Question about Alpine Air XL-15 Air Purifier
The fan is not spinning when I turn on my XL-15C... What should I do?
    Problem Solver:
  • 18 Answers
Some 3 in 1 oil on the shaft might help
Posted on Nov 18, 2010
My Oreck XL Air Purifier Tower constantly turns itself on and off while in use. Been cleaned once a month x 3 months I've had it, all instructions followed. How do I fix this?
I'd give oreck a call...
To speak with an Oreck representative call:
USA: 1•800•989•3535
Canada: 1•888•676•7325
Mar 16, 2018 | Oreck Air Purifiers
Eco Quest Living Air XL 15S Classic Air Purifier Cleaner Ozone Ionizer USA
Ozone is not good for you. If you can smell it, it is set too high. Look at it in dark room and check for blue orange glow inside the fan louvers. If you see the glow, it is working
Jan 10, 2017 | Air Air Purifiers
Fan is not coming on
The motor spins on brass bushings. you can try oiling the brass bushing. take off the front grill then gently pull off the fan blades. you need to oil the motor center shaft lay it on its back so the oil will run down into the bushing(not to much and use a light oil). there is one on the back of the motor also, this one is a little harder to get too. if this dont work you need a new motor. you can get on off of ebay cheaper. the motor should be replaced by some kind of tech savey person, as the are delicate and a very specifice disassemble procedure.
Jul 07, 2012 | Alpine Air XL-15 Air Purifier
Living Air Model XL-15C: the red-neon FT ionizer bulb does light.
Corrosion in the cicuitry at the connection are unseen until you take them apart, can cause this. The male and female connectors might be together but rotted inside the boots unseen and not connected. That happens sometimes. Gently pull those connections apart and look inside both connection areas and check.
Apr 28, 2010 | Ecoquest Fresh Air Air Purifier
I HAVE THE LIVING AIR XL 15C
Check the fuse. You may need a new one.
Jul 22, 2009 | Alpine Air XL-15 Air Purifier
Alpine XL-15 fan has stopped working
Hello night light,
How you proceed is going to depend on how comfortable you are taking it apart.
Given it's age and purchase condition, warranty isn't an issue. You will either be able to dis-assemble the purifier and try taking the motor apart and reassembling, or you can find a replacement motor (I've seen some on the web, they start at ~$50).
Another possibility is that the fan pot (the rotary switch that the knob turns to adjust the fan speed) may be out. If you have a multi-meter, see if you can get a signal through (when it's all the way open). If not, try replacing that first. Parts are available onthe web, I can't advertise per FixYa's terms of use.
Hope this helps.
Sep 28, 2008 | Alpine Air XL-15 Air Purifier
Living Air XL 15, no ozone
My XL-15 had the same problem a few years ago. I had a broken wire on the fan, and the Ozone problem turned out to be a problem with the power supply. I had to send it in to have it repaired.
Mar 18, 2008 | Ecoquest Living Air Classic Air Purifier
Fan is not turning on
The fan motor is probably locked up. You can either put a little oil to free it up (usually a temporary fix) or better yet replace the fan motor.
Oct 26, 2007 | Ecoquest Living Air Classic Air Purifier
Alpine Air XL-15 Air Purifier Logo
Top Alpine Air Air Purifiers Experts
Jerry Greenberg
Jerry Greenberg
Marvin
Marvin
Tom Chichester
Are you an Alpine Air Air Purifier Expert? Answer questions, earn points and help others
