Question about Toshiba Televison & Video
Toshiba RDXV59DTKB2 HDD/DVD/VCR recorder. Transferred non commercial VHS tape to HDD at SP quality - OK. Transferred video from HDD to DVD at LP quality with auto finalize selected - OK on playback within Toshiba machine. Will NOT play on PC DVD player or other (Philips) DVD player hooked up to TV. Tried 2 different blank DVD-R discs - no joy. What can I do to get a playable disc for other machines????
  • 1 more comment
  • edinburgh444 Nov 11, 2010
    Thanks but this machine offers only one option for recording on to DVD-R which is 'Video Mode'. There is no choice of CODEC provided.
  • edinburgh444 Nov 14, 2010
    Anyone actually used this machine?
  • edinburgh444 Dec 08, 2010
    The Toshiba is DESIGNED to transfer VHS tape content to DVDs either directly or via the built in hard drive. If you can not transfer to DVD, I should ask for my money back!
    Genius:
  • 1,126 Answers
You might want to try using the+R DVDs..
Posted on Jan 05, 2011
  • 8,197 Answers
Sorry you can not transfre to DVD. It will not work
Posted on Dec 07, 2010
  • Toshiba Master
  • 12,061 Answers
Ok, this is happening due to the fact that the CODEC FORMAT you recorded in doesn't exist on the player you wish to play it on.. you MUST ensure you encode the DVD in a CODEC that every machine will have... When you Burn a DVD the information is Encoded, with a CODEC, the SAME CODEC is required to Play it back, if the Player doesn't have the particular CODEC as standard, then it simply is unable to play the DVD. Look on the DVD Player and check out what CODECs it can handle, then encode your DVD Burns using that CODEC, and you will be able to play it on any compatible player, Usual formats are MPG4, VOB, DiVx,
have a look below to understand what you need to do.
http://www.webopedia.com/quick_ref/Video_Codecs.asp
Posted on Nov 11, 2010
I have a Toshiba RDXV59DTKB2 Hdd & DVD/Video
The control board is shot including the on/off switch.
Jan 21, 2013 | Televison & Video
Audio noise on some, but not all VHS tapes
First thing i would say is go for the HI-FI audio would go in and out and pop etc. Adjusting the tracking would bring in the audio, but sometimes the video would get fuzzy. Get the picture right and the audio goes out. Switch to Linear (mono on some VCRs) and the audio should be fine.
Finally if this doesn't solve your problem then i would suggest you to give it to repair and they will fix it.
Goodluck..
Feb 16, 2008 | Panasonic DMR-ES46VS DVD Recorder/VCR
How do you record dvd to vhs and from vhs to dvd
For VHS to DVD, put the tape to dub in the VHS slot and a blank DVD in the DVD tray. Make sure the DVD is compatible with the DVD recorder (see the recommended disc list) and is unfinalized if you are using a R/W disc. Close the tray. Set the unit to VCR mode with the DVD/VCR button. Advance the tape to the place that you want the recording to start. Then press the Dubbing button (either on the remote or the unit itself). Select the recording mode (SP, LP etc), highlight Dubbing then press Enter or Dubbing. Press Stop to interrupt the recording.
For DVD to VHS, put a blank tape in the VCR (make sure the protection tab has not been broken off) and the DVD to duplicate in the DVD tray and close the tray. Put the unit in DVD mode by pressing the DVD/VCR button. Find the point at which you want to start recording the DVD. Again press Dubbing and set up the recording mode and highlight Dubbing and press Enter or Dubbing.
Note that copyprotected content can not be recorded.
The manual for this recorder is on the right side of the page here: http://www.lg.com/us/tv-audio-video/video/LG-dvd-recorder-RC897T.jsp . See page 48 for the screen captures of setting the recording mode part of the dubbing procedure.
I hope this helps.
Mar 19, 2011 | LG RC897T DVD Recorder/VCR Combo
Have a toshiba tp 61H95 proj TV- want to connect panasonic dvd recorder and toshiba vhs recorder so I can copy family videos to dvd- can't get hook ups set up for both to work.
Select AV-1 or some thing in TV and plug DVD recorder Video-Audio output in AV-1 input of TV, playback any DVD and confirm its picture and sound in TV. Press Stop button of DVD recorder to stop playback.
Now plug Video-Audio output of VCR in DVD recorder input and select AV Input in DVD recorder, insert VHS tape in VCR and playback it and confirm you get VHS picture and sound in TV via DVD recorder.
Hookup between TV, DVD recorder and VCR is completed.
Playback VHS tape in VCR, Insert blank DVD disc in DVD recorder and press Record while you see VHS tape picture in TV.
Hope this info will help you.
