos LC-42D62U 42 in. LCD HDTV
Blinking power lights and opc lights blinking television was not in use for 2 months
  • 4 more comments
  • leftelvis Jun 19, 2008
    same issue, sounds like it trips a circuit breaker when you hit the power button on the remote ?
  • Sharpie69 Sep 27, 2008
  • blink28516 Sep 28, 2008
    same problem, just began. set is not yet one year old.
  • rey65 Oct 26, 2008
    same problem.power and opc lights are blinking
  • marlonj29 Nov 19, 2008
    Power and Opc Lights constantly blinking on my sharp aquos 37
  • pat_ib Apr 19, 2009
    power and OPC lights blinking and tv doesn't turn on.
Edcor, you are the encyclopedia brown of the internet!
Posted on Oct 17, 2008
    Problem Solver:
  • 14 Answers
Get an authorized repair tech to check it out
Posted on Jul 25, 2008
Power and opc lights flashing will not turn on tried vol/channel up reboot did not work
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
Oct 17, 2015 | Sharp Aquos Televison & Video
TV won't show picture the power and OPC light blink twice together followed by three blinks from the OPC alone.
The main tv Tuner signal board have problems or it is dying or might be dead already.But sometimes this tv will still work and can be used,i have the same tv have the same problems it work for me all the times.By doing this process.Everytimes Power and OPC lights blinks.Just push the remote power switch again for tv to repower the tv power and OPC lights again,have go thought this process pushing power remote switch again have to do this like 3 or 4 times sometimes before the tv to work.Tries websites like or to buy a whole new refurbish main tv Tuner signal board for the replacement.
Jul 30, 2011 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
So when i turn on my sharp hd it turns off then the opc light comes on! Then the power light and opc light keep flashing!! Alls i want 4 it to work? Plz help
The television has gone into a coma. It is going to need to be serviced or replaced. The blinking code is a pattern. If you look at the power light and the opc light separately and independently, you can acquire the blinking pattern. Cover opc and look at power only. Note how many times it is blinking before it pauses. It might just blink steadily. Next cover power and look at opc alone. Note how many times it blinks before it pauses.
Depending on which model you have it might work if you leave the television unplugged overnight. The next day plug the television back in and wait for the blinking to start. Hold down the power button on the side of the television until the light stops blinking and turns red (usually right away). Let go. Press and release the power button once more and the light should turn orangish and then green. The television should turn on.
You can call Sharp and have a case file created and try and INIT with the customer service representative.
Mar 07, 2011 | Sharp Televison & Video
I have an aquios LC-42D64U which suddenly has the following two lights blinking power & OPC. They both blink, once together, the second blink is only the power, and repeating the sequence. I've...
Sharp LED/LCD EEP cleared Step 1 Remove Mains Plug 2 Press On/Off Switch from LED/LCD Panel 3 Press Ch Down & Input Switch together and plug in mains cord 4 LED/LCD will start 5 "K" will appier on Screen 6 Press Ch Down & Vol Down from LED/LED Panel 7 1/9 Page will appier on Screen 8 Go to 9/10 page by pressing Up & Down arrow of remote 9 Select EEP Cleared 10 Press ok button from remote 11 On Screen dispay EEP running 12 Remove Mains Plug after complete EEP Run 13 Restart LED/LCD
Feb 05, 2011 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Thethe tv will not come on and power and theopc is flashing.
Ok This is how to troubleshoot the TV, there are lights on the front and you are mainly concerned with two of these lights (the power light and the OPC light). I) If non of the lights come on then this is a AC Power failure (There is a loose connection or you need to check the Power/Inverter unit or the Main unit) II) If the power light is blinking at a rate of one blink per min and the OPC light is off (then there is a CCFL backlight problem) III) If the power light is blinking at a rate of two times per min and the OPC light blinks at a rate of one time per min (13V/UR10V failure you need to check the Power/inverter board or the main board). IV) If the power light is blinking at a rate or two times per min and the OPC light blinks at a rate of two times per min (3.3V Main Failure check power/inverter board or Main board). V) If the power light is blinking at a rate or two times per min and the OPC light blinks at a rate of three times per min (UR6V failure check power/inverter board or Main board). VI) If the power light is blinking at a rate or two times per min and the OPC light blinks at a rate of Five times per min (Panel 5V failure check LCD control unit or control panel).
Sep 07, 2010 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Power light comes on for about 30 secs, something clicks and both power and ocp lights start blinking contineously. the screen does not light up
I have this model of the sharp tv.Happen to me very often the Power and OPC LED light indicators blink continueosly.Not the power supply board,it the Tuner board that take in the comming broscast signal that have the problems.You still can used this tv.Push the power button sometime the tv it will work right away.Not,each time POWER and OPC lights continueosly blinks.Just push the power button again each time the POWER and the OPC continueosly blinks.Just have push power button again about 4 times each time Power and OPC blinks recycles,it will finally show the backlight and picture come on.My guest,if u do this by pushing power button to recycles about 10-12 times each time the POWER and OPC blinks it time to change the Tuner signal board.
Jun 03, 2010 | Sharp LC-C4655U 46 in. LCD TV
Blinking power and OPC lights
If you have tried to reset the TV by unplugging it for 2 minutes and still have the same issue then it is time to bring the set to a repair shop.
Jan 04, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
OPC/DL light flashing Same problem of black screen and green lights flashing at power and OPC Help....
Dec 08, 2008 | Televison & Video
Blinking green light, no picture or sound
Hi, bought television only 2 months ago now blinking opc light and power lights with no picture or sound. Whats up with that?
Sep 13, 2007 | Mitsubishi WD-62525 62" Rear Projection...
Sharp Aquos LC-42D62U 42 in. LCD HDTV Logo
772 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
