Question about Mitsubishi WS-55819 55" Rear Projection Television
Convergence I am having convergence problems with my Mitsubishi model 55819.The picture bleeds red on the right side on startup then snaps back into and out of focus. Is there a Board to replace or just the convergence Chips? Where can I order these parts and get instructions on replacement?
  • Mitsubishi Master
  • 8,617 Answers
Best place to get them with instalation instructions included is the following link. you need two STK392-570 ICs
http://servicemanuals.vstore.ca/
Posted on Jun 17, 2008
Red ghost to right of picture and words
It is a convergence problem, How may I help you?
What do you want to know?
Nov 10, 2011 | Mitsubishi WS-55819 55" Rear Projection...
I have a ws-55819. the picture is out of focus, more so on the left and right, less out of focus in the middle. Its like there are 3 separate pictures, out of alignment
Thats caused by a failed convergence IC. You can get the convergence repair kit for your model from www.tvrepairworld.com The kit contains the parts and the CD with instructions for the repair.
Jun 06, 2011 | Mitsubishi WS-55819 55" Rear Projection...
Can not align red even though convergence board WS-55819
Did you replace the center board with the STK-392-570 chips or the Digital convergence board mounted on it?
98% of the time if you have a convergence problem it is on the center board---the small board on the left under the metal shield box stores and controls the convergence of this set.
WHICH DID YOU REPLACE?
I am here to help----I have fixed hundreds of Mitsubishi sets with convergence troubles.
Regards, SD TECH
Oct 28, 2009 | Mitsubishi WS-55819 55" Rear Projection...
Colors are bleeding and picture blurred. Can't adjust convergence settings.
Replace the two Convergence amp ICs they are both STK392-570 Ics you can get replacements at the following link with free instructions on how to remove the old and replace the new ones.
May 23, 2009 | Mitsubishi WS-55819 55" Rear Projection...
Picture problem on mitsubishi medallion ws 55819 model....picture convergence messed up on left and right side of screen (center fine)...problem goes away and set "re-adjusts" after it's been turned on for...
Well I have a Mitsubishi WS-65413 65 in. Rear Projection Television and when I power it on in the morning it looks as if the picture on the bottom of the screen is bending and parts of the picture "double up" but like the person above me said after it gets warmed up it goes back to normal but every 3 or 4 hours it might get messed up for a min...Anyways: Is it the picture tube going out?? If so how does anyone know how much it would cost to repair/replace & What is a "Convergence Module"?? I don't know if my T.V has one of those or not but if it doesnt is that the problem perhaps?? Please help me or ill be forced to go outside... :-( ..... thanx 4 the help ppl!! -
- Zachariah-
May 10, 2008 | Mitsubishi WS-65413 65" Rear Projection...
WS-55819 Mitsubishi Rear projection TV Picture goes blurry
Convergence ICs are bad need to be replaced. You will need to replace both of them also check the resistors right next to the IC often 1 or 2 of them burn out when the IC goes.
Feb 26, 2008 | Mitsubishi WS-55819 55" Rear Projection...
Mitsubishi WS 55819 with a convergence
CEM-NO, BOTH ICS' WORK ALL 3 CRT YOKES.YOU EITHER NEED TO REALIGN THE RED IN FACTORY CONVERGENCE MODE OR YOU HAVE A RESISTOR THAT HAS FAILED.THE LATTER YOU MAY ACTUALLY BE ABLE TO SEE IF YOU LOOK CLOSELY.OH, ALWAYS DOUBLE CK. YOUR SOLDER CONNCETIONS.GOOD LUCK. JOE TV
Nov 22, 2007 | Mitsubishi WS-55819 55" Rear Projection...
Convergence Problems
GREEN-YOU HAVE TWO STK392570 CONVERGENCE ICS' GETTING READY TO FAIL.SOME FOLKS HAVE REPLACED THEM ON THEIR OWN,OR YOU CAN GET A REPAIR TECH TO DO IT FOR AROUND 300.00$.JOE TV
Oct 29, 2007 | Mitsubishi WS-55819 55" Rear Projection...
Mitsubishi WS-55819 55" Rear Projection Television Logo
127 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