Feb 03, 2010 | Toshiba TP61H95 61" Rear Projection...
Which is better to record with SP or SLP?
HELLO!
The answer to this is simple....SP every time. That is of course you want to cram lots of programmes on to one tape and if that is so, then use LP.
LP slows the tape to half of normal speed and therefore sound and vision are slightly compromised. For maximum quality, SP.
HAVE FUN (:-)
Aug 31, 2009 | Orion VR213 VHS VCR
VCR DVD Recorder not dubbing
I called the manufacturer and realized I was using the wrong type of recordable DVD disc to dub to. Non copy protected VHS tapes dub just fine as long as I'm using the proper disc.
Jun 03, 2009 | Sony RDR-VX530 DVD Recorder/VCR
How to switch the tape speed on Go Video dvd/tape.
  1. Press SETUP,
  2. Toggle with the left/right arrow to the RECORDING OPTIONS (icon has a dot and the letters REC below it in the icon menus at the top of the set up screen.)
  3. While RECORDING options is selected, press the DOWN arrow to select VCR RECORD QUALITY.
  4. Press ENTER to go to the submenu.
  5. Use the ARROW UP/DOWN buttons to select the desired quality.
  6. Press ENTER to confirm selection.
  7. Press SETUP to exit the menu.
This is the same procedure for selecting the quality for the DVR recording speeds.
VHS speeds are:
SLP is 3x the recording time of SP.
DVR recording options are:
HQ=1 hour
SP=2 hours
EP=4 hours
SLP=6 hours
per disc.
Mar 18, 2009 | GoVideo VR3845 DVD Recorder/VCR
How do i hook up dvd recorder/vcr to my tv?
Hello.
If its a combined dvd/vcr unit you should be able to record on the dvd input from the vcr with a 3 split cord connected as described below..
VCR -
Video output - yellow.
Audio output - left and right - red & white.
DVD
Video input - yellow.
Audio input - left and right - red & white.
Or you might have to use a standared RF cable from the
antenna out on the video to the antenna in on the DVD.
Additional information....
Just as you can't copy commercially made video tapes to another VCR due to Macrovision anti-copy encoding, the same applies to making copies to DVD. DVD recorders cannot bypass the anti-copy signal on commercial VHS tapes or DVDs. If a DVD recorder detects the anti-copy encoding on a commercial DVD it will not start the recording and display some sort of message either on screen or on its LED front panel display that it detects the anti-copy code or that it is detecting an unusable signal.
A DVD recorder can be used to copy any homemade videos, such as camcorder videos and videos made from TV shows, and can also copy Laserdiscs, and other non-copyprotected video material. Also, remember that a DVD recorder also has a built-tuner for recording TV programming directly. The tuner can be programmed to record a series of programs on different days and times, much like a VCR. However, if you are recording a non-copy protected DVD to a DVD recorder you can record any of the video content, provided you click on the menu and start the video segments running and you have enough time space on the disc. DVD recorders function like VCRs in that they can record incoming video signals -- however, they do not automatically copy all the contents of the DVD - for instance, you cannot copy the interactive menu functions of a non-copy protected commercial DVD. A DVD recorder creates its own menu functions, it will not duplicate the function menu from a another DVD.
Hope this will help you.
/Tech5508
Feb 13, 2009 | Toshiba DVR610 DVD Recorder/VCR
No Instruction Manual
1. Insert a blank DVD disc in the DVD deck and
close the disc tray.
2. Insert the VHS video tape you wish to copy into
the VCR deck.
3. Find the place on the VHS tape from which you
want to start dubbing using the PLAY, FF, REW
and PAUSE functions. For best results, pause
playback at the point from which you want to
record.
4. Press the DUBBING button on the Remote
Control or DUB on the front panel.
The Dubbing menu appears.
5. Use the arrow keys to select the desired Record
Mode: EP, LP, SP or XP.
6. Select [Dubbing] then press ENTER or DUBBING
to start copying.
7. To stop dubbing at any other time, press STOP (x).
Dubbing will stop automatically when the VHS tape ends.
Mar 01, 2008 | Insignia IS-DVD1001 DVD Recorder/VCR
VCR to DVD Dub Out of Synch
FIRST THING YOU HAVE TO DO IS HAVE YOUR DVD RECORDERS LENS AND DRIVE CLEANED ALSO MAKE SURE THE VCR HEADS ARE CLEANED ALSO.
NEXT WHEN RECORDING make sure the format of the tape(speed like sp & lp are the same as the dvd recording speed(sp& lp are the same before starting recording.
Nov 20, 2007 | Insignia IS-DVD1001 DVD Recorder/VCR
Televison & Video Logo
241 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
