I have the agitator out of the washer but cant get the "dogs" out what do I have to do next?
  • Washing Mach... Master
  • 8,220 Answers
Place the agitator on the floor. Place your feet on it and pull the upper portion away from the lower.
Remove the old worn dogs part number 80040 and replace themI have the agitator out - themobilian_87.jpgThis video shows how:
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Nov 10, 2010
NEED TO REMOVE AN AGITATOR FROM A WASHING MACHINE
  • 1 First you must determine the brand of washing machine you have.
  • 2 To remove agitator on a whirlpool washer, remove top cap from agitator, Next you will find a translucent cap, remove this with your pliers. Then you will see a 3/8 inch nut, Back this nut out and you can then remove the agitator. Be Careful though, inside the agitator where the bolt has been removed is a white piece of plastic that holds the "dog ears". These dog ears are what lets the agitator move in one direction and locks when the transmission moves back in the other direction.
    Maytag and Admiral washers are very similar to remove. General Electric, (GE) is different, To remove a GE agitator simply pull upwards very hard, GE agitators snap on. Be careful not to pop it into your mouth, that really hurts.
  • 3 Remove agitator, repair or replace and reset, GE just push on, you will be able to see the groves to line up the agitator to the hub. For whirlpool place bolt into dog ear guide, and set down on top of transmission post and tighten, be careful that dog ears, do not get out of alignment. That's it.
    Buy F150 parts.
    Jun 03, 2012 | GE Washing Machines
    Replace dogs
    take off fabric tower and the remove cap in the middle of agitator. you should see a 7/16 bolt in the middle grab the bottom vane of agitator and loosen the bolt. Next grab the bottom of the agitator and pull up. Next take the two parts of the agitator apart and the agitator cam is release. Remove old dogs and insert new on and reassemble in reverse
    If you need further help, reach me via phone at https://www.6ya.com/expert/marlon_56d9a24f02585258
    Apr 17, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
    How do you remove the aggitater
    1- First you must determine the brand of washing machine you have. 2- To remove agitator on a whirlpool washer, remove top cap from agitator, Next you will find a translucent cap, remove this with your pliers. Then you will see a 3/8 inch nut, Back this nut out and you can then remove the agitator. Be Careful though, inside the agitator where the bolt has been removed is a white piece of plastic that holds the "dog ears". These dog ears are what lets the agitator move in one direction and locks when the transmission moves back in the other direction.
  • Maytag and Admiral washers are very similar to remove. General Electric, (GE) is different, To remove a GE agitator simply pull upwards very hard, GE agitators snap on. Be careful not to pop it into your mouth, that really hurts. 3-Remove agitator, repair or replace and reset, GE just push on, you will be able to see the groves to line up the agitator to the hub. For whirlpool place bolt into dog ear guide, and set down on top of transmission post and tighten, be careful that dog ears, do not get out of alignment. That's it.
  • Read more: How to Remove an Agitator From a Washing Machine ' eHow.com http://www.ehow.com/how_4620771_remove-agitator-washing-machine.html#ixzz1IhUKY7OQ
    Apr 06, 2011 | GE WBSR3140DW Top Load Washer
    I have a Kenmore 110. (full number is 110-82984810) It has a "ratchet/screw" type agitator. The big fins on the bottom part agitate back and forth, but the center piece no longer moves in a...
    This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
    First, see the Sears parts site for your washer:
    http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Washer-Parts/Model-11082984810/0582/0153200?pathTaken=
    and you'll see a list of major sub-components with diagrams and parts.
    If the bottom agitates and not the top, the problem is likely the 4 "agitator dogs" designed to allow the top agitator to turn only one way.
    Look at the section on the Sears site for Agitator, basket and tub.
    See the part "Dog, agitator "
    Remove the fabric softener unit, lift the top agitator cap (use a screwdriver) and you should see a plastic part in the center of the top agitator with a 1/2" square drive.
    Remove the drive and lift off the top agitator. Turning it over you should see the 4 "dogs", replace these and the top agitator should turn in one direction only.
    Replace the 1/2" drive, the cap and fabric softener unit and the top agitator should work.
