Question about Intex Excursion 4 Inflatable Boat Set
HELP! My new little 200 boat will NOT INFLATE! Have tried everything. I had another one that inflated immediately and this one will not! it is as if it has no way in the valves for the air to get into the boat! What is going on?
    Scholar:
  • 72 Answers
Hi, perhaps the problem may lie with the inflating method. Have you checked to see if the pump is actually giving air? These rafts usually have multiple bladders, are they all giving you this problem? Also, there is a plastic flap at the inside the base of the valve to prevent too much air from escaping before you plug it. you mush insert the air chuck adapter past this point. Good Luck!
Posted on Nov 15, 2010
My 1991 geo metro lsi convertiable i started it when i came to a stop and it stalled wont start. Inflate reset light stays on what is wrong with car.
inflate?
does it crank, that is first,
G10 engine 3 cyl or 4.?
stalls do have over 50 causes, ill not try to guess.
but most stalls , are not getting tuneup,"spark plugs top that list"
or EGR valve stuck open
here watch scotty.
this is what we do.
he has over 200 vids, all good.
https://www.youtube.com/watch?v=064Ilsz8Fzg&NR=1&feature=fvwp
May 25, 2016 | Geo Cars & Trucks
I am trying to inflate flat tire and can't get it to inflate with air master air compressor 59008. what am I doing wrong?
Jack the car up on the side you want to inflate to get the weight off of it. No compressor that i know of that plugs into a cigarette lighter is strong enough to inflate a flat tire under that much weight.
Nov 01, 2012 | Mini Tools & Hardware - Others
Im trying to figure out how to inflate the trek 4900 tire, its not your normal valve stem and i havent found anyone that know please help me?
Where did you look? Search for "inflate bicycle tire" or "inflate presta valve".
Search engines work for most common questions - immediately.
Aug 04, 2011 | Trek 4900
I have a SeaHawk 340 that is missing the cap for the main air chamber. therefore, I can neither inflate it and hold in the air if it was inflated. Is there any chance of a replacement part?
Too late with this reply, but hope it helps someone else like us. I had the same problem, then discovered the boat manual and found the cap is called a Boston valve; in this case 2cm (diameter). I cannibalised a smaller boat of ours for one (valve the same size), and you may get one cheaply by doing the same from a cheap boat at a car boot sale. Otherwise search eBay or Amazon for "Boston valve" or "Boston screw"; not cheap, but still a lot cheaper than a new boat.
Jul 12, 2011 | Intex Seahawk 4 Boat Set Four Person...
I have a walgreen blood pressure monitor that you have to inflate and i dont know when to stop inflating and sometimes i inflate too much and gives me an error what am i doing wrong i lost the manual...
if you have to inflate it manually, usually 190 to 200 is a place to start. If you can tell me who the manufacturer is and the model number, I may be able to furnish you an Owners Manual.
Hope this helped you. Please let me know.
May 16, 2011 | Health & Beauty
Just got a Skedaddle 2 XC Inflatable Kayak and having trouble trying to inflate it at home to see how it works before going out on the water. Don't know which tip to use on the foot pump or where to use it...
Use the threaded tip for the two main chambers, but be sure to turn the inside part of these valves clockwise to put them in the inflate position -- just press your finger on the valve and turn (the instructions aren't very clear on this). To deflate, push the valves in and turn counterclockwise.
For the orange twist valves use the tip that fits over them -- there is only one that fits snugly over them. Don't forget to open the valves (turn counterclockwise) before inflating and then close them (clockwise) before removing the tip. Just turn then cc to deflate when you're ready to put the kayak away.
I was able to inflate the Skedaddle 2 in less than 7 minutes on my second try, and I wasn't rushing at all. It's really pretty easy once you get the hang of it.
Mar 20, 2011 | West Marine Skedaddle 2-XC Two-Person...
The Carousel doesnt inflate complety, I already check everything and I really dont find the problem
check out this site: http://gemmy.com/customer-service/Airblown%20Inflatables/Airblown%20Inflatable%20General%20FAQs
Dec 19, 2010 | Carousel Airblown Inflatable Christmas...
We have a Gemmy airblown carousel with four figures inside. It will only partially inflate. We have unzipped everything and untwisted everything. The bottom inflates and part of the top but nothing in...
mine is doing the same it gets twisted cutting off the air supply. I unwind it and lubed it but it continues to happen. there seems to be some sort of spring on the inside at the based. i'm thinking of cutting the tie straps and seeing whats inside...
Nov 29, 2010 | Carousel Airblown Inflatable Christmas...
Tube leaks and I can not find the source to fix it.
spray it dwon with a soap water solution then inflate!! look for bubbles. sometimes a little seam sealer inside will fix . like used for tents
Oct 12, 2010 | Outcast Super Fat Cat Float Tube
Intex Excursion 4 Inflatable Boat Set Logo
935 people viewed this question
Top Intex Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you an Intex Boating Expert? Answer questions, earn points and help others
