Question about Refrigerators
I am trying to find out what year this conservator crosley serial # cr13ffw made in mexico is,
4 Suggested Answers
SOURCE: BROKEN DOOR BRACKET
Reliable Parts http://www.reliableparts.com/ has them in stock. The parts are made by Serviplus. According to Eric at their main number, there are several in stock in the San Francisco store. I called 877-733-9241.
One word of warning: when I went to pick up the part (I needed only the 221C6568), the first one they brought out was a 221C6578 that was mislabeled. You might want to ask them to verify before they ship them.
Posted on May 07, 2009
woodchuck789
  • 4070 Answers
SOURCE: crosley conservator is freezing, fridge not cooling
No, it is not normal. The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
If you need help finding your model number see here> http://www.appliancepartspros.com/modelnumber_locator.aspx
To locate your timer, motherboard, control or adaptive defrost control , enter your model number and search for the part or post back on Fixya.
http://www.searspartsdirect.com/partsdirect/index.action?psid=26129238&sid=PSx20071217x00001a
Posted on Oct 05, 2009
heatman101
  • 43501 Answers
SOURCE: my crosley conservator frig is producing a fowl
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Sep 10, 2011
My Crosley Conservator Ice maker will only produce crushed ice, HELP!
Ensure the Wire Signal Arm is not in UP position. • Ice maker should produce 2.5 to 3 pounds of ice in a 24 hour period. • Water supply is turned off. • Water pressure is too low. • The freezer is not cold enough.
Apr 15, 2015 | Crosley Refrigerators
Serial number look up
On the bottom of the Xbox 360, you will be able to see the Xbox 360 manufacturing date and the Xbox 360 serial number. The manufacturing date is in the following format:
2008-11-03 this is how you read it
YYYY-MM-DD
(Year-Month-Day) which is the date according to ISO 8601.
This would
The serial number looks like this:
6144526 84302
the serial number is formatted (LNNNNNN YWWFF)
  • L the number of the production line within the factory,
  • NNNNNN the number of the Xbox within this week.
  • Y the last digit of the production year,
  • WW the number of the week of the production year
  • FF is the code of the factory (02: Mexico, 03: Hungary, 05: China, 06: Taiwan),
So taking the serial number 6144526 14302 this would give us
  • Line 6 of the factory
  • This would be 144526 off the production line
  • 2008 production year
  • Week 43 of the year
If you need further help, I’m available over the phone at https://www.6ya.com/expert/richard_b59056c0c62ecb00
Aug 08, 2014 | Microsoft Xbox 360 Console
Apartment size washer dryer. I have the chance to
Formed in 1976 in Winston-Salem, NC, the Crosley Corporation consists of a group of independently owned distributors who resurrected the Crosley trade name and introduced a line of refrigerators, freezers, ranges, dishwashers, air conditioners, and other appliances. We carried the heritage of such features as "Shelvador" and "Conservator" that were marketed for decades.
Sep 27, 2013 | Crosley Dryers
Crosley conservator dehumidifier will not capture humidity
Have you noticed it not running as often or not being noisy? Also have you tried to select a continuous drain setting if your unit has one?
Aug 14, 2012 | Crosley W.C. Woods DCW40S Electric...
Fender strat guitar. Want to know what year it was made. How?
Your guitar was made at the
Ensenada Plant (Fender), Mexico
in the Year(s): 1992 - 1993
Jun 04, 2010 | Music
I lost my car radio antitheft code,its a becker typ 2330 mexico
TPlease post the SERIAL NUMBER as well as the MODEL NUMBER (BE2330) .
Jan 29, 2009 | Infinity Reference 1211a Car Audio...
Parts
What is the model # from the sticker on the unit? I'll see if I can help.
Nov 03, 2007 | Dehumidifiers
Refrigerators Logo
79 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
