Question about Minolta X-700 35mm SLR Camera
Advance lever will not operate. Is the transfer drive gone?
  • 176 Answers
Did you try fresh battery's ? This Camera needs good battery's to work write.
Posted on Nov 13, 2010
Lever no move rear hi 2whl only
check out your transfer case linkage it may be bound up, other than that check your fluid in the transfer case it may be stuck in 2wd.
Mar 23, 2015 | Suzuki Grand Vitara Cars & Trucks
What operate the 4x4 in the transfer box of the landrover freelander 1.8 Petrol. The switch on the gear lever works but the wires are disconnected and I see no switch or valve on the gearbox or transfer...
Freelander is permanent 4 wheel drive. The switch on the gear lever is for downhill decent control. These are usually diconnected when there is a problem with one of the ABS wheel sensors not working, causing three warning lights on the dash to display. Google Freelander Three Amigos.
Mar 18, 2013 | Land Rover Freelander Cars & Trucks
HAVE A 1989 FORD F-150 WITH AUTO TRANS THAT YOU CAN'T SHIFT OUT OF THE "PARK" POSITION AT THE STEERING COLUMN. THE TRANY CAN BE SHIFTED AT THE TRANS WHEN LINKAGE IS DICONNECTED.I THINK THE...
What trans? AOD? This is 1992 F Series, all I have.
Shift Controls, Automatic Transmission The transmission shift control linkage or cable transfers the transmission operating mode from the selector lever to the transmission. The indicated transmission position on the steering column is transferred to a shift lever on the bottom of the steering column. On vehicles equipped with cable-operated shift systems, the indicated position of the transmission selector lever is transferred to the transmission through the shift cane, then to the cable, and down to the transmission manual shift lever at the transmission. On vehicles equipped with shift rod assemblies, the rod transfers the indicated transmission selector level position through a bell crank assembly to a control rod. The control rod transfers the indicated position to the transmission assembly.
Automatic Transmission Manual Linkage Adjustments
  1. With the engine stopped and the parking brake applied, place the transmission selector lever at the steering column in the D (DRIVE position) for C6 applications and in the (D) (OVERDRIVE position) for AOD and E4OD applications, and hold against the D or (D) stop by applying a three-pound force to the selector lever knob.
  1. Loosen the shift rod adjusting nut at point A. Refer to the following illustrations.
  1. Shift the manual lever at the transmission into the (D) (overdrive) position for E4OD, by moving the lever all the way rearward, then forward two detents.
  1. With the selector lever and transmission manual lever in the(D) position, tighten the nut at point A to 17-24 Nm (12-18 ft-lb) torque. Use care to prevent motion between the stud and rod.
  1. Remove the three-pound force from the steering column selector lever knob.
  1. Operate the shift lever in all positions to make certain that the manual lever at the transmission is in full detent in all gear ranges. Re-adjust the linkage if required.
  1. On F-Super Duty Chassis Cab and Motorhome and Commercial Chassis recheck for correct operation of the automatic transmission selector indicator (PRN(D)21). Refer to Section 11-04A, Steering Column, Shift Rod Within Tube. ani_caut.gif CAUTION: Under no circumstances will it be permissible to adjust linkage in any position other than the(D) position for E4OD applications.
Automatic Transmission Shift Cable Adjustment
  1. From inside the vehicle, place the column shift select lever in the DRIVE position (C6) of the OVERDRIVE (AOD and E4OD). Hang a three-pound weight on the selector lever.
  1. Raise vehicle on a hoist.
  1. Remove the shift cable from the transmission lever ball stud.
  1. Pull down the lock tab on the shift cable body.
  1. Position the transmission shift lever in the DRIVE position (C6) or the OVERDRIVE position (AOD and E4OD). This is three detents from the front-most lever position with the first position counting as one.
  1. Connect the cable end fitting to the transmission lever ball stud.
  1. Push up on the lock tab to lock the cable in the correctly adjusted position.
  1. Lower vehicle down from hoist and remove the three-pound weight from the column shift select lever.
  1. After making the adjustment, check for park engagement. Check the transmission control lever in all detent positions with the engine running to make sure correct detent/transmission actions. Readjust if necessary.
Jun 21, 2011 | Ford F-150 Cars & Trucks
The 4 wheel drive shifter is broken. How does the linkage to the transfer case come apart?
Shift Lever NOTE: Remove the shift ball only if the shift ball, boot or lever (7E067) is being replaced.
