Question about Jabra GN9120 FlexBoom Headset Wireless
Need manual for GN9120 - Jabra GN9120 FlexBoom Headset Wireless
    President:
  • 1,082 Answers
Will these headsets work with a VOIP phone system as we are moving from ISDN to VOIP
neil look at the manual and check the voip phone model number against the most common phone types it works with
https://www.jabra.com/~/media/Product%20Documentation/Jabra%20GN9120%20Series/User%20Manuals/User_Manual_Jabra_GN9120-GN9125_EN.pdf
ISDN is a digital system are you using the old phones on the voip or having to install different phones ?
Nov 30, 2015 | Jabra GN9120 Wireless Headset
Jabra gn9120
Make sure ringer is turned on and the volume turned up on phone
Sep 02, 2014 | Radio Communications
Gn9120 cisco 7941
I had a 9120 for years, great headset. Change the compatibility wheel and levels on the unit per the instruction book link below. https://www.jabra.com/_/media/Product-Documentation/Jabra-GN9120-Series/User-Manuals/User_Manual_Jabra_GN9120-GN9125_EN.pdf
Mar 01, 2018 | GN Netcom Radio Communications
Hi, I have the GN9120 and they are getting ve...
Hello Jennifer,
I do not own a GN9120, or anything similar (I have an old bluetooth earbud for a cellphone), but it sounds like a typical exhausted battery issue.
Batteries get old and sometimes do not charge to full capacity. According to the pdf manual from Jabra, the headset will beep every 20 seconds if the battery is low.
Another idea is maybe they are drifting off-frequency, either the adjustment got knocked off (if there is a physical adjustment inside), or the capacitor or other component values have changed to cause them to transmit off-frequency. I am surprised there is no sort of squelch on the base unit like they have in wireless microphones used on-stage.
Also check the phone cable between the base unit and any other phone cables.
My last thought is check the power supply for the base unit, sometimes they fail and output too low of a Voltage or start becoming noisy with power line noise.
I hope you figure it out! :-)
I am thankfully not near the fires here in California...
Oct 18, 2017 | GN Netcom GN 9120-28 Wireless Headset
GN9120 Mic is to soft!!
common fault with these type headset
depress two end buttons at the same time and wait for bleep
when bleep heard press the rear button several times until loud bleep heard
this will adjust mic
Steve
Sep 18, 2009 | GN Netcom GN 9120 Professional Headset
Battery for GN9120 is not staying charged; what can I do?
Hi
The battery is no longer charging just like your car battery only lasts for so long and then dead no matter how long its been on charge
try and get replacement if not should think about a new headset
Steve
Aug 28, 2009 | GN Netcom GN 9120 Professional Headset
Netcom GN9120 needs repair
I can ship you a good remanufacture unit with a new battery in the headset. Marc@universetelecom.ca
May 15, 2009 | GN Netcom GN 9120 Professional Headset
My GN9120 does not connect ...
I solved this over the weekend: I found out, that the GN9120 comes with slightly differing battery sizes. I had to push the contacts deeper inside the housing so they got in touch with the new battery again. I used a very small flat screwdriver to achieve that. You have to be careful not to destroy anything surrounding.
This was an easy solution to a stuoid problem, but the contacts are barely visible in the inside of the GN9120 so i needs to have the idea to search for that as the source of trouble,
Jan 16, 2009 | Jabra GN 9120 Midi-boom Microphone-Headset...
Plantronics GN9120 microphone is too quiet for listener
I've had this same probelm and after much pressing of buttons eventualy fixed it by reading the manual... :s
Last page page of Quick Set-Up Guide under "Transmit volume adjustment":
1.) Make call to another phone user to assist.
2.) Press + and - on the headset at the same time.
3.) Adjust volume by pressing either - and +.
4.) Confirm volume with helper.
5.) Wait for 10secs and the settings will store.
May 08, 2008 | GN Netcom GN 9120 Professional Headset
Jabra GN9120 FlexBoom Headset  Wireless Logo
242 people viewed this question
Top Jabra Radio Communications Experts
Bobby G
Bobby G
Damen Wong
Damen Wong
Jerry Greenberg
Jerry Greenberg
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