    Also see the following illustrated description of the above.
    http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=136&osCsid=0da65cea0e338fe930b1fde153a243f0
    For future reference you might also want to review / print / save the following Whirl[pool / Kenmore Service Manual for these washers:
    https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
    Dec 26, 2010 | Kenmore Washing Machines
    Agitator is not agitating. Cant seem to get
    If this is a Whirlpool manufactured TOP LOADER, and this is a simple matter of the agitator not working, but everything else does, you may just have a worn agitator cam assembly, worn agitator dogs, loose agitator bolt, or all of the above. The following link explains what agitator dogs are and how to access them:
    http://www.fixya.com/support/r3608577-replacing_agitator_dogs
    Whirlpool manufactured washers use a split agitator design. The top half is known as the "auger, while the lower half is the agitator. Between the two pieces is a cam assembly, with small teflon teeth known as "dogs". There's also an agitator bolt that holds the entire assembly to the center post.
    If the auger (top half of the agitator) is slipping, I would suspect the dogs or cam assembly need to be replaced. The part number for the dogs is included in the link I provided. For a little more you can purchase the entire cam assembly which includes the dogs, the cam, the cam seal and thrust bearing.
    If the entire agitator appears loose or slipping, check the agitator bolt to ensure it is tight. DO NOT overtighten as this can restrict movement of the agitator or damage it. Tighten until snug.
    Replacement parts (if required) can be purchased at any of the following websites:
    pcappliancerepair.com
    appliancepartspros.com
    repairclinic.com
    All these sites are reputable and offer great service with competitive pricing, so shop and compare. The first three sites I listed also include helpful exploded view parts diagrams to assist you in locating and properly identifying the parts you need. If you do not wish to order parts on line, use the part numbers from the Sears website and go to your nearest appliance parts retailer. All these parts are commonly sold as part of their in-store inventory.
    If you have any questions, please post back and let me know. I hope this helps you.
    Apr 26, 2010 | Whirlpool 3.2 cu. ft. Plus Washer
    Agitator not working properly...lower part works while the upper part just sits there not turning
    you nead to replace the dogs in the top portion of the agitator.first remove the fabric soffiner despencer from the top of the agitator,next there may be a plactice cover that you nead to remove,next you nead to remove the 7/16 bolt and pull up on the bottom of the agitator and remove the agitator and place it on the floor,put a foot on both sides of the bottom of the agitator,next you nead to grab the top of the agitator and pull up and remove the top of the agitator.place your hand inside the top of the agitator and turn it upside down and remove the dog assembly.replace the rubber dogs and reassemble the agitator and reinstall the agitator.
    Dec 31, 2009 | Whirlpool Estate TAWS750PQ 27-Inch Washer
    How do i replace the dog agits? cant seem to get the part that holds the dog agits
    Please see the following:
    http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=136&osCsid=42ae105eb990dea3eb5dcf047d1cdc92
    Oct 17, 2009 | Whirlpool LSB6200KQ Top Load Washer
    Model # is LSR8233EQO Top portion of the agitator seems loose and does not agitate properly?? Does is remove? It seems to unscrew??
    you have to replace the dog's in the top ov the agitator.the part# ror this part is WPL80040462.the cost is $4.62.to replace the dog's you nead to remove the fabrick sofeiner assembly from the top of the agitator.next you nead to remove the top cap.now you nead to use a 7/16 socket to remove the bolt in the agitator.now you nead to grab the agitator at the bottom and pull it up.now yopu nead to seperate the top from the bottom.place the agitator on the floor,put a foot on both side's of the bottom of the agitator and pull up.now you the top portion of the agitator.turn top portion upside down and remove the cam.you will see the rubber dog's.replace the dog's and reverise the prossess.
    Oct 05, 2009 | Whirlpool LSR5132PQ Top Load Washer
    Agitator cant be removed from base to get to clutch dog
    hi, There is a 7/16" bolt that hold the agitator in. Remove the top cap on the agitator and the cap inside it to get to the bolt. Once you get the bolt out, pull the agitator out and seperate the two pieces.
    I hope this help you. Please let me know if I can assist you further.
    Vic
    Jul 02, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
    Top part of agitator appears to becoming disconnected from bottom part. bottom is attached to motor and is working.
    Hello Friend, Your problem is easily solved. You need to replace the agitator dogs. To replace all you have to do is pop the top cover off of agitator and remove bolt. Pull up on agitator and remove from washer. Next remove upper agitator from lower agitator. Inside the upper agitator top piece you will see a mechanism that has 4 little ratcheting teeth, these are called agitator dogs. Just replace them with new ones and re-install agitator. This should solve your problem. Happy to help, Tim.
    Jun 25, 2009 | Washing Machines
    Washing Machines Logo
    19 people viewed this question
    Top Washing Machines Experts
