Question about Tamron 18-200mm f/3.5-6.3 for Nikon
My lens will not zoom when the zoom ring is turned. What can I do?
  • Tamron Master
  • 3,289 Answers
I'd contact Tamron Tech Support. These are not cheap optics and they are assembled with precision. Opening the lens could cause contamination or further damage resulting in an even costlier repair, if out of warranty. Most Tamron lenses are covered by up to 5 years of warranty - provided you haven't opened it up - or abused it.
I hope this helped - good luck!
Posted on Nov 10, 2010
I have a Quantaray 28-200mm AF zoom lens Nikon, I use Nikon D80, are they compatible?
Turn the aperture ring on the lens to its smallest setting (largest f/number). You can control the aperture from the camera body, the same was as with a lens without an aperture ring.
Jul 14, 2014 | Quantaray 28-90mm F3.5-5.6 Autofocus Zoom...
When the camera is turned on and the 16-105 DT 3.5-5.6 zoom is attached there is a repeated clicking sound that continues until the camera is turned off. A sony camera salesman indicated it was the lens. ...
I had the same problem with my SAL-16105. It turned out that inside the lens the FOCUS DIFFERENTIAL RING (Artnr.: 321020202) was broken. The camera tries to move the focus from one end to the other when it is turned on (probably to check the functionality), but as the ring is broken, focus will never reach its end-point. Thus the camera continues to try to turn the mechanics futher until either the gear on the lens ring or one of the gears inside the lens will jump, making the clicking sounds. Another reason might be that one of the brushes ("focus brush") inside the lens that are used to signal the position of the focus to the camera electronics is damaged. (This might even lead to the mechanical destruction of the focus differential ring I think). I was able to repair my ring, but as I had to glue it, after a few months it failed again. I'm waiting for a replacement ring now.
May 15, 2011 | Sony 16-105mm f/3.5-5.6 Zoom Lens for ...
ROKINON AUTO ZOOM Macro--- HELP to enable macro
Some of the Rokinon (and other ) zoom lenses could only go into MACRO at certain focal lengths- the lens you have "zooms" from 80 to 200 focal length,but is that done by "sliding" a ring forward and back on the lens, or by twisting a different ring that the one that focuses?
May 16, 2010 | Rokinon 85mm f14 for Nikon
Hi I bought a pro-spec 70-210 lens for my Sony Alpha. When you go to zoom out it doesn't twist. You can pull it straight out...Is this how it should work? The rest of my lenses all twist out
Yes. It's a push pull zoom action.
One touch zooms as used on 35mm film SLRs used to have the same mechanism, the zoom ring twisted as well to achieve focus but now that most lenses are autofocus that's unnecessary. So you have a lens which just retains the push-pull, a far more natural action in my opinion and usually faster than a rotating zoom. Once you get used to it I think that you'll prefer it.
By contrast, most modern zooms have what was considered in 35mm terms to be an old-fashioned twin touch zoom: one ring was turned to zoom the lens and another was turned to focus it. This sometimes meant that after zooming you had to refocus; your push pull zoom will likely have a more technically demanding constant focus zoom action, there will be an additional manual focus control as well, but it's very much a minor secondary control used only when your AF has broken or is switched off.
I hope that my reply has been of use to you, please return the favour by rating my answer.
Mar 03, 2010 | Sigma 70-210/4-5.6 UC II AF Zoom Lens for...
How to achieve full zoom with a Nikon 55-200mmf/4-5.6G ED lens?!
1) What camera body are you using?
2) I do not understand your assertion that it automatically zoomed in. Zooming is a manual function. The automatic functions of your lens pertain only to focusing on of the subject so that your picture is sharp and ensuring that the correct amount of light is admitted so that you have a correct exposure.
3) Are you sure you were turning the zoom ring and not the f-stop ring? The zoom ring is labeled 200 on one end of the scale and 55 on the other. It is also the widest ring on the lens barrel. When you rotate it, the physical length of the lens will lengthen as you rotate it clockwise (viewed from behind the camera) and shorten as you rotate it counter-clockwise.
4) For reference, at 200mm the angle of view on your lens should be 10 degrees and at 55mm about 40 degrees.
Dec 27, 2008 | Nikon Zoom-Nikkor 55-200mm f/4-5.6G ED...
Zoom ring is loose and drops/slides on its own
Yes, this happens even when the lens is brand new. Some other lenses have a Zoom lock to prevent it. What I did was to slip a flat rubber band around the black area just behind the zoom ring, the area where there is s white mark or line, with the band ring just touching the zoom ring. The rubber band should be fairly tight, but not too tight. When the zoom ring revolves, the rubber band touching it gives it just enough friction to prevent it from turning. You can adjust it to give as much friction as you want. Hope this helps. Jay
Oct 02, 2008 | Canon EF-S 17-85MM F/4-5.6 IS USM Lens
Kodak m763 wont stay on
i think you should take the battery out then hold the power button for ten seconds then put the fully charged battery back in if it doesnt work go back to the store and have them look it over.,
Jul 21, 2008 | HP Photosmart R927 Digital Camera
No zooming
sorry but the dmc-fz7 does not have a zoom ring only a zoom control on the top right.
Apr 29, 2008 | Panasonic Lumix DMC-FZ7 Digital Camera
Zoom ring on 18-55 mm lens is locked/stuck
Are you sure it's the zoom ring that's stuck, and not the focus ring? The focus ring doesn't move when the camera is in autofocus.
If it's indeed the zoom ring that's stuck, you can spend more money than the lens is worth in repairs, or buy a replacement (circa 35 dollars on ebay) for dreadfully cheap. Good luck.
Apr 06, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Tamron 18-200mm f/3.5-6.3 for Nikon Logo
212 people viewed this question
Top Tamron Cameras Experts
Steve
Jerry Greenberg
Jerry Greenberg
bhargav
Are you a Tamron Camera Expert? Answer questions, earn points and help others
