Question about Vodavi Starplus SP7314-08 Corded Phone
Our system went down today and is now back up and reprogrammed. before it went down our incoming ring was a single ring and the internal ring was a double ring. Now it is the opposite. Is there a way to chang it back? the tech that reprogrammed the phones did not know how to change them
  • michelle603 Nov 10, 2010
    Do you know the steps of how to try and change it?
    Our phone system is the Starplus STS, It says something different at the top of this page (not sure if they are the same thing or not)
    Thank you!
  • 8,197 Answers
Sorry we do not know how to chang the ring. You can contact there tech suport on the link below.
http://vertical.com/about-contact.html
Good Luck
Posted on Dec 07, 2010
  • Vodavi Master
  • 2,460 Answers
It depends on the version software you have (FP2 or FP3). In FP2 Ring Scheme is supposed to be 2 by default which is single ring C.O. and double ring intercom. Scheme 0 is reversed, and 1 is both single ring. Scheme 1 is recommended with voice mail, probably because the VM gets confused on the double ring from intercom. It's programmed in Option 4 RESOURCES and it's the first choice in the database.
There is nothing in the manual on explanation of what the "4th" Ring Scheme is. My guess is it's distinctive ring, but it's just a guess. The Resources shows 0/1/2/3 but the explanation shows 0/1/2 only. My manual page explanation is on 176. The choices may be 1/2/3 or 1/2/3/4 so you'll have to play with the settings. I'm not able to fire up my DHS to check it at this time.
Carl
Posted on Nov 10, 2010
  • Carl Navarro
    Carl Navarro Nov 12, 2010
    No, they're not the same. An STS does not have changeable cadence, inside calls are double ring and outside calls are either single ring or distinctive. Go look at the phone system cabinet and post the part number here. There are a couple versions of DHS, and STS and STS-E. Also a part number off the bottom of your phone.
    Good thing I didn't dig out the DHS box.
Has Sansung Pro Star DCS - phone system; Has changed offices so moved the phone system. Now For incoming phone calls, none of the extentions can recieve the calls. Has four incoming lines; no incoming...
pdf.textfiles.com/manuals/.../Samsung%20Prostar%20DCS%20Compact%20System%20Admin%..
pdf.textfiles.com/manuals/TELECOM-S-Z/
panasonicmadeeasy.com/SamsungManualsLead.htm
Above is your setup manuals.
Unfortunately it is NOT just a simple job of moving the instrument, one has to reprogram the system to "Tailor" it to everything.
You need to use the manual and reprogram the system to it's new configuration.
Mar 14, 2011 | Cell Phones
Incoming calls ring once and are told thew will be transferred and then a voice tells them goodbye
Sounds like your system lost its programming so now the voicemail ports are just like extensions, they are ringing and picking up. And since the voicemail doesn't know where the phone systemn is, it just transfers all calls to the lowest numbered extension (10)
The system needs to be reprogrammed completely.
Jan 10, 2011 | Avaya/Partner 4-Line Display PBX...
How do I send a call to internal voice mail?
Use feature 986 (transfer to VM) then enter in the co-workers extension number. That will bypass the extension and send the caller directly to his voicemail.
Jun 29, 2010 | NorStar M7324 Telephone
I need different ringtones on my Nortel 7310
you should already, intrnal is double ring and external is long single ring. you can set sounds from the softkeys below display.
Nov 12, 2009 | Lands Phones
Ring tone for internal and external calls
this is a change your system administrator will need to handle, (or your phone tech). There is an option in the under "system options" called internal ring cadence for external callers; this is where you can have the system do a double ring for External and a single ring for internal or vice versa.
Jun 25, 2009 | Mitel 5212 IP Phone
Since power outage phone lines do not ring - only to receptionist
Your system lost its programming. It will need to be reprogrammed completely. The lines are ringing on the extensions where I voicemail is, unplug voicemail and at least lines will ring in correctly.
Jun 15, 2009 | Avaya Lands Phones
Stop ringing at main phones when outside calls come in.
Here is a link to program line ringing.
It sounds like your extension is forwarded (confirmed by the one beep you hear on an incoming call.
From any display phone, press Feature 11
then enter your extension number 2 times. So if you are extension 20, do this:
Feature11-20-20
see if that does it.
May 28, 2009 | Lucent PARTNER18 Corded Phone
We have a Toshiba phone system DKT2010 and I need to reprogram
try to decrease to volpum of ringging
other wise ask the vendpr to reassign the incoming ringging group for yr 3 incoming lines
Apr 13, 2009 | Toshiba DKT3010SD Corded Phone
Lost power and need to reprogram lucent 18D.
Call in a vendor. Your system has lost all programming. Voicemail is goofed up to a point.....
The entire system needs to be reporgrammed.
Jan 07, 2009 | Lucent PARTNER18 Corded Phone
M7310 phone not ringing audibally
If the internal calls dont ring, then there is something with the extension. When a call is ringing the phone, press the UP VOLUME. Chances are that someone accidentally turned the ringer all the way down.
Let me know if that doesnt work.
Nov 05, 2008 | NorStar Meridian M7310 Phone
Vodavi Starplus SP7314-08 Corded Phone Logo
101 people viewed this question
Top Vodavi Lands Phones Experts
george  peters
george peters
Matthew MacWilliams
ray gallant
Are you a Vodavi Lands Phone Expert? Answer questions, earn points and help others