Removal
  1. Raise vehicle on hoist and position suitable safety stands under vehicle.
  1. Prior to removing the control lever assembly (7E069), be sure the shifter is in the 2H position.
  1. Loosen (do not remove) the nut retaining the shift handle (7E067) to the control lever assembly (7E069). Remove the shift handle (7E067) from the control lever assembly (7E069).
  1. Remove the vent hose (7D494) from the notch in the detent plate.
  1. Remove the control rod (7A315) from the control lever assembly (7E069). ani_caut.gif CAUTION: When removing the control rod (7A315) off the control lever assembly (7E069), do so very gently so as not to damage the control lever assembly.
  1. Loosen (do not remove) the large pivot bolt holding the control lever assembly (7E069) to the detent plate.
  1. Swing the control lever assembly (7E069) out of the way and remove the two bolts (39129-S2) retaining the detent plate to the transmission extension housing. Remove the entire control lever assembly from the vehicle.
Installation
  1. Prior to installing the control lever assembly, be sure the transfer case link (7B106) is in the 2H position (pointing upward).
  1. Install the two bolts (39129-S2) to retain the control lever assembly (7E069) to the transmission extension housing and tighten to 92-125 Nm (68-92 ft-lb). Refer to the following illustration for bolt hole application.
  1. Attach the control rod (7A315) to the control lever assembly (7E069).
  1. Tighten the large pivot bolt to 92-125 Nm (68-92 ft-lb).
  1. Attach the vent hose (7D494) into the notch in the detent plate so the white mark is flush to the outside surface of the plate.
  1. Install the shift handle (7E067) into the control lever assembly (7E069). Tighten the retaining nut to 27-38 Nm (20-28 ft-lb).
  1. Check transfer case for proper shifting and operation.
Feb 27, 2010 | 1992 Ford F250
Nikon Fa advance lever loose. Not used camera for a few years and set to M250 mode due to not having batteries, Advanced lever once to test, advanced one, then pulled lever back for another test. Lever...
Try moving the coupler on the bottom where the motor drive would connect. See if you can rotate the piece clockwise. With the advance lever loose, it may be in mid-cycle on the winding/advance
Dec 10, 2009 | Nikon FA 35mm SLR Camera
My Mamiya RB67 triggers and shutter lease lever works but film advance lever doesn't move. Trigger button fired several times but film advance still showing 1.
This is not the best solution as it indicates a faulty film back. The film should advance without resorting to activating the film-wind release lever. That is only for intentionally advancing a partially exposed roll of film. Make sure the multi-exposure lever is not engaged and that the counter does advance and the red mark disappears as you advance to an unexposed frame.
Nov 09, 2009 | Mamiya RB67 Pro SD Medium Format Camera
Error message 0x80070052
I tried setting up a new folder and transfering the files, this did not work either so I just purchased a new Jump drive. I had plenty of space remaining on the Lexar, however, my time was worth more than the cost of a new drive. I'll keep looking for "free solutions" to my problem and if I find the answer, I'll respond.
Apr 18, 2009 | Lexar JumpDrive Classic Portable USB Data...
How Does Quadra Drive Work?
Under normal driving conditions, the system operates conventionally, and the majority of available torque is applied to the rear wheels. However, when front-to-rear wheel speed variations exist, the progressive differential transfers torque to the axle with the better traction, thus minimizing wheel spin and maximizing control.
The key to this design is a progressive coupling Progressive Coupling , which is supplied with pressurized oil by a gerotor style pump. The pump rotor and case are driven by the front and rear driveshafts respectively, and deliver pressurized oil flow to the coupling in proportion to their speed difference. The progressive coupling contains a multi-disc clutch pack that is alternately splined to the front and rear driveshafts, and controls torque variation between the front and rear driveshafts as dictated by the pump.
A set of orifices and valves control the speed-differential starting point and rate of torque transfer rise in the clutch. This allows the system to disregard the normal speed differences between axles that result from variations in front-to-rear loading and typical cornering.
Transfer case operating ranges are selected with a floor mounted shift lever. The shift lever is connected to the transfer case range lever by an adjustable cable. Range positions are marked on the shifter bezel plate
Jan 08, 2009 | 2000 Jeep Grand Cherokee
Leica m2 film advance lever is stuck
mandie22,
on this model two strokes are needed to fully advance the film and to set the counter to the next #,
so advance the lever, bring it back and advance again.
Jun 03, 2008 | Photography
Minolta X-700 35mm SLR Camera Logo
32 people viewed this question
Top Minolta Photography Experts
pontelemon
pontelemon
TC CAMERA REPAIR.Com...
Parshiv Luthra
Are you a Minolta Photography Expert? Answer questions, earn points and help others
